Hi, I installed my sierra custom home but it wont open everytime I want to open it, it gives me this message " THE PROCEDURE ENTRY POINT _RESETSTKOFLW COULD NOT BE LOCATED IN THE DYNAMIC LINK LIBRARY MSVCRT.DLL".
I installed this programme before and it worked perfect what can be the problem....
-   I just tried to load the software into my computer, and have the same error message. Downloaded the msvcrt.dll file to my system files, and still no go.-   mismadhatter
Just delete the msvcrt.dll file from the SHA folder (C:\Sierra\SHA).
In Vista:
1. Click on the Start button. 2. Click on Computer. 3. Click on Local Disk (C:). 4. Double-click on the Program Files folder. 4. Double-click on SIERRA folder. 5. Double-click on the SHA folder. 6. Click on the msvcrt.dll file. 7. Press delete.
I have had this installed on my XP for more than a year with few problems--none that affected the...
(More)
I have had this installed on my XP for more than a year with few problems--none that affected the way it ran. Suddenly one day when I tried to "Start with a Blank Design", I got the message "Sierra Home Architect (tm) has encountered a problem and needs to close." The option "Open Most Recent Design" sometimes does nothing. HOWEVER, I can open any of the Designer Rooms and change that any way I want to, and I can open any of my saved designs through the File menu inside the program. I can live with this but it would be nice if it worked like it used to! I have uninstalled and re-installed, restarted, and defragged my computer several times since this started happening. Could it be that one of the Windows updates has affected the program?
I read to delete the file msvcrt.dll to fix my problem of not being able to even open sierra home...
(More)
I read to delete the file msvcrt.dll to fix my problem of not being able to even open sierra home architect but now once I get it open it's saying the program has encountered a problem and needs to close. When I go to view the errors it says it's another SHA problem.
Sierra Home Architect will not let me save any of my work. It will ask if I want to save when I...
(More)
Sierra Home Architect will not let me save any of my work. It will ask if I want to save when I close down the program and if I say yes, the program does nothing. Also, even when I try to save manually by pressing the "save" button, nothing happens. What do I do?
services.exe entry point not found the procedure entry point-resetskoflw could not be located in the...
(More)
services.exe entry point not found the procedure entry point-resetskoflw could not be located in the dynamic link library msvcrt.dll
