Question about GE Microwave Ovens
Ge jvm130k001 microwave oven won't heat
When oven turns on it makes a funny noise
MicrowaveSvc
  • 9047 Answers
SOURCE: Ge jvm1860 microwave oven
Rotu is right - it certainly could be crud on the waveguide vcover or waveguide. If not, it might very well be be a bad magnetron. My understanding is that GE had a run of bad magnetrons and/or other problems in the high voltage section, but I don't know if they publicly acknowledged it. If it's not a dirty waveguide problem, I would contact GE or an authorized servicer. If you don't have a manual, you can download it here: http://www.geappliances.com/service_and_support/literature/
Posted on Oct 18, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Sensor Error, Funny Smell and Noise
On GE models, "SENSOR ERROR" appears on the display when:
  • Using the sensor feature, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
  • Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.
If none of these conditions apply to your situation, then you may have a defective sensor and/or magnetron.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Posted on Sep 06, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
  • 4090 Answers
SOURCE: ge spacemaker microwave JVM1330BW002 making noise, food not warm
bad news I am afraid. the heart of the unit has had a coronary and needs a tech to intervene
Posted on Aug 01, 2009
  • 18 Answers
SOURCE: GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Posted on Nov 21, 2009
This is very likely a faulty Magnetron especially as there is not heat. To repair this would mean replacing the Magnetron which is a fairly standard repair for a Microwave oven
Nov 26, 2012 | Microwave Ovens
Microwave will not heat and makes a funny noise
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 07, 2011 | GE Spacemaker JVM1540 Microwave Oven
GE jvm1631wb003 not heating has a funny machine smell
Most likely the magnatron has gone out and it runs around 90 bucks. If something is funny smelling then by all means don't use it unless you want a fire. If it were me I would replace the oven instead of throwing money nto a repair on a used microvave, they simply don't last as long as they used to. It won't hurt to take the cover off and inspect it for burnt wires that may have grounded out, if none found I would replace the unit.
Jul 01, 2011 | GE Microwave Ovens
JVM2070CH001 GE Microwave. When operating makes a very loud humm noise and does not heat.
heatman101 '
May 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating and making a funny noise. Does this mean go get a new one or can it be fixed?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 20, 2010 | GE Advantium 120 Convection/Microwave Oven
GE space maker JVM1640. Does not heat food.
with out a proper diagnosis, i would have to believe your magnetron is gone
Oct 03, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating
If the maggie went it's very plasible that it took out the Cap and/or HV diode with it.
Nov 21, 2007 | GE JEB1095 Convection/Microwave Oven
Microwave Ovens Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
