Place for washing mashine
Hi.
i have electrolux front loading washing mashine. can i put it in to the cupboard with the door? and where then air flows?
Thank you
    Sergeant:
    Champion:
  • 318 Answers
You do not need airflow for the washing machine only the dryer.
And yes you can put it inside of a cupboard or cabinetry,as long as you have water supply, and waste water discharge access
Posted on Jan 19, 2009
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
I have been putting my washing on a 40 wash and have been putting enough washing liquid in but my clothes just will not wash, i have felt the glass in the door but it doesnt get very hot, is my washing...
The hot water goes into the machine at a slower rate than the cold water does. Open the hot spigot (water valve) behind the washing machine all the way open, then open the cold spigot just enough to get the desired 'warm' temperature of the water going into the machine while the machine is filling. You may have to shut the door to allow water to flow. Remember that it takes a minute or so for hot water to reach the machine from hot water tank.
Dec 08, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How do i wash my quinny buzz seat cover
Hi I found the best way to wash it, is to fold it with the front part on outside place inside a pillowcase & put in washing machine on a gentle wash, I then dried it on my water tank in airing cupboard it came up lovely, before that I tried handwashing it & it came out terrible.
Aug 03, 2010 | Quinny Buzz Three Wheel Stroller
My electrolux ewf 1481 front loader wont spin
Open the flap, bottom right of the front panel and check the filter is clear. Most machines will not spin until they have expelled all the water. You may want to check the hose is not block and any connections to the sink if it's not on a standpipe.
Most new machines have quite sensitive out of balance detection so if it an odd load try again but add a few extra items to allow the machine to distribute the load evenly prior to spin. Hope this helps
Jul 07, 2010 | Electrolux Washing Machines
How to replace door lock electrolux washing machine
Simple enough. Pull plug out and remove top cover of machine. There is a long way and short way so ill advise short way. The latter would require taking the boot off which needs expertise putting it back. Ok open front door and with screwdriver undo 2 screws holding the inner door latch. Place you one hand in the machine and then pull latch up high enough to allow you to pull wiring off. Note the position of those wires.(important). Once off, replace in reverse order, and test.
May 23, 2010 | Electrolux EW1000i Front Load Washer
From time to time the mashine is not evacuate the water and the mashine will not start for a new load .I have to unscrew the filter,drain the water and then will wash. Is a problem with the pump? thank you...
a front loader huh, usually there is an access panel at the bottom front held on with 2 screws. remove this panel and trhere should be a trap filter that is plugged up. remove filter and clean it out, than put it back. or the water pump is going bad try the filter first.
Nov 07, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washing mashine dispalys symbol not in users manual.Where time is displayed it shows a symbol that look like a padlock.The machine does have a key symbol on side panel. Door is showing unlocked. Cannot...
Try buttons "dry" & "spin" together for a few seconds. This could be the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............
Mar 30, 2009 | Electrolux EW1000i Front Load Washer
Electrolux front loading washer - door is locked, won't unlock
I have an Electrolux front loading washer. I just got done washing a load of laundry and the door will not unlock. I tried washing it for a second time thinking maybe it would open again. No luck.
Nov 09, 2008 | Washing Machines
Washing Machines Logo
70 people viewed this question
Top Washing Machines Experts
