Question about HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m...
Trouble with HP Business InkJet 1000
Hello!
My printer HP Business InkJet 1000 don't print anymore and the message is "some covers are open", but I checked and this is not true.
What should I do?
  • 1 more comment
  • loubielu Feb 01, 2009
    Same here. As soon as printer is switched on, power light flashes and resume light is on. Troubleshooter suggests "cover may be open" but they are not. Tried unplugging, reinstalling etc but as soon as I power up, the same lights are on.
  • Anonymous Feb 26, 2009
    i have the same Problem. Please help!!
  • visacan May 04, 2009
    "Hy! My printer HP Business InkJet 1000 don't print anymore and the message is "some covers are open", but I checked and this is not true. What should I do?
    Thanks.
Ur check all the sensor one bye one indivisual in dislpay scareen error code are different .mpost probablity this error front cover.
Posted on Jan 19, 2009
Hp Business inkjet 1000 wont stop printing garbage - a bit on lots of paper. It ran out of black ink - now replaced - but now wont stop printing .... Have tried unplugging power and usb. turned...
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Thanks
Till next time!
damnor01
Apr 13, 2011 | HP Business Inkjet 1000 Printer
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
In hp business inkjet 1000 1st page comes blank & then its printing from 2nd page in vista i am facing this problem.
kindly re install the printer driver it will fix the problem.
Have a nice day and do not forget to rate please...!
Feb 02, 2010 | HP Business Inkjet 1000 - Printer - colour...
How can i set only black print in hp bussiness inkjet 1000 printer?
give print ... select your printer .... then go to preference it will open another window ...then go to .color tab ....select print in gray scale ......
Dec 04, 2009 | HP Business Inkjet 1000 - Printer - colour...
Printer says "out of black ink", I replaced, still won't print.
are you sure it is a fresh cartridge? or a refilled one? because if its a refilled one it is normal that it will show that message "low on ink" but you can continue printing if your sure that it is properly refilled
Sep 06, 2009 | HP Business Inkjet 1100dtn Printer
SORRY PRINTER LOSS
I have this problem too and I have found that opening the covers and closing them sharply often helps (occasionally I also have to lift the front of the printer a cm or two (say one inch) and drop it. Usually seems to work as a temporary fix at least.
I suspect a sensor is sticking somewhere.
Apr 02, 2009 | HP Business Inkjet 1000 - Printer - colour...
Print head error message
reset it in window printing menu. perhaps it works.
Dec 03, 2008 | HP Business InkJet 2800 Printer
HP BUSINESS COLOUR INKJET 1000
Does it go through the motions but no ink is getting to the paper? Does it stop part way? I need to know more details as to what it's doing or not doing, please. Thanks.
Sep 14, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP HP Business Inkjet 1000
If the printer is new, then maybe the printer catridge nozzle seals have not been removed and so the catridges are not being detected.
If it has been working before and then the problem starts, look at which light is blinking  because the paper and catridge lights are different. So check wich light is on and get to me for further instructions.
thnx
Jul 31, 2008 | HP Business Inkjet 1000 - Printer - colour...
HP Business Inkjet 1000 - Printer - colour - ink-jet - Legal - 1200 dpi x 1200 dpi - up to 23 ppm (m... Logo
661 people viewed this question
Ben Johnson
