Question about Refrigerators
Lg model LRTN18320WW water infridge compartment
WATER KEEPS LEAKING IN THE FRIDGE COMPARTMENT.DONT KNOW WHERE ITS COMING FROM.TAKES A DAY OR SO AND EVERYTHING IS WET
5 Suggested Answers
  • 113 Answers
SOURCE: fridge has water in it which freezes into sheets.
see if there is a drain line going up the back if there is you should be able to take if loose to see if its stopped up
Posted on Apr 24, 2009
mgprice
  • 744 Answers
SOURCE: My fridge has water pooling on the top shelf
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the Freezer is because the water has been leaking into the freezer instead of running into the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike.
Posted on Aug 14, 2009
Testimonial: "This gave us an idea of what to do. The drain tube was blocked with some plastic lumps that must have come from the factory in our 3 month old fridge."
  • 4 Answers
SOURCE: LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Posted on Jan 16, 2011
aviral_srms
  • 1216 Answers
SOURCE: my lg fridge has just
The defrost drain is frozen, you need to take the cover off inside the freezer and there will be a drain hole probably coverd with ice, you will need to pop most of the ice out first then I use a turkey baster and a tub of hot water. Squirt the hot water in the hole over and over again untill it drains. Then just wipe everything down.
Posted on Aug 06, 2011
No water coming out
pls be more specific when you press the lever do you hear a click from behind the fridge? can you hear water flowing ? do you see any puddles of water outside the fridge or inside the refrigerator compartment not the freezer compartment?
Dec 05, 2011 | LG LSC26905TT Side by Side Refrigerator
Water shoots out of the grill at the top of the fridge compartment,as if its coming from the freezer compartment?Tried turning it off for 2 days,but after a day has started doing it again..do i need to set...
First how old is this unit? sounds like the water line from the filter to the ice maker is the problem, even if your model does not have an ice maker their is still that water line running to that area.
Feb 03, 2018 | Whirlpool GR2FHMXV Top Freezer...
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
My LG Model LRTN18320WW is leaking water inside frig. on bottom below produce drawer. has occurred since summer. what is solution?
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
Oct 05, 2010 | LG LRTP1231W Top Freezer Refrigerator
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Our roper fridge is leaking water onto the bottom shelf and into the bottom drawer area where it puddles. After a few days it is enough water to saturate 2 kitchen towels. Otherwise the fridge works...
Good day,
Sounds as if the drain in the freezer compartment is iced up.
Remove the rear panel in the freezer compartment, and check for ice blocking the drain hole. If so melt out with hot water (no heat such as a hair dryer).
Depending on your style,the defrost water runs from there into the top of the fresh food compartment, out a fitting to the back of the machine and down into the drain pan.
The blockage is there somewhere.
Service techs use compressed air to blow the drain system clean, once all ice is melted.
If you have no access to a device like that, a standard tire pump with a 1/4" stub piece of tubing makes a good substitute.
Be patient. Do not force air if any ice still exists. May cause damage to connected fittings.
You'll know when you get it right. Water, when poured on the cooling coil will run thru the drain and wind up in the drain pan.
Mar 02, 2010 | Refrigerators
Fridge has water in it which freezes into sheets.
Apr 24, 2009 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Apr 08, 2009 | LG Refrigerators
Bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
Jul 27, 2008 | Bosch Refrigerators
Water and ice in fridge leaking on floor.
you have to defrost the freezer it will take almost a day byitself,but you can speed it up with a hair blower pointed inside the freezer toward the back at the bottom,unplug your fridge and hair blower on low you dont want to melt the styrofoam,put 2 bowls in you fridge top shelf towards the back to catch watr falling from the vents,when you see water come into the pan under the fridge your all set ,clean up water and plug fridge back in,its the drain hose is blocked with ice
Jul 08, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
