Question about Dell Dimension 3100 PC Desktop
Dell dimension 3100 beep codes 1-3-2
After the beep codes it will sometimes boot and sometimes not. How would I go about fixing this. Beep codes indicate improperly seated DIMM
jell587
  • 447 Answers
SOURCE: Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Posted on Feb 22, 2009
SOURCE: Beep problem Dell Dimension 4700
Beep problem update - Dell 4700. Last night started computer - cold boot. The screen had just started to light up and then went black and computer started beeping in an interrupted sequence. Fan speed increased considerably (suggesting overheat?) Shut it down and attempted two restarts with no success. This morning I unplugged all cords, opened case, pulled and reset memory cards and vacuumed inside. The computer was very clean so really don't suspect that dust was an issue. Buttoned it back up plugged in plugs and restart successfully accomplished. Have no clue why. Some square electrons, I guess.
Posted on Dec 27, 2007
  • 121 Answers
SOURCE: dell dimension 3000 memory card
if your pc is old, it may not be compatible with that amount of memory.. check to see your are buying the correct type of memory, a lot of pc's vary depending on model.. be sure to push down firmly when installing the memory stick.. hope this helps
Posted on Feb 21, 2008
antiochpc
  • 1314 Answers
SOURCE: "my computer will only beep no screen,it beeps
Hi
You likely have a bad memory module. First, try removing all the memory and putting it back in again. This is called reseating. If you still get the errors, then try removing one stick at a time and testing it with each stick (provided, of course, you have more than one stick installed). If you only have one stick installed, remove it and turn on the computer and it should beep at you as well. That memory stick will need to be replaced.
Thanks and please take a moment to rate this solution as fixya. Thank you.
Posted on Mar 14, 2009
  • 90 Answers
SOURCE: won't boot..getting 2 short beep codes..have tried memory that i know is good.
Its the problem with the memory only. the memory u get from dell will noit suite ur pc. try changing the same type and speed memory
Posted on Apr 20, 2009
Hello, I have a problem with my Dell Dimension C521. When I try to boot it up it gives 1 long and 2 short beeps! How can I fix this problem? Thank you!
1 long and 2 short beep code means your Memory (RAM) has gone bad and needs to be replaced. Your system made a Memory test and the test is a failure (bad memory during memory sizing).
Here's a guide for Beep Codes on your Dimension model: Click Here
Hope that helps you.
Aug 07, 2011 | Dell Dimension C521 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100 bleeps 6 times and wont turn on
HERE is the documentation straight from Dell. It gives the explanation of the beep codes and other diagnostic information like what the lights mean. It's the best place to start.
Jan 03, 2011 | Dell Dimension 3100 PC Desktop
When I turn the hard drive on it beeps 6 times intermittently, it goes 1beep slight pause 3beeps slight pause 2beeps, and doesn't boot up as normal. Numbers 3 and 4 on the hard drive are lighting. The...
Has anything changed since it was working last? check that first
Next -- the Beep codes indicate a hardware problem --the PC was unable to POST(Power On Self Test-)-but DELL's beep codes closest to what you described is either 1-2-video card not detected or 1-3-1-1 which is Memory (RAM) error adn the PHEONIX beep code of 1-3-2 is Memory error also-- so be sure all cards and chips are seated properly--I dont think its the hardrive --a PC can still boot and POST without a hardrive.
Dec 29, 2010 | Dell Dimension 3100 PC Desktop
I have a dell dim 2400 that will not boot. When attempting I get a beep code 1-1-2. Is it fried??
Go to the Dell website. Under Support, at the upper right corner, type in 'Dim 2400 1-1-2 beep codes. The first thing that comes up is 'Advanced Troubleshooting Dell Dimension 2400 Series". Half way down the next page under 'Beep Codes' you'll find Code 1-1-2, the cause of which is 'Microprocessor register failure.' This probably means you'll have to take your 'puter into the shop to get it repaired.
Sep 04, 2010 | Computers & Internet
High pitched beeping sound?
hi!
I'm not sure with your beep code.. but here is the list of known beep codes for dell motherboards
Beep codes Possible Causes Solution
1-2 no video card detected Reseat the video card
1-2-2-3 BIOS ROM checksum error
1-3-1-1 DRAM refresh error Reseat the memory card
1-3-1-3 Keyboard error Keyboard connector
1-3-3-1 memory card Reseat the memory card
1-3-4-1 RAM failure on line xxx Reseat the memory card
1-3-4-3 RAM failure on data bits Reseat the memory card
1-4-1-1 RAM failure on data bits Reseat the memory card
I hope it match your beep code..
Please rate this help.. thanks..
May 25, 2010 | Dell Dimension 3100 PC Desktop
Dell precision 3100 machine will not boot up
Hi there
The beep codes indicate that there is a problem with the system memory, it may have to be changed.
Thanks for using fixya!!!
Feb 02, 2009 | Dell Dimension 3100 PC Desktop
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
Wont boot correctly
Typically, a system that won't pass POST (Power On Self Test) will beep in a pattern indicating what the problem is. Here's the beep codes for Dell systems:
Beep Codes Possible Causes Corrective Action 1 - 2 No video card detected Reseat the video card 1 - 2 - 2 - 3 BIOS ROM checksum error 1 - 3 - 1 - 1 DRAM refresh error Reseat the memory modules 1 - 3 - 1 - 3 8742 Keyboard Controller error Reseat the keyboard connector 1 - 3 - 3 - 1 Memory defective or not present Reseat the memory modules 1 - 3 - 4 - 1 RAM failure on line xxx Reseat the memory modules 1 - 3 - 4 - 3 RAM failure on data bits xxx of low byte on memory bus Reseat the memory modules 1 - 4 - 1 - 1 RAM failure on data bits xxx of high byte on memory bus Reseat the memory modules
Jul 08, 2008 | Dell Dimension 4500 PC Desktop
Dell Dimension 3100 PC Desktop Logo
196 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
