Question about SanDisk Sansa e200 MP3 Player
Hanged when disconnected from charging
I was charging my Sansa e200 MP3 Player(2GB) with my PC. When I disconnected it restarted and shoed the refresh database menu. Then it is freezed there. After discharging(I left for oneday for discharging fully) of the baterry when i again plugged(USB) into the PC its displaying the same thing. Any Body can give me any solution. How to restore the facory setting manually?
  • Paresh Panda Jul 02, 2007
    It happened same with me. Then I switched off the player by pressing power off button for 5-8 secs. Then I pressed rec button with the hold key in lock position, at the same time i pressed the power on button and came into recovery mode. Then I connected it to MyPc and recovered using sansa recovery tool available in ScanDisk site. After that its working fine.............
    -Paresh
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
My sansa e250 keeps shutting down
switch the usb mode which ever one is highlighted first chose the other and then it will stop refreshing
Feb 19, 2009 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa Clip 2GB stuck on refresh after charging
download the firmware update!
I had same prob- gone after update
here is link to update:
http://www.sansa.com/support/sansa_clip/faqs
good luck
Joe
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
Sansa e200 2gb is countinously restarting
OK TRY THIS...Turn unit on and allow to completely run dead.Allow to fully charge.this should reset and no more constant reboot.Please allow to fully charge.Do not rush this process.RICHARDM69
Jan 07, 2009 | SanDisk Sansa e200 MP3 Player
Recently i encountered this Refresh Database problem, whenever i switch ON my player it shows Refresh Database, even it doesn't switch OFF. I need to remove my battery to switch off my player, i tried to...
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 18, 2008 | SanDisk Sansa e250 MP3 Player
Hanged
First, uninstall all Sansa-related software that is installed on your computer. Then, I would load the version of the software from Sandisk's website - it is more up to date than the installation CD. After installation, replug your mp3 player into the computer and try again.
Nov 24, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 2GB wont synchronize
sounds like a faulty device, return to the company!
Apr 19, 2008 | SanDisk Sansa e200 MP3 Player
Help i can't open my sansa E200
Go to the place where you bought your Sansa E200 and ask them to have the firmware reinstalled. Most mp3/mp4 players crashes its firmware when you are working on something and the battery goes down. There is nothing wrong with your gadget's harware, just a software issue.. that's all.
A Simple Thank You is Good enough
Feb 15, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e200 mp3 player -hung
Hi , can you connect to pc computer for scan anti virus clean and heal viruses.
Jan 22, 2008 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
48 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
