Question about Dell 1600n All-In-One Laser Printer
Freakels on Print
On the Dell 1600n recently, my prints and copies are coming out with freakels on the page. Ive tried giving it a quick clean on the maintainance option with no luck. Is a problem with the printer or the cartridge ? Any ideas
  • Javeed Baig Aug 17, 2007
    I changed the cartridge and all is working fine. Many Thanks
    Sergeant:
  • 390 Answers
Poor print qaulity nine times out of ten usually means ink is coming out incorrectly or leaking where it shouldn't. Do you fill your own cartridges? I would try doing a manual clean with proper ce\leaning solution. Using cotton buds and solution, thoroughly clean deep inside printer carriages where ink goes in (cartridge). Also use a non scented baby wipe folded into a pad and wipe gold printhead (only the one that ink comes out of) and press a fresh one firmly on after this, check to see if ink leaves correct bright colours, in bold squares, and is not patchy or missing. replace cartridges and try again.
Posted on Aug 17, 2007
    Sniper:
  • 58 Answers
Cartridge. As always with print quality problems....Cartridge first.
Posted on Jun 26, 2007
SOURCE:
I have a dell p513w printer, and recently it stop printing color copies. I have replaced black and color ink, cleaned and deep cleaned pinhead.
You said the device will not "print" color copies. Have you tried to make a copy of something in color?
Recommend printing out a demo page that should show all colors listed, also do a print head alignment that would show the colors too.
Mar 16, 2014 | Dell V313w AllInOne InkJet Printer
Where do I find the "clean drum" function on my Dell 1600n laser printer?
You should never use alcohol when cleaning this printer. If you need a solvent, use a soft, lint-free cloth dampened with water. A dry lint- free cloth is better for cleaning most parts of the printer. The Clean Drum function on the Dell 1600n is accessed from the Maintenance sub-menu. You need to press Menu on the printer repeatedly until you see Maintenance on the top line of the Display. Clean Drum should be displayed on the bottom line. Press Select twice to start the cleaning. You may need to repeat this operation several times if you see that the printed page is still streaky.
I hope this helps.
Jan 08, 2014 | Dell 1600n All-In-One Laser Printer
Prints faint copies
If the print rubs off the page, this means the toner is not being fused to the page. Fused......this is done by the fuser. This would have nothing to do with light print.
The dell (1600n and 1815n /1815dn) printer drivers has a toner saver mode, which can contribute to light print.
To turn Toner Save Mode off, (Windows XP) perform the following steps:
  1. Click the Start button, click Settings, and then click Printer and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser MFP 1600n, 1815dn, and left-click Printing Preferences.
    The Dell Laser MFP 1600n, 1815dn Printing Preferences window appears.
  3. Click the Advanced button.
    The Dell Laser MFP 1600n, 1815dn Advanced Options window appears.
  4. Click to highlight Toner Save.
  5. Click the drop-down list and change it to Off and click OK.
  6. Click OK.
One thing that you mentioned in your post "it takes the printer forever to warm up". The fuser does have to reach operational temperature in order for it to fuse the toner to the page. So it is possible that you are having fuser problems, because of the time it is taking for it to warm up. Another thing that can contribute to the warm up time is not plugging the laser printer directly into a wall outlet. This would be true for any laser printer, not just a Dell laser printer. The low voltage power supply is what works the fuser, along with sensors and other motors in the printer.
Replacing the fuser and or the low voltage power supply in this model of printer is not an easy task. If using a Dell branded toner cartridge and checking the toner saver mode does not fix the issue. Then you would be looking at more expense then the machine would possibly be worth.
May 04, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Slow Printing
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Feb 23, 2009 | Dell 1600n All-In-One Laser Printer
Printer will not print. Displays no paper.
Is the page stop at the back of the tray set correctly? If you have the stop a "click" off, rather then seeing letter size, it will see universal or A4 and say no paper, because it's looking for letter size. If it is on the network, just open a browser and go to the IP address of the printer, or print out a configuration report. That will tell you what size the drawer is reading.
Jun 16, 2008 | Dell 1600n All-In-One Laser Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Printer Problem
Clean the small glass strip on the left side of the scanner. There is probably some dirt there and will only show up when using the ADF.
Nov 15, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n ADF Problem
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
Nov 12, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
93 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
