Question about Mitsubishi Televison & Video
Mitsubishi lt 46153 wont update firmare
No sound from right speakers or woofer. TV wont take the updated software from usb.
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: looking for the owners guide
You can get the manual on the link below.
http://www.mitsubishi-tv.com/pdf/151_153_OG.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Oct 01, 2010
  • 476 Answers
SOURCE: software update lcd tv
The Philips 32PFL5522D does support firmware upgrades.
Only the digital board can be updated by the user. This is done by downloading the firmware on to a memory card (CF) and inserting into a PCMCIA adaptor. This is then inserted into the CI slot at the back of the TV.
The main TV would have to be updated by a Philips service agent using a COMPAIR device.
However, I don't think the problem you describe is to do with firmware.
You could try altering the following settings:
  • Contrast - 65
  • Sharpness - 2
  • Contrast Plus - OFF
  • NR - ON
  • Colour - approx 50
If this doesn't help, then the problem is most likely caused by a faulty lead between the LCD panel and driver board. This is a common problem with this model, but should not be an expensive repair.
Posted on May 08, 2008
  • 3 Answers
SOURCE: I have a Mitsubishi LT46265. My TV downloaded a
Hold the power button on the side of the TV (not the remote) for 10 seconds or so to force a reboot. Otherwise, unplug it for an hour.
-Mr_E
Posted on Feb 06, 2011
SOURCE: I need the USB firmware
Unplug TV, Plug back in. Hold menu and -vol buttons. Push power button and release it. keep holding the 2 buttons for 5 sec. release both button and TV should come on.
Posted on Sep 18, 2012
I have a 40 inch Mitsubishi Lt - 40151 TV. The sound stopped working need some help getting sound going. Will a software update fix this problem?
Problem can be intermittent. In most instances, normal operation can be restored by installing a software update available on-line to the public at Support Mitsubishi TV under the "Support" tab. If this does not correct your problem, double check your setting and make sure the speakers were not turned off. If you are still having problems then you will need to replace the main board, or the pre amp board. Part# 938P103010. I hope this helps.
Feb 15, 2016 | Mitsubishi Televison & Video
Hello, I have a Mitsubishi LT-46151. When I power the TV ON I'm getting a blue screen and the GREEN power light is flashing. The blue screen continues to show and then the GREEN flashing power light
Hey it sounds like u have did everything, so check and make sure u downloaded the right firmware on a good USB drive such as a 4GB and make sure format it with Fat32 before u download. Have seen that before with jump drive device and follow directions from Mfg website. If does not work then the CPU or Eprom has been corrupted and main board needs replacing.
Dec 08, 2014 | Mitsubishi LT-40148 40 in. LCD TV
What if you turn TV off when trying to get update done with USB?
You either have a TV that doesn't work anymore or you can try the update again.
Aug 27, 2014 | Mitsubishi LT-52151 52 in. LCD HDTV
Mitsubishi WD-60638 firmware
Make sure software was in top menu in USB stick. Not ib a folder. Try reset buttons on front of TV. Could be bad e2p module. (boot firmware.)
Mar 30, 2014 | Mitsubishi WD-60638 DLP TV
The speakers are making a crackling noise that is not effected by the volume
Check the speakers first. If the voice coil of the speaker has any fault, the speaker should be replaced. Connect an other speaker in place of present one, and see whether the crackling sound occurs with it too. If yes, the audio output board to your TV have the fault, and it should be replaced.
Oct 17, 2012 | Mitsubishi LT-46153 LCD TV
Mitsubishi LCD HDTV LT-40153 lost all sound... less than a year old
do nothing except reset, if in warranty call Mitsubishi.
Feb 24, 2011 | Mitsubishi LT-40153 LCD TV
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Looking for the owners guide book for Mitsubishi TV Model # LT-46153...please help!
Oct 01, 2010 | Televison & Video
I have firmare update 3.30 on my usb flash drive in the ps3/update folder I plug it into my ps3 system which is firmware update 3.15 and I go to the system update and I clicked on the update from storage...
Make sure to follow the instructions thoroughly on Sony's website. You have to have the folders just right and the update named just right. Make sure to try other USB slots also, you may have a bad USB slot.
Apr 29, 2010 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
