Question about Ricoh Corp Aficio SP C231N Laser Printer
Ricoh aficio SP c231n prints ghosts images
My ricoh just started printing a ghost image and the paper is wrinkled
    New Friend:
  • Ricoh Expert
  • 164 Answers
Sounds like fuser is bad with wrinkling also or two different problems drum assy blade fail and fuser assy failed
Posted on Oct 15, 2014
4 Suggested Answers
  • 142 Answers
SOURCE: The Ricoh Alicio SP C410dn
You must first try to clean the paper feed roller which you will inside of the printer (bottom) when you pull out the paper tray. If this not works, then I am 100 % sure that the magnetic clutch which operates this feed roller must be replaced. I can tell you the part number for ricoh part catalog:
GX20-0014. If you don't have tech skills please don't do it by yourself because it's a hard and precision work. Call for help tech support
pifonski
Posted on Mar 02, 2011
  • 34 Answers
SOURCE: Ricoh SPC400DN Getting frequent "Press A
It sounds as if it is not picking up the paper from the tray. It might need new feed rollers. Another thing to check is the lift arms on both sides of the tray. Make sure the springs are still attached to them. There is also a little switch on the left side front of the tray that adjusts the bottom plate pressure. You can try adjusting that to see if it helps.
Posted on Mar 12, 2011
Testimonial: "Springs on left arm are attached. I adjusted plate pressure to Thick and problem seems to have gone away (paper if 20lb, so either setting was ok)"
davidmamian
  • 543 Answers
SOURCE: hello my printer keeps getting jammed, it wants to
if it is in warranty , send back , and they will solve that problem.
Posted on May 28, 2011
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
How to change feed roller on RICOH Aficio SP C231N
You would need a technician to help out with the stuff.
Ghost image ricoh 3245c
No can do, if you are referring Norton Ghost. Ghost it only for OS on computers. Printers have chips with instructions.
Here are the drivers in case you need them.
http://support.ricoh.com/bb/html/dr_ut_e/ra/model/c35_45/c35_45en.htm
Oct 25, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Hp 5550 patchy print
Most of the cases fuser assembly or supplies are causes of ghost image. If image is not properly transferring on media causes transfer roller or ETB.
Do this small exercise: Give print command, wait till paper grabs, once paper entered in cartridge area, power it off, open top & front cover, remove paper and see the print quality.Observed any ghost image what you observed? No ghost image? then problem with fuser assembly..
1.Remove fuser assembly, check any toner particles deposited on surface of fuser transfer roller or heater roller.. if found clean carefully with good cotton cloth while fuser having certain temperature,pl avoid metal & sharp objects to clean..
2. Clean paper path roller(You can observe the rollers to push the paper to reach the destination)
I hope this exercise will resolves the issue..
Jul 26, 2012 | HP Color LaserJet 5550hdn Printer
RICOH FW740 is printing with a ghost image. Can I clean it myself?
Ghost images appear on the printed page because of bad cleaning blade or improper charging of the drum unit. Ghost images appear on the next printed page if cleaning blade does not clean the drum surface. Drum/ photoconductor is very sensitive to light, so special care should taken while pulling it out. Read More here Image ghosting problem
Dec 02, 2011 | Ricoh Office Equipment & Supplies
Changed the toner cartridge and wasn't inserted correctly. I reinserted and noticed there was a lot of toner outside of the canister and now it's printing but there is a ghost print as well.How do i fix or...
The dirt just have to vacuum.
When you tell a "ghost" you refer a repetition of the image????? If so, you have to replace the fuser roller (also you should replace the thermistor, pressure roller and the cleaning roller).
I hope you have some technical training....
I hope I have helped you.
Reply any questions ok ???!!!
Feb 08, 2011 | Ricoh Aficio 3025P Black and White Copier
Ghost images of the same printing repeated down the page
Run a half test. While printing a few pages, open the cover, pull out the toner and look down at the paper. If you see the ghost images replace the toner. If you don't see the ghost images, replace the fuser.
Sep 11, 2010 | HP LaserJet 1020 Printer
Ricoh sp c410 yellow toner is offset in prints
Go into the menu that says maintence )I think) and do the color registration.
Jun 24, 2009 | Ricoh Aficio SP C410DN Laser Printer
Print quality
Ghosting can :
1-prints on the fuser roller, check if yes try cleaning it off, wait until it cools off
2-blanking lamps dirty or not working,(deletes image off the drum, before it gets ready to accept a new one)
BL mirror-(new image)
drum
3-Bad drum (although I doubt it this far in the process.)
Sep 05, 2008 | Ricoh Aficio 1013F Copier
Ricoh Corp Aficio SP C231N Laser Printer Logo
213 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
