Question about Motorola Mobility RAZR V3
Motorola v3x i just bought a brand new v3x... and when i tried operating it , none of the keys except the on/off key , it also does not prompt for any password ..... i have been unable to make calls/sms etc. but have been receiving calls ... but unable to retrieve any sms because of the problem . i even tried putting in default unlock password but it does not work ????? can anyone help me please ???????????
  • Anonymous Jul 10, 2007
    thanks for answering , i tried putting the last 4 digits but it does not work .....do u have any idea about what is a flex file....i read about a solution saying that it either a faulty flex cable or a flex file ...how can i fix it ??????
    Problem Solver:
  • 8 Answers
Have you tried using the last 4 digits of your phone number as the unlock code? Some companies use that,
Posted on Jul 10, 2007
  • 63 Answers
Hi There, If this phone is brand new it is faulty and should be returned to seller. This problem usualyy occurs when u have a faulty flex cable either on the screen or the entire keypad assembly. One of these would need to be replaced by a repair tech for v3 phones.Hope this helps. Sam !
Posted on Jul 01, 2007
As I posted elsewhere in this site, my husband had the same problem that kinni is having; he could answer his calls by flipping the phone open but could not dial any number (in fact, only the on/off key was working). The solution was rather simple (and was found in Motorola's FAQs): the phone's keypad was locked (apparently by mistake); the fix: "To lock and unlock your keypad press Menu then * (Star)". Hope this helps.
Posted on Jul 11, 2007
SOURCE:
How can reset my motrola razer v3x without secret code plese help me
Hello, You can perform a master reset to dissolve any glitches, bugs or other complications you experience with a Motorola Razr V3x. According to the device's user guide, a master reset will reset all options in the phone, with the exception of the "unlock code, security code and lifetime timer." Back up any data, pictures, or contacts you wish to keep before performing a master reset on the Motorola Razr V3x
1 Navigate to the "Settings" menu using the directional arrows. Click the "Setting" option with the "Center" key on the phone. 2 Press the "Center" key to choose "Initial Setup" from the Settings menu. 3 Press the "Center" key on the keypad to select the "Master Reset" option from the Initial Setup page. Thank you for using Fixya
Dec 28, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Phone is locked up noe of the keys work
remove the battery and let the phone sit for a few minutes and put the battery back in.
make sure your battery is charged and working to potential.
if nothing helps, buy a new battery and see if that works.
often the battery is the cause of mobile phone problems.
Jun 02, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola V3x
Try bootloader mode. Hold down the * and # key at the same time, then press the power key. (3 keys all together). You should get a bootloader menu. If you do, your phone can be saved. If not...
Apr 15, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Can't even turn the stupid thing on. Turns itself off when I do.
i think that's really the problem with motorola V3x coz i hav d same problem here in saudi arabia where i bought mine. i'm thinking of going back to nokia again. motorola sucks..
Apr 10, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Only the End key works
download the set of programs from that link i sent you, if u hav installed drivers for ur v3 as yet, jus plug in the cable n folow the prompts n select the folder called p2k drivers, afer that restart ur pc, install rds lite 2.4 n plug ur fone back in n browse for the small in the the key pad folder n flash ur fone... that shud fix ur keypad issue
http://www.4shared.com/file/40625107/d1513354/key_pad_fix.html
Mar 12, 2008 | Motorola Mobility RAZR V3
My mobile stay off even with a new battery
i am having the same problem with my phone. after using a tester it seems that the board itself is faulty. i have tried a new battery, charger and still no luck... current seems to not be flowing to certain transitors. Fuck you motorola
Jan 16, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Path key #1234 not working
The Motorola krazer phone is not on the compatibility list. The only Motorola RAZRs on the list are the V3, V3i, V3m, and V3x. Check the outdated list at http://www.kenwood.com/bt/bt100/
Nov 24, 2007 | Kenwood KCA-BT100 Wireless Headset
V3x trouble
My guess here is that u probably got a bad deal.This problem usually stems from a faulty flex cable or a bad screen connection.You need to return this phone from where ever it came. If the phone is new u shouldn't have this problem.Thanks !
Jun 26, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
169 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
