Question about Kenmore Elite 45986 Front Load Washer
Kenmore elite He4t washer making loud noise during spin
There is a clanking/ bumping sound during spin, it sounds horrible..now even starting to clunk as it normally spins. What is causing this? The machine is 7 years old so obviously don't want to invest too much to fix it.
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
antiochpc
  • 1314 Answers
SOURCE: Loud noise when draining and spinning
It sounds like it has something to do with the pump which can be located in the direction of the noise. It could be something as simple as the belt wearing out or even just the pump came loose off of its mounts. Worst case scenario would be a new pump but it honestly sounds like something a little less intrusive. I know I had one that I had to hold down with a bungee cord because the mount had broken off of it.
Posted on Jun 13, 2007
  • 6 Answers
SOURCE: Clanking noise during spin cycle
I was told by 3 technicians that my washer had shot bearings and this is a common problem for the Kenmore Elite Front loader.
Sears knows it and will not do anything about it except try to sell you a new washer since it costs $800 to replace the unit with the bearings.
Posted on Feb 13, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
Loud noise during the spin cycle
Did you have an oil leak at the bottom of the washer? If yes, chances are your transmission oil leaked and your transmission needs changing or repairing.
Jan 15, 2014 | Kenmore Washing Machines
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
Noise during spin after changing clutch / kenmore elite washer
The clutch is likely failed again - or the coupling this time.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Clicking sound.....
must likely something in between drum & basket or rear bearing going bad.call sears ask for service smart agreement it will cover rear shell with bearing &basket in warranty
Nov 13, 2008 | Kenmore Elite 45986 Front Load Washer
Makes a very loud noise on spin cycle. Seems to worsen with larger loads.
sounds like a rear bearing gone bad , not exaectly a doit yourselfer. pretty costly as well id call sears, for possible part warr. and how much theyd charge to replace the rear bearing?
Oct 31, 2008 | Kenmore Elite 45986 Front Load Washer
Jan 02, 2008 | Kenmore Elite 45986 Front Load Washer
Spin
What kind of noise was it making. Squeaking? Clanking/clunking? Jet engine loud?
Nov 13, 2006 | Zanussi WJS1397W Front Load Washer / Dryer
Jun 29, 2006 | Kenmore 43042 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
287 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
