Question about Magic Chef Washing Machines
Magic Chef W20HN2-Rev M, Washing Machine
Model # W20HN2-Rev M top load washing machine works well until the water drains, then the spin cycle seems to go out of control, what can I do to fix it?
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
gittos73
  • 244 Answers
SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
Posted on Sep 12, 2007
SOURCE: washing machine will not spin
MY WASHER WANT SPIN AT ALL
Posted on Nov 15, 2008
  • 1122 Answers
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Posted on Apr 24, 2009
  • 4088 Answers
SOURCE: my washing machine drains but does not spin
Look for a motor belt that is worn out and make sure that the drum turns freely (machine off).
Posted on Aug 01, 2009
The machine wash but the spin not working. so the cloth stay wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Magic Chef CAV2000AWW Top Load Washer
When the washer gets to the spin cycle it seems to stop and not pump out the water. All other cycles seem to work ok. It is a GE spacemaster 22"
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 02, 2010 | GE Spacemaker WSLP1100D Top Load Washer
น้ำ รั่ว
heatman101
Aug 30, 2010 | Magic Chef Washing Machines
Margic Chef washing machine makes loud ginding noise when agitating and on the spinning cycle.
heatman101
Aug 29, 2010 | Magic Chef CAV4000AWW Top Load Washer
When I begin a load of clothes the water will not stay in the machine. It just flows out & never fills the machine enough to begin the wash cycle.
IT SOUNDS LIKE THE DRAIN HOSE IS TOO LOW. IT SHOULD BE HIGHER THAN THE TOP OF THE TUB, OTHERWISE THE WATER WILL JUST GO DOWN THE DRAIN.
Feb 11, 2010 | Magic Chef CAV2000 Top Load Washer
MAGIC CHEF WASHER WONT SPIN OUT
underneath the washer is a pully assembly kit . remove the belt ,the c clip and replace the pully kit about $ 20.00 cost for parts.
Feb 02, 2010 | Magic Chef CAV4000AWW Top Load Washer
My washing machine drains but does not spin
Aug 01, 2009 | Magic Chef CAV2000AWW Top Load Washer
MAgic Chef top loading washer will not spin or drain
you have to open it,at the bottom of the drum it has a either clear or black plastic hose that goes to pump held together with pressure clips remove them water will flow then ,it also will flood the aerea around it,so plenty of soil to soak it up
Aug 31, 2008 | Magic Chef CAV2000 Top Load Washer
Washing Machine Won't Spin/Drain
Apparently, there is an issue with this model. Get it checked out. I did.
Jul 31, 2007 | Magic Chef CAV2005A Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
