Question about Brother XL-2600I
Alarm = x - axis home possition error -- Carrage move to the right of machine banging ane end of machine -
Brother PR 620
How do i repair X-Axis home position error for pr 600II
If the machine's embroidery arms have been moved under force when the machine's power is on, you may need to have the machine tune up and reset to true center. I would suggest taking it to a authorized repair shop for a good cleaning and service. In most cases for what you paid for the machine, there is included service that can come with the purchase of the machine, or in the least, a discount on mechanical services and repairs.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Mar 02, 2015 | Sewing Machines
I have a Babylock BMP8 that i have an x-axis home position error. How can I fix it without spending hundreds to take it to a technician that is hours away! Please help!
Turn off and unplug machine. Manually move hoop frame front to back and left to right.
Plug in and turn on. Motors driving hoop x and y axis should initialize. If not you must see a tech, If the frame will not move see the tech
Dec 08, 2014 | Sewing Machines
How do I fix the error on a babylock emp6 "trimming sensor error?
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf.
Oct 07, 2010 | Baby Lock Sewing Machines
My machine was working fine and during the embroidery, it suddenly stopped and said "Trimming Sensor Error". I have tried everything to no avail. It will not let me do ANYTHING. I have moved to an area...
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf..
Sep 11, 2010 | Baby Lock Sewing Machines
Brother PR-600...does anyone know if it's a major problem if it says "main motor lock"? The needle broke while sewing, and it is stuck in the down position and will only say "main motor lock" on the...
I took the case off, and was able to raise the lever, and am NOT getting the error msg anymore. However, now machine is out of time (I think) I want to fix it myself...can I?
Nov 04, 2009 | Brother Sewing Machines
I am wanting a monogramming or embroidery machine for my home business. I am looking at a Meistergram 900xl. Does anyone know anything about this machine? I know they only make embroidery machines now so I...
I would recommend looking at the PR-620 its a single head emb only machine with 6 needles and is made by brother, you can do hats and just about every thing including momgramming plus they have a great rebate going on right now
Jul 15, 2009 | Brother CS6000i Computerized Sewing...
CE-4000 brother sewing machine error
F4 means that the machine is losing a disconnect from the foot control which could mean a main pc or new foot control
Jul 15, 2009 | Singer 7462 Mechanical Sewing Machine
Brother pr 600 has x axis possition error message.
In most cases customer were emb. bags when or after you get this error message, there is a sensor under the x-axis; horizontal arm; that gets hit and breaks you can try to get a dealer to sell you the sensor and repalce it yourself its really easy, one screw on the side of the x-axis cover and it lifts and slides off and one screw for the sensor plus two flexible flat cables plug into it
May 05, 2009 | Husqvarna Designer I
Needle securing screw
My PR600II error message main rotate error. what can i do to fix it
Nov 29, 2007 | Brother Sewing Machines
Brother XL-2600I Logo
23 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
