Question about Philips Philishave Cool Skin HQ6760/HQ 6761
Replacement batteries for cool skin HQ6760
Battery does not hold charge
2 Suggested Answers
brector3
  • 1610 Answers
SOURCE: My Philishave Cool Skin HQ6740, doesn't charge the
If the shaver will not charge, the problem is likely the batteries are worn out. You will find replacement batteries at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Posted on May 08, 2010
Hi, I'm Looking for a Philips 8000 Series Razor Charger Stand.
You will find this item at shaveroutlet.com. Always be sure to match your specific model number to the list of compatible models to ensure you are ordering the correct item.
Norelco Philips 8000 Series Cool Skin Charging Stand
Mar 16, 2016 | Philips Philishave Cool Skin HQ6760/HQ...
How to get replacement heads for philishave cool skin HQ6761
Compatible blades can be found at shaveroutlet.com using the link below
http://shaveroutlet.com/philips-norelco-hq7-gentlecut-shaving-heads.html
Jun 28, 2014 | Philips Philishave Cool Skin HQ6760/HQ...
My shaver would not hold its charge then finaly just stoped running
Sounds like the battery is dead. A replacement battery for model 7775X can be purchased at the link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/philips-norelco/shaver-battery-pack-for-most-norelco-more-p-278.html
Mar 26, 2013 | Norelco Cool Skin 7775X Electric Shaver
My philipshave coolskin shaver doesn't work after it has been charged. when it is on the charging stand the green light is showing that it is being charged. Please help!! Ry
Your battery pack is probably dead and needs replacing. You will find the correct battery for model 5605X at shaveroutlet.com. See link below for item and also scroll down item page for installation tip videos
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
Aug 13, 2011 | Philips Philishave Cool Skin HQ6760/HQ...
Charged up but seems jammed
soak your blades in a boiling solution for a couple of minutes.
Oct 28, 2009 | Philips Philishave Cool Skin HQ6760/HQ...
Charged for approx. 6 hours then wouldn't work
I copied this from the Philips website... this took me FOREVER to find! Their site isn't the easiest to find products on...
"Insert the small plug into the shaver and put the powerplug in the wall socket. When you charge the appliance for the first time or after a long period of disuse, let the shaver charge for at least 16 hours. Remove the powerplug from the socket and the small plug from the shaver as soon as the batteries have been fully charged. Ignore the charge indicator when you charge the batteries for the first time. The batteries are completely new and need to be charged longer than the time indicated by the charge indicator to ensure that the back-up capacity is fully charged as well."
I hope this helps. Please remember to rate my help! I would greatly appreciate it!
Apr 26, 2009 | Philips Philishave Cool Skin HQ6760/HQ...
Lock symbol
You've turned the travel lock on - hold the power button down for about 3 seconds and it should turn off and on normally again.
May 11, 2008 | Philips Philishave Cool Skin HQ6760/HQ...
Philips cool skin shaver fault
The shaver head symbol means the motor isn't starting, which all the support info assumes is because the heads are too gunked up with hair and congealed moisturizer etc, so clean it. In my case it was because the motor had seized - I completely dismantled the razor and turned the cog attached to the motor spindle by hand while turning the razor on, which was enough to free it up and kickstart it - you'll need some torx screwdriver bits - remove the battery cover (it may be a bit sticky since it is wedged against a rubber seal that it may have stuck to, but it does just lift off, there's nothing to snap), remove the black plastic retainer underneath that which hides a couple of screws holding the head assembly (you may need to prise the battery up to get at them) - undo them and you should be able to pull the head assembly off and push the motor up from underneath to free the plate holding the three cogs driving the head - beneath that is a big cog attached directly to the spindle, spin that by hand while starting the razor and it should hopefully spring back into life since you'll have freed the seized spindle.
Sep 10, 2007 | Philips Philishave Cool Skin HQ6760/HQ...
Philips Philishave Cool Skin HQ6760/HQ 6761 Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
