I am using Jvc Rx5042s, having a problem it permanently displays "Overload" even if the speakers are not connected and there is a "tuck" sound coming from Omron G5PA-1 switch. Your help will be highly appreciated
2 Suggested Answers
SOURCE: overload, switch off
I had the same problem, in that the receiver would automatically shut down displaying the "overload" message. I checked the 5 fuses inside, as well as ensured that the fan was working. I was using six 4ohm speakers + subwoofer. All the speakers other than the rear center channel and subwoofer were ceiling mounted in the room.
However, I decided to check the overall impediences of each speaker line to ensure that there wasn't an issue with the speakers. It turns out that the net imediances of the four corner speakers and the front center speaker were 5.7ohms because of resistance in the long lengths of speaker wire I had. However, the impediance of the rear center speaker was only 4.7ohm -- because the speaker line was much shorter.
Thus, the quick solution: ensure that all the speaker line lenghts are the same, (to ensure that the overall imediances of all the speakers are the same). Once I did that, the receiver started working beautifully -- full loudness surround sound working fantastic.
Posted on Dec 27, 2009
When I turn it on, it says Overload and then shut off
Try disconnecting your speakers. Then see if the unit displays overload. If it does, then the finals in your Amplifier have gone bad and will need service. If the unit comes on and there is no error, you most likely have a bad speaker.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Aug 18, 2010 | JVC RX-6042 Receiver
My reciever plays then cuts out
They don't overload from missing speakers. I'm curious, what buggered the one speaker?
Examine all of your speaker wires carefully to be sure no unintended contact is made between them and anything else.
Is "overload" being displayed?
“OVERLOAD” starts flashing on the display.
Speakers are overloaded because of high volume.
1. Press STANDBY/ON on the front panel to turn off the receiver.
2. Stop the playback source.
3. Turn on the receiver again, and adjust the volume.
Speakers are overloaded because of short circuit of speaker terminals.
Press STANDBY/ON on the front panel, then check the speaker wiring.
If “OVERLOAD” does not disappear after turning on the receiver again, unplug the AC power cord, then plug it back in again.
If speaker wiring is not short-circuited, contact your dealer.
Mar 31, 2010 | JVC RX-6042 Receiver
Overload keeps flashing
Remove anything that may be sitting on top of it, and give it at least 6" of clearance all the way around it to help dissipate heat and leave it that way
permanently.
Next check that the speakers you are using have a compatible Ohm rating for the receiver.
Dec 19, 2009 | JVC RX-558V
Overload comes on after start up
disconnect all speakers to see if 'overload' goes away.if it goes away then you might have a bad speaker.If OVERLOAD is still there with no speakers connected .Then audio output circuit needs repair in unit..
Jul 30, 2009 | JVC RX-6008V Receiver
Reciever Problem
hi, its definetly an internal problem, commonly in the output section, usually its a capacitor or an transistor which is leaky or short. which causes the overload, so u will need a techinical hand to get it resolved.
Feb 12, 2008 | Audio Players & Recorders
JVC TH-M606 so many problems
Are the speakers made by JVC? Do they come factory with that unit? Is it a receiver/dvd player or is it just a dvd player?
It seems that the receiver (dvd player) doesn't have enough amps (power) to support the sound throughput being pushed to the speakers, therefore turning off the unit for blowout protection.
Dec 29, 2007 | Televison & Video
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
My jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 10, 2007 | JVC RX-6010V Receiver
JVC RX558 VBK, Crackling noise from speakers
A quick quess of mine is the following:
The OVERLOAD indicator lights up when the receiver is maxing out on the current it is sending to the speakers. My guess is there is possibly something wrong with the receiver itself, especially since the B speakers won't play. Either that, or something is broken in your speakers or you are using a set of speakers that have too low an impedance rating for your receiver.
Apr 23, 2007 | JVC RX-558V
 Grubhead
Grubhead
