Question about Tablets & eReaders
How to unlock the 4sight tablet
My son forgot his password and did not set up a google account yet. is there anyway to bypass the password??
  • 24 Answers
SOURCE: COMPAQ TC1000 TABET FORGOT PASSWORD
TC1000 Password Clearing Procedure
1. Discharge any static electricity you may be carrying, it can burn up your mainboard and it doesn't take much! Remove the battery pack and place it out of immediate reach. you will be tempted to snap it back in later before it should be and this will spoil the work. Read everything before you start so you will understand. Remove the mini PCI communications/ memory expansion slot cover (2 small phillips screws, stick them to a piece of tape. When you reinstall them later, start by turning backwards till you hear and feel the threads mesh, then tighten slowly ... you don't want to strip out the threads on your frame! "Lefty loosey, righty tighty")
2. Remove the RTC battery “Real Time Clock (RTC) Battery” This is the black coated nickel sized battery tucked under the frame edge a little. You may have to remove the RAM if you have the extra slot filled to have enough room to work the RTC battery out. to remove the RAM chip pull the spring arms gently away from both sides at once and it will pop up at a 45 degree angle. pull it straight out. to reinstall it later put it back in at an angle, push it gently in then down to let the arms snap onto it and hold it in place. only goes in 1 way, note the notch. Use a toothpick to lift the black plastic film from the edge of the chip as it always tries to get in the way on reinstall. Have some patience or let someone else do it. DO NOT use any metal tools and be sure to remain static free!
Break or cut a short piece off your toothpick to make it easier to use the squared end to push and work the connector of the RTC battery plug off it's attachment. You may be able to unplug the RTC battery without removing it, your call. It connects at the white connector thats located next to the frame rail that separates the battery compartment from the mini PCI communications/ memory expansion bay. It is between (above) the battery release switch and the thumb lift depression to lift out the battery. Now, hold the power switch in the on position for 30 or 40 seconds to discharge any static. This is a good and recommended practice every once in awhile when batt is out and AC is not connected.
moz-screenshot-3.jpg3. Wait approximately five minutes.
4. Replace the RTC battery (or reconnect it)and reassemble the tablet PC except for the main battery, do not install it yet! Remember the toothpick will help you get the plastic film lifted clear of the RAM chip, work it into place at a 45 deg angle and then gently press it down till it locks. DO NOT STRIP out your cover screws, or try to get them super tight. They will strip out your frame, finger snug is enough.
Do not reinsert the battery pack at this time! Thats why you can't reach it!
5. Connect AC power to the tablet PC.
6. Turn on the tablet PC.
All passwords and all CMOS settings have been cleared.
7. Now you can reinstall the main Batt!
Posted on Apr 05, 2008
tengzong0214
  • 21 Answers
SOURCE: i have a craig touch screen tablet and i forgot my dot password how do i reset it?
Unlock windows password,the easiest way I ever use is to adopt Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
For more details,go to: http://www.windowspasswordreset.net
Posted on May 28, 2012
SOURCE: Forgot password on a brand new pandigital tablet, how can i reset?
u should really give us something helpful
Posted on Jun 16, 2012
TechyDrood
  • 2072 Answers
SOURCE: the screen for the 4sight tablet looks like it is scratched but it is not really because I felt for bumps on the screen but there wasnt any
Most tablets and smartphone use gorilla glass which is highly scratch resistant. It's probably just dirty, use a lint free cloth damped lightly with water and clean it. If it doesn't clean up post a picture of it.
Posted on Dec 06, 2012
ramona_wrigh
SOURCE: My son has a 4sight tablet he got for xmas n the
I don't know but my son put a pass code on his tablet and can't get in and he got his for Christmas also. Do you know how to reset the pass code?
Posted on Dec 27, 2012
I have a 10inch Tablet that my son put a password on but has forgotten the password. Is there anyway to reboot the tablet without knowing the password?
It's hard to tell you exactly how to do this without knowing which tablet you have. I'm guessing that it is an Android tablet and some of them (if you linked them with a Google account) will let you unlock them remotely through Google. This will have to be done by entering in the wrong password several times and then it will prompt you to try your Google account.
If that doesn't work you will most likely have to perform a hard reset on the tablet. Understand that doing so will wipe any personal files and reset it to the same state it was when you pulled it out of the box for the first time. I would recommend connecting your tablet to your computer and downloading any pictures or music you have on it first.
To reset the to reset the tablet some tablets have a small pin hole located on them that you can insert a paperclip into to reset the tablet. Some tablets will let you enter a development mode by holding down the volume-up key and the power key for several seconds. This will let you reset the device to factory settings.
Feb 17, 2015 | Tablets & eReaders
How do i unlock my tablet if i forgot my password?
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings. Support Troubleshooting Guide
Jan 27, 2015 | Kocaso M9300 Google Android 4.2 capacitive...
Unlock polaroid tablet
Continue trying passwords until the tablet asks for your google account sign in. For the user name type the word null, for the password type four zeros, ie, 0000. This is the universal google unlock code for android devices.
Sep 10, 2014 | Polaroid 7-in. Internet Tablet - Other
Unlocking pin code
You can try to open it with your google account, but you must be near to the internet that you used before.
Aug 29, 2014 | ASUS Google Nexus 7 Tablet
Polaroid factory reset
Before you try a reset continue submitting passwords until the unit asks for your google account sign in. If you have a google account go ahead and sign in. If you don't have a google account type null for the user name and four zeros, ie, 0000 for the password.
Aug 15, 2014 | Polaroid PMID4311BK 4.3 Internet Tablet...
I need to know how to unlock my Kocaso model # M9100 (blue) tablet. My son put in a security code and forgot it so now I am locked out! HELP PLEASE?
Apr 21, 2014 | Kocaso MID M9100 9 Dual Camera Android 4.0...
Unlock a kocaso M736 tablet forgot google password
Apr 18, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
I forgot my pattern to unlick my kocaso how do i factory reset it or unlock it
Apr 04, 2014 | Kocaso M M9100 9-Inch 8 GB Tablet
Son forgot password
Mar 23, 2014 | Kocaso M730W 1.2GHz 4GB 7 Capacitive...
Forgot password to enter xp
OK
RESET IT
YOU GO ON SAFE MODE AND CREATE A NEW ACCOUNT . TO GO IN SAFE MODE PRESS F8 BUTTON WHILE BOOTING WINDOWS. ONCE IN SAFE MODE CRATE A NEW ACCOUNT, THEN RESTART THE PC. ONCE YOU RESTART LOG ONTO THE NEWLY CREATED ACCOUNT AND GO:
CONTROL PANEL> ADMINISTRATIVE TOOLS> COMPUTER MANAGEMENT> ON LEFT SIDE SELECT LOCAL MANAGEMENT AND GROUP>THEN SELECT USERS>THEN U WILL SEE LIST OF USERS .
RIGHT CLICK THE USER U NEED TO RESET PASSWORD THEN SELECT ALL TASK SET PASSWORD>CLICK PROCEED> THEN LEAVE NEW PASSWORD AND CONFIRM PASSWORD BLANK THATS ALL
Nov 13, 2009 | Toshiba Satellite R10-S802TD Tablet PC
Tablets & eReaders Logo
143 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
