Question about Microsoft Windows Vista Ultimate Edition
Some disturbance in audio output
Sir i have some disturbance in the audio output and my sound level has been decreased just give me the way to solve the problem
    Sergeant:
  • 191 Answers
Go to control panel then sound ad devices then volume control then increase your audio
Posted on Jan 19, 2009
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Hello,peter
hello sir, my acer kav60 net book is installed with audio drivers. but there is lot of disturbances in audio ,how to solve the problem
Aug 15, 2011 | Computers & Internet
Audiodriverkav60
KAV60 is basically an AOD250. You should be able to download those drivers from the link.http://us.acer.com/ac/en/US/content/drivers
May 05, 2011 | Acer Aspire One PC Notebook
Audio-Technica freeway 200 Series VHF Wireless System - I had problems connecting the wireless system with a quarter inch to a xlr. The sound system made a very loud disturbance sound. What cable do I use...
XLR connectors are a two-wire plus ground system. Using a 1/4 inch to XLR adapter may not connect the wires correctly to your sound system input.
The A-T Freeway 200 Series has a 1/4" output jack. This would indicate a line level. A cable to connect the tip of the 1/4" jack to pin 2 of the XLR and the sleeve of the 1/4" jack to pins 1 and 3 of the XLR should work. The XLR should be plugged into a device that accepts line level.
Ideally, you should plug the 1/4" into a 1/4" or RCA jack that is designed for line levels.
Dec 14, 2010 | Audio Technica ATM33A Fixed Charge...
I was wondering if there's a way to change audio out from variable to fixed cause I want the volume out only from my surround sound not from the tv I heard If I switch from variable to fixed the problem...
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Sep 09, 2010 | Televison & Video
We cannot increase or decrease the sound. There does not appear to be a volume control on the set and it does not respond to the remote. The remote is working in all other respects.
Make sure the speakers are turned on in the audio menu. Usually when the speakers are turned off the set goes into a fixed sound level at the audio output jacks. These jacks are used for external amplifiers, etc. Hope this helps. Thanks
Oct 28, 2009 | Philips Magnavox 27MS343S 27" TV
Volume when on tuner is very different than when on DTV
Under the input menu, there is a volume trim function which allow you to increase or decrease the volume level of each input. It is designed so that the volume of different components can be matched to prevent a blast of sound when changing to a lounder output. You can increase the alevel of the dtv input, and decrease the level of the tuner. Tuner volumes are usually high.
Jan 24, 2009 | Yamaha RX-V1400 Receiver
About sound(audio) drivers
go to this link and follow the steps and it will take you to the drivers you need --
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3739727&lc=en&dlc=en&cc=us&lang=en
if this has helped you please select fixya, thank you
Dec 25, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
74 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
