Question about Acer AL1706AB LCD Monitor
Desarmar monitor acer AL1706
Quitar la tapa
  • 541 Answers
SOURCE: Acer AL1706 A monitor powers up green light is on
you have a bad power supply, it maybe fixed. you have bad back lights in the screen, usally too expensive to replace with the cost of labor. you have a bad invertor, this will start the back lights. you need to open the rear cover and look at the power supply to see if you can find a burned componet or exploded componet. if you see a bad , burned componet a local electronics repair shop usually can fix it.
Posted on Oct 28, 2009
micromend
  • 748 Answers
SOURCE: i have an acer al1706 lcd monitor. it won't turn
This is generally indicatve of bad capacitors in the circuits. Take it to a reputable repair person or check my website www.micromendllc.com
Posted on Feb 25, 2010
budmrtn
  • 11361 Answers
SOURCE: I have an acer AL1706 with a flashing power led.
First place to check will be the power supply section.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 10, 2010
budmrtn
  • 11361 Answers
SOURCE: mi monitor acer al1706, presenta
¿Has comprobado todos los pines de los conectores de vídeo? Pruebe con otro PC para asegurarse de que no es problema de la tarjeta de vídeo.
http://s807.photobucket.com/albums/yy352/budm/Acer%20AL1706/
Posted on Jan 29, 2011
Como desarmar
primero desmonta el motor de la base. luego en el motor hay tres tornillos en la parte donde entra el cable de alimentacion, quitalos. luego en el cabezal movil quitas un tornillo allen 4mm, en el vastago donde se acoplan los accesorios debes quitar una chabeta y el pin de seguridad y luego halas toda la pieza y abras quitado la tapadera de los engranajes. espero te sirva de algo la respuesta
Sep 21, 2013 | Hamilton Beach 63221 Stand Mixer
Como agregar aceite a la bomba impulsora
TE recomiendo q le saques toda la gasolina del contenedor plastico , volcando la maquina hacia atras . De esa manera le puedes quitar los 4 tornillos a la bomba pero no totalmente , cuando dichos tornillos estan flojos levanta la maquina a su posicion normal para q asi el aceite de la bomba salga solo .Despues de q el aceite este afuera de la bomba vuelca la maquina hacia atras nueva mente y con mucho cuidado quita los tornillos totalmente , asi podras quitar la cabeza de la bomba y podras limpiar las partes de su interior . Ten mucho cuidado al quitar dichas partes para q asi puedas poder todo en su respectivo lugar despues de limpiarlo . Tu siguiente paso le puedes poner el aceite nuevo 15w40 recomendado por Karcher y despues pones de nuevo la [tapa ] o cabeza con sus respectivos tornillos . Buena suerte
May 19, 2013 | Karcher 2500 PSI Pressure Washer
Como quitar lA TAPA DE LA CADENA DEL TIEMPO EN NISSAN ALTIMA 2.5 2003
Como puedo quitar la tapa de la cadena de tiempo de un Nissan Altima 2006
Jul 20, 2012 | 2002 Nissan Altima
Quero saber como dismontar uma memoria ram
desconecta la notebook de la corriente electrica pon la notebook con la pantalla hacia abajo y localiza la ranura de memoria vas a necesitar un desarmada para quitar la tapa una vez que quites la tapa veras la memoria sugeta por 2 laminas separalas con cuidado para liberarla
para inserta una memoria nueva la colocas en angulo presionas con cuidado hasta que las laminas la sugeten de nuevo
Mar 28, 2011 | Dell Inspiron E1505 Notebook
How do you remove the "Top Cover" off the InFocus
Michael,en la parte de abajo del lado dellente tiene un tornillo que tienes que quitar y tambien tienes que quitar la tapa de la parte de atras,del mismo lado donde esta el lente tienes que levantar la tapa porque tiene seguros,antes de levantar la tapa desconecta el cable que va hacia los botones de menu,source y reser para que te sea mas facil. espero que esto te ayude . Atte.Rivas.
Mar 16, 2011 | InFocus LP 130 Multimedia Projector
ERROR SCANNER 22 EN IMPRESORA HP LASERJET ML1120 MFP
REMOVE THE SOFTWARE AND FRESH INSTALL WITH THE DRIVERS CD
Dec 02, 2010 | HP LaserJet M1120 MFP All-In-One Printer
QUE DEBO HACER CUANDO ME PRESENTA EL ERROR C7990 Gracias DORIS RODRIGUEZ OSORIO
El error corresponde a "deposito de desecho lleno"; Sacas la unidad completa donde va el toner, colocas la pestilla verde donde la flecha indica cleaner, en cada lado lateral trae un tornillo en un agujero profundo, quitarlos y luego quitar las tapas pequeñas, vacias el contenido en la basura y listo.. (favor no hacerlo con ropa blanca porque queda negra)
Jun 21, 2010 | Kyocera Copystar 1820 Grayscale Copier
How do i unlock the machine? i try to open player to change cd but it says its locked
Trato de Abrir el CIBER HOME al quitar los tornillos la tapa no desliza
hacia atrás. Como se hace
Sep 12, 2009 | Kenwood DV-6050 Multi-disc DVD Player
I have a Samsung that say Transfer Belt Error
Hi
I have a utility to reset the consumables errors on this printer, but only if the component is past its lifecount. (60k for transfer belt)
Its called CLP-300_Reset_RLCv04.exe or just RLCV-04.exe (if you can find a copy)
If you need a copy, let me know and I'll find some way to get it to you.
I've used it for transfer belt reset and it works.
Dec 19, 2008 | Samsung CLP 300 Laser Printer
Acer AL1706AB LCD Monitor Logo
153 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
