Question about Yahoo Messenger
Messenger cannot connect
I have my new laptop and cannot connect to the yahoo messenger 9 always having a connection problem 81003004 please hepl me...
  • 54 Answers
81003004 and 81003005 are quite similar errors and increasingly common these days with Y! 9.0 being so popular. I suffered the same error and I'm finding more and more that the only similarity between people who've had this error would be that all of them had the Microsoft .NET 2.0 Framework installed. I don't know why or if this is a cause but for me this happened each time I re-installed Visual Studio which requires 2.0. On XP one of the AU downloads is 2.0 as well so anyone upgrading to XP would eventually run into this error. Mine happens to be working now, thank God, but even Y! engineers know of no fix for this problem yet. They'll instruct you to contact your device manufacturer. In the mean time if it's worth it you may consider backing up your data and keeping a log of your installed programs as I do. Use maybe a USB drive or similar memory device and label folders 1-? and in those folders place your files such as browser bookmarks, etc. Then in a notepad document just write down the line 1-? what location to put the given files in. Makes a re-install of an OS very simple. You may also try an uninstall of the .NET Framework just to see if that's your problem. :)
Posted on Jan 19, 2009
I cannot access my yahoo messenger account. it says it is locked. how to unlock?
I have installed yahoo messenger version 9. But I can not log-in. There was a error message popping up ' messenger encountered a connection problem....81003004. ple, help me to resolve this problem.
Nov 13, 2009 | Yahoo Messenger
Experiencing error 81003004 in yahoo messenger
ok first of all install an latest & updated version of antivirus and scan all the system throughly and delete all browsing history and in the temp dir
start>run>type --- %temp%
and delete all files in the folder of temp
install the latest ver of internet Explorer V8.0
and install the latest yahoo messanger from the site
\\\\i hope so it will work
Sep 18, 2009 | Yahoo Messenger
Y!im has 81003004 error
I am sure your computer has registry problems.It is very easy to repair 81003004 error. you just need 3 steps:
1: Download a registry cleaner and install it.
2: Open the registry cleaner and scan you computer for free
3: Click fix button and you done.
Download the top 81003004 error repair tool here: http://www.fixerrorfast.com/ttfix-810030… Source(s): http://www.fixerrorfast.com/ttfix-810030…
Messenger 9 for Vista users and XP users with 9, With windows new update to their FireWall, Has so many glitches. Yahoo has given up and no longer trying to fix it.http://www.ymessengerblog.com/blog/2008/… The updated Firewall will not let Messenger download correctly.And is causing 8.1 users to have major problems now. The only option they are leaving users with is reverting back to 8.0 or 7.5 these and all versions can be found here;http://www.filehippo.com/download_yahoo_… They are releasing a new version 10 (untested) as usual!
You need to remove version 9 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
error 81003004 is a connection problem,
Connection Problems;
1. Open your Internet Explorer
2. Go to Tools > Internet Options then click the Connections tab
3.Click the LAN Settings button and a new dialog box will open
4. At the new dialog box, look for the Proxy server checkbox, if this is checked, uncheck it.check connect directly to internet then click ok
5. Then your done, click OK button for the dialog boxes.
6. Try logging in to your Yahoo Messenger account.
Jul 31, 2009 | Yahoo Messenger
When logging in to yahoo messenger it always says network problem
to find out what network connection are YM can get in. Go to your preferences then check your network connection.
There is 3 connection in there:
  1. DIAL-UP
  2. LAN
  3. BROADBAND
If you have this type of connection, select it.
Then you can enter you yahoo back to normal. Good luck!
Jul 29, 2009 | Yahoo Messenger
Login error 81003004 from Yahoo Messenger
Change your messenger connection settings. I had to check "Connect via a proxy server " in order to sing in.
Goto Connection  Prefrences and use a http proxy.
thank you
Jun 02, 2009 | Yahoo Messenger
Are you behind a firewall (like one in schools) or using proxy??
If so, see any options are available to change the connection settings in yahoo messenger before connecting.
Whi sing in get the message ecountered a conection problem . network connection and the click try again {81003004} X(((((((((
Messenger 9 for Vista users and XP users with 9, With windows newupdate to their FireWall, Has so many glitches. Yahoo has given up andno longer trying to fix it. http://www.ymessengerblog.com/blog/2008/...The updated Firewall will not let Messenger download correctly.And iscausing 8.1 users to have major problems now. The only option they areleaving users with is reverting back to 8.0 or 7.5 these and allversions can be found here;http://www.filehippo.com/download_yahoo_... They are releasing a new version 10 (untested) as usual!
You need to remove version 9 1st to get another version to work. Toremove Messenger version Use Unwise located middle of page of MessengerFolder.. Your contacts are stored online But if you want to save yourold messages archives,they are saved on your PC in the messenger fileyou are about to delete.Go here and copy them to a new folder
4. At the new dialog box, look for the Proxy server checkbox, if thisis checked, uncheck it.check connect directly to internet then click ok
This person asked same Q.
Asker's Rating: Asker's Comment: Thanks..but I already uninstalled thenew version and went back to 8.1 and it seems to be working just fine. It was always logging on and off and bogging mycomputer down.
Mar 12, 2009 | Yahoo Messenger
Messenger problem
click the "messenger" menu and select "connection preferences" Select "Firewall with no proxies" click "Apply" you should see a message asking you to sign in again click "oK"
info found in yahoo help here is the link
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/messenger/mstanoconnect.html
Feb 26, 2009 | Yahoo Messenger
81003004
Go open Internet Explorer and go in the File menu and uncheck at the bottom the Work Offline option. Then go to a site using IE. Close IE. Open Yahoo Messenger and log in.
Nov 13, 2008 | Yahoo Messenger
Yahoo Messenger Logo
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
