Question about Dell PowerEdge 1600SC Server
Our 1600sc dell server is beeping continuosly.
Two amoung its hard disc are out of order , even if you pull out those two, the remaining hard disc in place server continue to beep . Please help me to solve this prolem. Thank you.
  • 2 more comments
  • abetvz Jan 20, 2009
    The system does not start, three hard disc light green two are lightinig amber (like yellow) .Red 6 light in the back card can be seen once I remove the cover. Beep sequence like beep - beep - beep.
  • kwetei Feb 24, 2009
    i have three hard drives two lights are green one is amber and is beeping continuesly but the system is working fine
  • jeff785 Apr 24, 2009
    Beeps at startup. No screen display. Not sure how to restart using CD drive without the monitor. Tried holding te space bar down at startup and then the "C" key. Also tried hitting the F8, F10 & F12. Only beeps.
  • Cisf May 11, 2010
    give more details... !! is the system starting ? who is beeping and in what pattern ...
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
Check the PowerEdge Raid Controller for parity problems. Sounds like the status on the physical volumes participating in a RAID array has been degraded.
Loud beeping from a drive is usually an indication that an invalid drive array member has resulted in a degraded logical volume.
If you were counting correctly, you had at least three drives - most likely participating in a RAID-5 setup. The array might have been rebuilt with one bad drive. But it sounds like you've got two corrupt physical volumes in the array. And that's not good.
Hope you've got a backup!
Posted on Feb 03, 2009
Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
Aug 01, 2013 | Dell PowerEdge 1600SC Server
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
When powering up a Poweredge 1600sc i get 6 error beeps,the order is 1-3-2
It states 1-3-2 = No memory installed
Remove and reset the memory modules (see "Memory Modules"). If the problem persists, replace the system board (see "System Board"). Good Luck
Jan 29, 2010 | Dell PowerEdge 1600SC Server
PowerEdge 1600SC long beep and hang
check the Cmos battery. or levae pluged in over night and then check setup setting you battery went dead
Oct 12, 2009 | Dell PowerEdge 1600SC Server
New hard drive won't go online on our Dell RAID server.
This needs to be reconfigured again. My suggestion is to call DELL again so that things happen they can still able to do the replacement of the hard drive.
Oct 06, 2009 | Dell PowerEdge 1600SC Server
Hard disc Problem for server (powerEdge 1600SC)
Hi , I suppose its a issue with the RAM , Kindly check re-inserting the RAM on the server and try booting the system
Jan 14, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server occasionally beeps when running
Check out this site:
http://bioscentral.com/postcodes/dellbios.htm
Write down the exact number of beeps and how long they last to find what the error means. The are call BIOS post codes and they resemble Morse Code. (ie. one long, 3 short, 2 long = RAM issue) Good luck!!
Sep 26, 2008 | Dell PowerEdge 1600SC Server
How to install win2003 server freshly on dell power edge 1600sc?
You'll need to load the SCSI hard drive controller driver.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PWE_PNT_XEO_1600SC&os=WNET&osl=en&catid=&impid=
Aug 06, 2008 | Dell PowerEdge 1600SC Server
No Video Signal on 1600sc
Disconnect from the network and all other accessories, and power up the system, this might be due to a faulty device attached to the system, eg: when you connect a usb faulty device the boot takes very long time, sometime it does not boot up.
Dec 30, 2007 | Dell PowerEdge 1600SC Server
Dell PowerEdge 1600SC Server Logo
1,994 people viewed this question
Alun Cox
