Question about Xerox Phaser 6125 Laser Printer
Just replaced fuser assembly on Phaser 6125 but it's leaving a shadow of the print down the page.
Originally the ink wouldn't fuse to the page unless you used regular paper. Now even with a new fuser assembly it still doesn't stay on the paper and it leaves a shadow of the print image all down the page. I've used all the maintenance menu tasks to refresh the drum, clear developer etc, but it still won't print cleanly. This printer is less than two years old. Any other suggestions?
Soulvisitor
  • 1113 Answers
SOURCE: Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Posted on Nov 19, 2007
checkitright
  • 1362 Answers
SOURCE: Phaser 8560 smudging problem
previous image on a copy are from two things
1-the blanking lamps that erase the image from the drum from the previous copy, and making it ready for the next image is bad
2- the fuser roller is bad and retaining the image on it.
Posted on Oct 08, 2008
pdouglasss
  • 125 Answers
SOURCE: phaser 8560 magenta ink not transfering to paper
Hi jbasset285: Your printhead may be bad do to third party ink.
Try these steps first.
Diagnosing Print-Quality Problems
The Troubleshooting Print-Quality Page provides a good overview of the most
common print quality problems. To print the Troubleshooting Print-Quality Page,
follow these steps:
1. From the Control Panel, scroll to Troubleshooting, then press OK.
2. Scroll to Print Quality Problems, then press OK.
3. Scroll to Troubleshooting Print Quality Page, then press OK.
The Troubleshooting Print Quality Page includes instructions for printing the
Eliminate Light Stripes test print. These instructions are also provided on the next
page of this manual. The Eliminate Light Stripes test print indicates individual weak
or missing jets or an obstruction in the imaging path that affects a vertical band down
the entire page. Also, you may see color variation from jet to jet on the Eliminate
Light Stripes test print. Some variation is normal, occasionally occurs, and usually
self-corrects within a few printed pages. If a print-quality problem is not resolved
with the information provided in the Diagnosing Print-Quality
Posted on Jan 09, 2009
  • 2072 Answers
SOURCE: xerox phaser 8560 prints blank pages
That's very weird, I have been thinking about your problem a lot.
What I am wondering is if somehow there is a piece of paper between the print head and drum, but that should be moved out of the way by the wiper blade assembly.
There is a compressor that creates the pressure to spray the ink onto the page. That could have failed, or one of the hoses disconnected.
The other thing is the print head itself. But if this was a sudden thing, it really isn't likely the print head jets failed all at once. That would be bizarre considering the amount of jets on that print head.
If there were an electrical problem with the print head, the machine would definitely give you a fault code, and if the print head was not going into the proper position you would no doubt get an 07,xxx.xxx code.
I have to conclude the compressor or a bad or somehow disconnected hose. The compressor is near the ( looking from the front) the right side , near the top rear of the machine, It is a black box and has a hose with a wire wrapping around it.
Posted on Jan 28, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 8550 drum issue?
The life of the drum is unlimited, it is just a solid aluminum drum.
The usual suspect when the drum is not cleaning is the maintenance kit. It was not stored on end was it ? If so the lubricant would have run to one end and not clean correctly.
The transfix roller could be failing, although that is not many pages on the printer.
You are using OEM ink and not third party? If so try new ink.
The last thing you could have is a bad wiper blade not cleaning between pages.
Drum heating is very unlikely. If it was not running hot enough, there are enough sensors in the machine that one would shut off if it were not heating properly.
Posted on Feb 19, 2009
Print is repeating on next page
That type of problem is usually caused by the fuser assembly. The heat roller is coated with a Teflon film. When this coating get worn down some of the toner stays on the fuser and is deposited on the next page. You will need to replace the fuser assembly to correct the problem. The part number is RM1-4728 They are available from Ebay. It does take a bit of time to install one and you will need the service manual to do it.
Apr 01, 2013 | HP LaserJet M1522nf Multifunction Printer...
Smudged ink
Chances are the fuser is not working correctly. How warm is the paper as soon as it leaves the printer? It should be quite warm. The fuser heats the toner and 'fuses' it to the paper. If the fuser does not get hot enough, then the toner which is a powder smudges on the paper. Also not setting the correct paper type for a tray will also cause the toner to smudge as the printer adjusts the temperature based on the type of paper selected.
Aug 21, 2012 | Xerox Phaser 7700 Laser Printer
I have canon lbp 2900 printer when i print first line shadow is also printed in the middle of page and middle line shadow is also is printed in the last of page. and some of line shadow is also printed.
Repetitive ghosting defects like this are caused by either a bad drum in the cartridge or a damaged or worn fuser assembly. Try a different cartridge first, but make sure you print at least 50 pages to make sure that any toner residue is cleaned of the fuser in the printing process. If the defect is still there then you will need to either repair or replace the fuser.
May 06, 2011 | Canon LASER SHOT LBP-2900 Printer
ERROR CODE PHASER 8560 07,010.43:69551 Replaced Maintance kit
. they replace a certain number of pages printed by the manufacturer data
maintenance kits are easily user installable and come with a fuser assembly, transfer roller, and pickup, or feed/separation rollers.
Apr 11, 2011 | Xerox Phaser 8560DN Laser Printer
Top of the page prints fine. From the middle down it prints but also has a shadow or smear of what was printed higher up on the document.
there is a problem in fuser assembly where your prints actually fuses it needs to be cleaned or may need some parts to change
Jan 26, 2011 | HP LaserJet 2100 Printer
Help! My printer is printing text and then leaving like a shadow or very light imprint of that text on other pages. Too, there are a few ink splotches here and there on the various pages. Does the printer...
First, if you have one available swap out the toner cartridge. It is possible on this series for the toner cartridge to cause double imaging. This is especially true if the double imaging is across the entire page. If the double imaging is in more of a streak or line down the page especially on one edge then is it more likely to be a fuser film going bad. You can replace the fusing unit yourself if you want. Just do a google search for HP 4350 fuser unit (going by the picture in your post)
About $150 to $200
If you can find a guy, you can have just the fuser film replaced in your fuser unit at a cost of around $175 for parts and labor.
The most expensive route is to have a service company replace the fuser. They will charge you around $300 parts and labor.
Good Luck and Thank You for using Fixya.
Jul 07, 2010 | HP LaserJet 4250n Printer
The black print jobs have a shadow about 3 inches down the page
I had replaced the fuser - no improvement. I removed the fuser, imaging unit & transfer roller. CAREFULLY using a vacuum cleaner I cleaned all units and the internals of the printer, rotating the roller on the imaging unit to clean all parts. (Warning Place Imaging unit on paper as toner escapes) After a few test prints the page cleared and duplicate ghosting cleared.
Apr 07, 2010 | Xerox Phaser 6360 Laser Printer
Oct 08, 2008 | Xerox Phaser 8560MFP Laser Printer
Shadows on prints
Hi, The problem your having sounds like a Fuser . The Fuser will cause printed text to give a ghosting look down the page were it repeats itself.
Nov 30, 2007 | HP Color LaserJet 2600n Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 6125 Laser Printer Logo
46 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
