Question about HTC Cell Phones
Htc merge stuck on the hboot screen - HTC Cell Phones
4 Suggested Answers
  • 3278 Answers
SOURCE: My HTC Inspire is stuck
Hello.
Give this a try from HTC Support:
Power the the phone off
Plug it in to the computer and power on. Should boot into recovery.
Reflash the ROM.
Let the phone update.
If still a problem, hold the vol down when its plugged in and then turn it on and it should boot into recovery.
Hope this helps.
Posted on Jul 18, 2011
SOURCE: htc inspire stuck on HBOOT
my phone is stuck on hboot screen and i cant go up and down on the screen by pressing the vol button
Posted on Jul 31, 2011
vladmototole
  • 226 Answers
SOURCE: htc inspire is stuck on white htc screen. When i go into hboot and select recovery or factory reset, nothing happens.
What happened before the white screen problem?
Posted on May 21, 2012
My htc merge is just stucked on blank htc when i turn it on please help me
are you able to get into recovery mode?
With the phone turned off, Hold the 'Volume Down' button and the power button until HTC logo appears and 'Entering Recovery Mode' appears at the top in pink.
If you can access recovery then it could be possible to reset/reinstall android OS
Dec 11, 2014 | HTC Merge Smartphone
My metro pcs htc wildfire s is frozen on the unlock screen
try hard resetMaster reset using hardware buttons: HTC Wildfire SVERSION 4 Created on: 15-Aug-2011 09:21 by tmo_brian - Last Modified: 07-Mar-2012 16:29 by tmo_josh_m
To perform a hard reset using the hardware keys, follow these steps:
  • Note: A hard reset restores the original factory settings and erases content, including downloaded ringtones, images, programs, and contacts stored in the internal memory. This feature allows for resetting of sound profiles, display settings, and phone or memory card settings. However, if you want to try resetting some factory settings without losing any data, then clear system cache before a master reset.
  1. Back up all necessary data and synchronize files. See: Prepare for a master reset and back up data on Android
  2. If the phone is plugged into the charger or USB cable, unplug it.
  3. Remove the battery.
    • Important: Removing the battery is required. Turning off the phone with the Power key does not work, because of the Fast Boot feature.
  4. Re-insert the battery.
  5. Press and hold both the Volume Down key and the Power key. Do not release the volume key, continue on to step 6.
  6. Release the Volume Down key when the three Android images appear on the bottom of the screen. The following options display:
    • FASTBOOT
    • RECOVERY
    • CLEAR STORAGE
    • SIMLOCK
      • Note: If you are stuck on a screen that says 'HBOOT' and 'FASTBOOT' without any other options to choose from, it means you have pressed the Back button. To get to the regular options, press either the Power key on HBOOT or the Back button.
  7. Press the Volume Down key twice to select CLEAR STORAGE.
  8. Press the Power key to initiate the master reset.
  9. Press the Volume Up key to confirm Delete all user data.
  10. Wait as the device clears the user data then restarts.
DOC-25626
Aug 30, 2012 | HTC Wildfire S White Metro Pcs Android...
Htc wildfire stuck on boot screen
Hi
Try hard resetting the phone.Here's a video tutorial on how to go about it.
Hope it helps.
Feb 21, 2012 | HTC Wildfire Cell Phone
I place a four diget code on my phone and locked for the screen and forgot the code
remove and reinsert the battery, press and hold the volume down then press and hold power, you should be in hboot mode, press power once, you should see factory reset among the options down, scroll to it and press power. Note: all data will be lost.
Nov 11, 2011 | HTC HD7 Cell Phone
Htc sense smart phone....have a white screen with 3 of the little green guys at the bottom...at the top of the page it says HBOOT and below that it says FASTBOOT recovery clear storage and simlock...I have...
hi free_b_73 this sounds like your phone is doing a hard reset on it. Right now phone is doing what is call a hard reset. The our problem is that the phone has not finish yet. GO to hboot and see if that finishes. the phone should go come on all the way now. Next your going to have to reactivate the phone Set the phone up again. after you get the sim going I would get your gmail back on the phone this should reinstall your contacts and apps on the phone. this should help let me know if this works.
Sep 13, 2011 | HTC Touch P3450 Smartphone
Htc inspire stuck on HBOOT screen
Jun 21, 2011 | Cell Phones
I tried to root my HTC evo Comes up wrong image or no image Found then is comes up update Failed newer version
what is your hboot version ?? is it 1.02 0.92 0.88 0.83 need more info what android ver you running 2.1 2.2 is it all factory as of now your hboot version and your recvoery version 2e or 3e recovery lmk so i can help thaksk
May 09, 2011 | HTC Cell Phones
Cell Phones Logo
32 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
