Question about Ozeri Health & Beauty
Need manual for Ozeri digital kitchen scale Model ZK013
I am unable to work it because I misplaced the manual
SOURCE: Need manual for the Chefmate Digital Nutritional Scale
Redtruckie,
The contact information from my manual is:
e-mail: sales@alldmd.com
Phone: 314-453-1606
Customer support: www.weighoflifescale.com
Hope this helps.
Bill
Posted on Apr 11, 2009
awa13
  • 78 Answers
SOURCE: Salter kitchen Scales Model: 1041SVDR won't turn on.
This sounds very typical of kitchen and postal scales. I know you don't want to hear this, but this basically means it is time to replace your scale with a better scale - perhaps no longer giving Salter your business..
Posted on Mar 21, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: Healthometer Bathroom Scale
http://www.healthometer.com/Manuals.aspx
Posted on Aug 23, 2010
fb62685
  • 4 Answers
SOURCE: I just bought I digital
I had already solved this after a lot of playing and research, put I thought I;d post it on here for others as the answer was different for other scales listed here. What I did was press the 'Button 1' and 'Button 2' together for 5 seconds. This powered it up and then the display showed 'Cal' with a number on the screen. I pressed 'Button 1' again and it said 'Zero' and then displayed the numbers '0000'. Then I added 1kg of weight and it said 'Cal1'. Then I added 3kg of weight. It said 'Cal2'. Then I added 5kg of weight. It said 'Cal3', then 'Pass'. It then returned to normal mode and now started weighing correctly. I calibrated the weights (Flour and Sugar packs) on another set of scales first, but they were only a few grammes wrong so would be close enough anyway. I hope that helps!
Posted on Dec 04, 2012
Scales will not turn on
If there is still power in the battery and it is inserted correctly then the connection may not be being made. Check the spring and flat connectors are tounching the battery tightly. Has your scale been wet? This could cause a short. If non of the above it is a loose wire and you should return if under guarantee or have repaired/replaced.
Jan 13, 2016 | Ozeri Scale. Touch Digital Bath Scale in...
NEED MANUAL
google it or manufacturers website customer support
May 02, 2015 | Ozeri Touch Professional Digital Kitchen...
HOW DO I CHANGE BATTERIES IN OZERI BATHROOM SCALE MODEL ZB13
On the back of the scales under the Ozeri sticker, you will find the battery cover. Remove the cover and replace the two CR2032 batteries (model ZB13).
Sep 04, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
How do I reset my ozeri digital scales that read body fat percentage
I fixed this on my scale by going through every profile and changing the height and age, setting the two main ones correctly (but swapping my wife and mine) and then setting the rest to be very short and young. Then I pressed Set, picked my profile again, and weight myself. At this point I no longer got the PIP2 error.
Jul 31, 2014 | Ozeri Precision II Digital Bath Scale...
How do I restart my Ozeri ZB13-W after replacing batteries?
Should start right up. Check make sure batteries are good and properly installed. If terminals are dull looking shine them and reinstall batteries for a good connection.
Apr 24, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
How to change kgs to lb
There's a small "unit" button on the bottom/back of the scale. Press this until it goes back to lbs. It should cycle between kg, stones, and lbs. If that doesn't seem to be working, press and hold for 4 seconds or more. The screen will flash "reset" and it will have gone back to default, factory settings.
Mar 23, 2014 | Ozeri Scale. Touch Digital Bath Scale in...
Ozeri ZK 14, error code oVE2, what does it mean?
oUt2 means that it needs to be calibrated. I am not familiar with these scales so no sure if they can be re-calibrated.
Jan 25, 2014 | Ozeri Pro II Digital Kitchen Scale in...
Manual for ozeri zb13
search on google for Ozeri zb13 manual.
Dec 07, 2013 | Ozeri Scale. Touch Digital Bath Scale in...
Health & Beauty Logo
438 people viewed this question
Top Ozeri Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Ozeri Health and Beauty Expert? Answer questions, earn points and help others
