Question about Epson Perfection V600 Photo - flatbed scanner
Clean underside of glass on Epson V600 scanner
SOURCE: Underside of document table needs cleaning
Hey! I've just find the solution. The only thing you need is a multi-screwdriver to take out the two screws sitted on the backside, then use a screwdriver with a plain point to separate the dark grey plastic piece from the light grey one (use a few toothpicks to keep every flap open). When you get all the flaps open just pull the light grey piece (the bottom one) and separate the dark one with the lid and the glass. Now you can clean conscientiounly the glass. Be sure to put in its right place the back little plastic piece that covers the power connector before closing your scanner when it's clean. Close it introducing the front side before and pressing over every flap. Work done! enjoy you Epson scanner!
I apologize for my english, maybe I've used any unconvenient word, but I think you'll understand it.
Regards,
Jordi (Terrassa, Spain)
Posted on Sep 19, 2008
SOURCE: How do I clean the inside of the glass on the Epson 3490 Scanner?
Disconnect and remove the lid. Remove the two screws on the back of the base. Then use a screwdriver or flat blade to slightly open the back seam. Beginning at the back, run a blade up inside the upper part of the side seam. You will need to release three catches on each side. Once the sides are loose, raise the back of the top, while pushing forward, and the two snap catches at the front will release. The top then lifts off and you can clean the glass. Reassemble in reverse order.
Posted on Nov 17, 2009
SOURCE: cleaning underside of glass on 610 scanner
Ok. Found this question on-line as I also wanted to know the answer. Couldnt find an answer so I just decided to have a go myself. It was quite easy really. Lift the lid upwards and gently push it backwards from the hinged end and it will unclip. With the scanner facing away from you, undo the only 2 screws visible at the back. Then gently lift up and push forward towards the front. You can see thru the glass 3 plasic lugs holding the front down. With a little wiggle the cover with the glass attached will come away from the slotted holes where the plastic lugs go. Clean glass an carefully replace lid in the reverse order. Pete
Posted on Dec 21, 2009
Testimonial: "Thanks. I had a go at it myself several weeks ago in the absence of instructions. The steps you describe are the same I used. They worked. Thanks."
  • 181 Answers
SOURCE: How do I clean the underside of the glass on the
Scanners are not meant to be user serviceable. This means that to clean the inside of the scanner, its better that it be brought to the manufacturer who can do this in a safe and correct manner. Believe me, it is worth doing this than ending up having a non-working scanner.
Posted on Jan 11, 2010
SOURCE: scanner glass clean
Cleaning the glass is rather simple. Take the 2 screws under the cover out. Now gently lift the top part of the scanner (some force may be needed). Then the scanner is in 2 parts and the glass can be cleaned inside and outside with a wet wipe glass cleaning pad. Dry the glass with a towel and inspect the glass with a lamp, that no cleanser remains are left. Now install the scanner in reverse order.
Posted on Feb 14, 2011
What are the approved cleaning fluids for use on the underside of the object glass?
  • Use any fluid approved for use on glasses or camera lenses. Glasses and photo lenses have coatings that should not be subjected to be acidic cleaners. Windex, for example should never be used on car window tint... who knew?!?
Feb 27, 2015 | Office Equipment & Supplies
Remove top glass from scanmaker 8700
Sir,
Please click on this lin http://www.artixscanm1.com/Cleaning_Instructions_Chassis_VI.pdf and download the manual for cleaning the glass for your scanner.
Go to page 2 and follow the instruction step by step.
Have a nice day.
Thanks
Oct 30, 2008 | Microtek ScanMaker 8700 Flatbed Scanner
How do I remove Scanner Glass to clean underside.
jast go and download service manual for 6110
http://h10032.www1.hp.com/ctg/Manual/bpd09762.pdf
. Read it. Then try to open your printer's glass.
Thank you
Jun 01, 2013 | HP Officejet J6410 All-in-one InkJet...
How do you clean the underside of hp5590 glass?
Detach the ADF assembly. Remove the 4 case screws from the scanner bottom. The case has a notch at the back that has to be unclipped to separate the top and bottom. Clean the glass underside repeatedly, I use methylated spirits on soft toilet roll. Check in the glare of the scanner light, and reassemble.
May 19, 2011 | HP Scanjet 5590 Flatbed Scanner
Cleaning underside of glass on 610 scanner glass has mildew on underside
Oct 23, 2009 | Epson Perfection 610 Flatbed Scanner
I need to clean the underside of the glass on my Canonscan Lide20
How on earth did the underside of the glass get dirty?
Ok, never mind that... in the end, it's NOT worth it. In the old days, you could have since scanners were as big as printers are today... but now they are definitely NOT designed for the consumer to service. The scanner is designed for accuracy, even if you were to get it all apart, the odds that you maintain the precision and integrity of the bulb, the track on which the bulb moves, etc, are very slim.
Suggestion... How is the printer you have holding up? If it's getting on in age, it may be a wise investment to purchase a dual scanner/printer (as long as you are spending the money).
Hope that helps :)
-- RT
Aug 29, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
How to clean the underside of a microtek 9800xl
open it up...
you can try using a vacumm on the venting bars maybe it would help abit...
good luck
Feb 12, 2009 | Microtek ScanMaker 9800XL Flatbed Scanner
HP photosmart 2710 dirty glass
hi,
no way.... u cannot clean the underside of the glass... u can clean the glass using a lint free cloth....
thanks and regards
agnel
Dec 30, 2007 | HP Photosmart 2710 All-In-One InkJet...
Epson Perfection V600 Photo - flatbed scanner Logo
496 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
