Question about Sylvania 6626LCT 26 in. LCD Television
Please let me know that LCD monitors emit x-ray as CRT monitores ? would you please compare the exposure rate of CRTs and LCDs? Kind Regards Afsane
  • 4,234 Answers
I'm not sure what you are looking for here, but LCDs do not emit Xrays like CRTs. For that matter the most recent CRTs don't emit much either. The LCD uses a flourescent "backlight" to illuminate the Liquid Crystals. The orientation of the crystals either allows or blocks that light. That is how the LCD panel works (essentially).
Hope this helps,
Dan
Posted on Jan 19, 2009
How to find monitor radiation
LCD screens do not emit electromagnet radiation.
The CRT monitors do emit electromagnet radiation in low level BUT most of the radiation is emitted from the back of the CRT monitor.
Dec 13, 2012 | Compaq Presario 1210US Notebook
Tip
This is mostly wrong. It is true for CRT screen but LCDs are much more robust...
The discoloration problem is due to the near by magnetic field appliances like speakers which are very near to monitors ...
so what you have to do is just keep some distance to the monitor from the speakers and other magnetic appliances and then press menu button & just give degauss..
on Oct 19, 2010 | Sony SDM-HS73P 17" LCD Monitor
I feel my ASUS monitor is bright to my eyes. I checked and found the frequency of the monitor is 60Hz. I want increase the frequency of my monitor. How can I do it? I want to my eyes feel comfortable for...
On nearly all LCD monitors the frequency cannot be raised above 60 Hz. This is due to the way LCDs are displayed, which is very different than CRT monitors (on a CRT, you can select a range of refresh rates)
Mar 03, 2011 | ASUS VW224T 22 inch LCD Monitor
I have a black spot on my crt samsung monitor screen
I know some people still prefer old CRT monitors over more modern LCD monitors even today. Unfortunately Cathode Ray Tubes or CRTs aren't serviceable since they are a factory vacuum sealed unit and this probably why no-one has replied. The black dot is probably a burn mark on the inside of the CRT if it's always there. When there's a problem with the CRT itself there's nothing one can do except replace the unit and it's not worth changing the tube as it will cost much more than the monitor is worth and anyway I'd be very surprised if they even bother making these old parts any more. One can buy 17" CRT monitors as cheap as 10 pounds and larger CRT monitors for a bit more at recycling businesses like Speedie Computers near Birmingham in the UK, so if you you still want to use an old CRT monitor, replacing the whole unit is certainly the best option. There's currently still an excess of old CRT monitors that need recycling after being replaced by newer LCD monitors and recycling companies like Speedie often have literally pallet loads piled up high and they'll be only too glad to let you take one or more off their hands for next to nothing. It's better if you can find somewhere local to yourself rather than purchasing online if at all possible or you'll probably end up paying more in postage than the cost of a replacement used CRT monitor because they're fragile, heavy and bulky to transport.
Sep 18, 2010 | Computers & Internet
After using the monitor for more than 20 minutes eyes become watery and burning sensation starts. I am afraid if it causes heavy radiation. ...
CRT screens emit low levels of electromagnetic radiation, mainly from the back of the monitor. LCD a lot less emit less electromagnetic radiation. The backlight from a LCD screen is provided by a CCFL lamp, this is a very small fluro tube about 2mm in diameter compared with a 20-25mm normal fluro tube.
I do not think the LCD is the cause of your problem, I suggest you consult with an EYE specialist about your problem.
For details of electromagnetic radiation of CRT and LCD screens/TVs, please click on this link :-
http://www.lcdtvbuyingguide.com/lcdtv-crt.shtml
Sep 14, 2010 | LG Flatron L1515S 15" LCD Monitor
What are the possible disadvantages of computer monitors?
a CRT monitor, those big glass ones , that are as deep as they are wide, those ones i personally think give better picture and seem better when watching movies, because there is less tearing of the picture (when it lags behind the sound)
both LCD and CRT monitors are going to use more power when attached to a laptop than the laptops built in screen.
usually a computer monitor can be a higher resolution (more desktop real estate) than a laptop screen.
beyond that, there arent many downsides to having a monitor attached to your PC. - i guess another disadvantage of a computer monitor is that they don't float in water, they are heavy to carry , and don't fit in your pocket, however, that all also applies to the desktop computer itself.
Jul 15, 2010 | Computers & Internet
What disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Can my LCD monitor damage if I place multimedia speakers near it?
No this happens in the machines that with CRT, LCD is free from this thingy as LCDs don't use magnetics to steer the non-existant electron beam.
The only danger might be if they produce a large alternating field, as this could induce currents in nearby wiring, but this an't gona happen.
Regards, Waqar.
Sep 23, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
I have a hp pavilion mx704 17" CRT monitor which starts flickering and blacks out every 5mins or less than that, i have to hit it with the right amount of force on the sides or on the back to make the...
i have experienced this problem before with a nec crt monitor and its permanent and can not be fixed with out having to flush money into it. personally i wold not deal with it. in this day in age era LCD monitors are almost dirt cheap plus if you put it this way which is more valuble to you your health? or your monitor. the reason asking this is because crt monitors outputs a high dose of radiation. partly the reason to produce lcd monitors they dont disapate heat like crts and they dont have all that radiation build up like crt monitors hold. so if you would rather have your health then get a lcd for sure.
Jan 22, 2009 | HP Pavilion MX70 17" CRT Monitor
Installation of Fedora core 6 on Amd+ASUS
Your computer is booting up in a video mode or refresh rate that your monitor cannot support. Not sure how you would go about changing it without reinstalling Fedora or doing it from the command line.
If you're using an LCD, try an old CRT monitor, may be able to use the mode you selected. LCDs can usually only support 60Hz modes.
Jan 10, 2008 | Computers & Internet
Sylvania 6626LCT 26 in. LCD Television Logo
136 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
