Question about HP Compaq nc6220 Notebook
I have a problem with my smart card
When i start the laptop ..he ask for smart card...and i haft to restart him a few times befor start windows...i enter in bois and try to disable the function but is still there...and i can't boot a windows cd because i ask me for the smart card...
...if i take the batteri from the mother board ..the bios will reset?..or is a another way to resolv my problem?
  • 1 more comment
  • catallin_r Jan 21, 2009
    i have reset the bios but the problem is steel thare :(
  • Anonymous Mar 02, 2009
    I have the same problem, I was thinking about fixing mine with a size 12 boot. I am about to try flashing bios
  • Anonymous Mar 13, 2009
    I have the same problem, windows will start but cannot get through the smart card and control alrt delete will not function
    what to do?
I have hp pavilian dv6 laptop. now i have facing problem to open my laptop. i switch on laptop its showing press ESC to continue. i press ESC key but there is no response from system side. please advice me...
could be a few things. 1. you could have a bad memory stick . if you have 2 sticks of memory try removing 1 of them and restarting if it works the the stick that you took out was the bad 1 if not then replace the 1you removed and remove the other and restart again. if that dont work then could have hard drive problem. try to start off in safe mode by pressing f8 a few time when you start your laptop the go to the option same mode with command prompt. then it will tell you ab out minimal drivers and graphics card just click yes the it will as you which windows partition click on 1 because thats the default, then it will ask you for admin password if never set 1 the click enter. then it will take you to
the Windows C:\Windows\system32>chkdsk/r you will type this will start and try and fix any problems you may have. ok you can start out with those simple ones 1st
Jun 19, 2011 | HP Pavilion dv6-1030us Notebook
I have an HP Compaq nc8230 when I boot my laptop there will always insert smart card reader, I must first wait one hour then starts normally
Hi, once the computer is booted to windows successfully go to the "Device Manager" find the "Smart Card" Device and then right click on the device. Click on the "properties" and click on the "Drivers" tab. Then click "Disable" disable the Hardware. Click on "OK" and "APPLY". Restart the computer. This will resolve the issue.
It's a Weird Issue: You can try pressing the Notebook under the two "ALT" buttons(Don't press the 'ALT' buttons), this is required to be done whenever you are booting.
May 28, 2011 | HP Compaq nc8230 Notebook
I have dell vostro 1014 with windows 7. i tried to install ZoneAlaram antivirus version 9. and i t got sucessfully installed and asked whether to restart or not. i opted for restart. while restarting its...
It sounds like windows doesn't like a driver that zone alarm installed... when the PC starts, just tap on F8 a few times until the screen pops up to offer you to go into safe mode... select "Last known configuration" (i.e. the configuration that worked prior to installing zone alarm...
it should reboot and all should be well...
Check the version of Zone Alarm to ensure it is compatible with Windows 7...
Mar 10, 2011 | Dell Vostro 1014 Laptop Computer
Hi i have just got a new Pavilion DV7 only a few weeks old on boot/start up it starts then goes off several times before it starts to load windows the fan starts and the lights come on then goes off...
Run CHKDSK/F to check for errors. There may be an error on the hard drive.
Closing the lid when closing down, puts it in sleep mode and it will restart much easier but the error should be removed.
Jan 20, 2011 | HP Computers & Internet
Smart failure predicted on hard disk drive 0 is the massage
SMART or smart or S.M.A.R.T. stands for - Self-Monitoring, Analysis, and Reporting Technology or S.M.A.R.T. it is a monitoring system for computer hard drives to detect and report on various indicators of reliability, in the hope of anticipating failures. Heed the warnings. Do not ignore them.
usually means you have multiple badsectors, it can be repaired using your HD manufacturer bootable cd but usually its just a matter of time before it rolls over and dies. your best option is to image the drive with something like clonezilla or just backup your important files to a cd or dvd and buy another HD off a site like newegg.
Mar 25, 2010 | Acer Aspire 5500 5570-2609 Laptop
My acer notebook starts up with the windows logo then goes blank
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback
Mar 17, 2010 | Acer Aspire 4720 Notebook
Hi grade laptop boot problem
crashing a few times in order to boot can be caused by corrupted boot files that Windows required.
Try do a "scan for bad sectors" checkdisk (Right click C: in My Computer, click Properties. Click Tools tab and then Check Now button, tick both option boxes and it should ask to reboot for the bad sector check. 8c484d1.jpg
You can also use HDD Regenerator to fix corrupted files. Read my other posts for details.
Mar 19, 2009 | Computers & Internet
I'm locked out
What operating system are you using? If Windows XP, try booting into Safe Mode (Press the F8 key before Windows starts). You may be able to use the Administrator account. Sometimes the Admin account does not have a password associated with it. Once you get in, you can use the User Accounts Control Panel to change the password on your account (this all assumes that you are using a local profile and not a server profile). Give that a try and let me know if you have success.
Jun 03, 2008 | Acer Aspire 5100 Notebook
Smart card
Is this in Windows or a bootup of the pc? If at bootup you'll need to reset the bios (can be found in manual) , otherwise you can try a reinstall of windows with the cds you got with the pc. WARNING: if you use this you will all your data on the pc
Sep 20, 2007 | Acer TravelMate 610TXVi PC Notebook
HP Compaq nc6220 Notebook Logo
212 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
