Question about Samsung Office Equipment & Supplies
SCX-4726FN+Fax+Wakeup Once unit goes into power save mode it will no longer respond/receive faxes
SOURCE: samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Posted on Mar 03, 2008
  • 31 Answers
SOURCE: How to set Ans/Fax receiving mode of SCX-4521F?
Try setting the receive mode to FAX/ANS. If you want the fax not to pickup before a phone call comes in, you should set the number of fax rings to a higher number, like "5" for instance. Set the answering machine rings less and the fax higher. The machine will usually record a message first and then detect a fax tone.
Posted on Mar 27, 2008
rhoncruz
  • 134 Answers
SOURCE: Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Posted on Dec 01, 2008
  • 3 Answers
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
Posted on Mar 11, 2009
SOURCE: scx-4521f fax not sending and not receiving
4521f printer fax receive but not print so whats your problem
so plz solve this problem
Posted on Apr 22, 2010
How do i set my fax machine to recieve and send faxes
Dear
Connect the telephone line to the LINE socket of the fax machine and a telephone receiver unit to the EXT socket of the fax machine.
To send a fax, put the document on the platen glass (face downward) or face upward in case of ADF.
press on hook dial, (here the dial tone on machines speaker)
dial the fax no. ( wait for call connection and here the fax Rx. tone)
press START.
To receive a fax two procedure can made, manual- lift a hand set of telephone receiver on incoming ring, here the TX tone(periodical beep tone) press * 9 * of the telephone receiver. In auto mode go to fax setup select ans. to ring or auto fax etc. to activate atuo reveive of fax.
Hope this may helpful.
Thanks.
Aug 11, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Sir I am using Samsung printer Mode SF-565P I received Fax , it goes into the memory received but did not print how can I print it out plz advise me
hi
you have to configure your Printer Fax just check your manual you will find the configuration how to configure fax will print direct without going in memory
Dec 22, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Fax tones heard during tel conversatio
Kindly check your incomming line connected in Line In port of machine . And change your receive mode as TEL/FAX .
Again the same will happen the probelm related to its Line Interface Unit. Change it and check, your problem must be solve.
Jul 19, 2009 | Samsung SCX-4828FN All-In-One Laser...
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Fax received goes directly into memory of the machine my mchine is samsung SCX 4521F
Good day Sir,
If you don't want other people to view your received documents, you can use Secure Receiving mode. In this mode, all of the received faxes are stored in the memory.
To turn Secure Receiving mode OFF:
  1. Press menu until "Advance Fax" appears on the top line of the display.
  2. Press the scroll button < or > until "Secure Receive" appears on the button line and press Enter.
  3. Press the scroll button < or > to display 'Off" on the bottom line and press Enter.
  4. Enter the 4-digit password and press Enter.
The mode is deactivated and the machine prints all faxes stored in memory.
5. To return to standby mode, press Stop/Clear.
Have a nice Day and God bless.
Apr 16, 2009 | Samsung SCX 4521F All-In-One Laser Printer
  2. Press <Menu>.
Receive mode
Purpose
FAX :
FAX only
FAX * :
DRPD
FAX :
Manual RX
FAX :
FAX :
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Jan 24, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
Dec 18, 2007 | Samsung SCX 4521F All-In-One Laser Printer
112 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
