Question about Brother LS-1217 Mechanical Sewing Machine
The thread in the bobbin and needle keep balling up
As I'm sewing and the needle starts to go down it does one or two stitches and then completely balls up and there is a lot of thread tangled and balled up in the bobbin.
SOURCE: Thread in needle or bobbin keeps on breaking
The tread only breaks in the needle. what can i do . i don't get to sew anything . I tread the needle and get everything ready and start the machine and as quickly as that the tread is broken and the machine has not sewn at all.
Posted on Apr 07, 2009
Mongo32
  • 111 Answers
SOURCE: its like it is getting tangled in bobbin casing
loopy on bottom means upper threading or tension is wrong
Posted on Aug 23, 2009
madelinesalo
  • 59 Answers
SOURCE: i thread my bobbin right, but thread keeps getting
your machine is new, asked for assistance to timing your machine.
Posted on Mar 31, 2010
  • 1788 Answers
SOURCE: When i start to sew
There has to be a problem in your threading or your needle. You may have the needle inserted backwards, flat side has to face rear or the needle is bent. Totally unthread your machine and make sure that there are no tangles and that it feeding the right way. Watch how they show your for threading and winding the bobbin, plus threading the bobbin. Good luck, but I truly think it is in your threading.
Posted on Sep 25, 2010
HansPP
  • 2510 Answers
SOURCE: bobbin thread keeps balling up
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Posted on Feb 24, 2011
Tiptronic 2040 won't move forward to sew. Seems to be problem with bobbin? Thread "balls up" at bobbin.
Hello Day Fegely
Thread balling-up in the bobbin area indicates that the upper thread (the one going through the needle) is the one doing the "balling". Check that the upper thread is threaded through all the thread paths ... this specific issue seems to be due to the thread not threaded through the "take up lever" ... that is the 'thingy' that goes up and down really fast as you are sewing.
Happy Stitching
Sewingirl/
Apr 20, 2017 | Sewing Machines
What makes stitches skip?
Skipping stitches is usually the needle choice. OR if could be blunt (needles are supposed to be changed every 8 - 10 hours of sewing) There are needles to be only used for sewing stretch fabrics, these are the "blue needles" of ball point needles, then there are the Universal needles for sewing woven fabrics cotton etc. then there are needles only for sewing denim.
You will need to identify which fabric you are sewing and use the appropriate needle.
Then there are the sizes #12 #14 #16 or 75 80 or 90 I'm not sure which numbering system you are using the smaller the number the finer the fabric is the usual way to go..
Also check that the needle is in the correct way. The scarf (the flat side of the needle is to be facing the back of the machine) also check the bobbin as it too can be put in the wrong way and will even try to sew..
Check that your threads are suitable for the fabric If possible try and match the thread in the bobbin with the top thread type.
If all else fails go and have a cuppa and come back to the machine change the needle change the bobbin change the threads and most times it will be ok. cheers Dot
Sep 23, 2015 | Sewing Machines
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
Feb 03, 2014 | Janome Magnolia 7330 Sewing Machine
Bobbin thread shows
have you tried to tighten the bobbin tension spring??
Dec 23, 2012 | Brother PE770 Computerized Sewing Machine
Singer 4423, timing out,what line up with what
I don't think it's a major timing issue, so don't panic. Take a look at your selected stitch pattern selector and set for straight stitch, and set Tension at 3-4. Width: 4. Length: 4. Make sure presser foot Down when you rethread machine so the tesion disks open up to locate thread. Always hold thread taut when "feeling" for tension slot. Insert new needle. Needle goes all the way up into needle clamp as far as it can possibly go, FLAT side needle toward needle bar and more rounded side needle facing you. Leave 6" tail. Hold thread toward you as you turn hand wheel toward you so needle can make a loop with bobbin thread. Make sure bobbin thread isn't hanging down on or across bobbin! Make sure thread in bobbin has wound evenly - good quality thread ideal! Clean bobbin area and feed dogs for broken, loose threads and lint. Always use needles appropriate size for weight of fabric. I suggest walking away from machine, taking deep, cleansing breadth, humming a favorite tune, then doing above and see how it goes! Soon your machine will be humming happily along with you. Hope these suggestions help. Jimmy
Mar 31, 2012 | Singer 4423 Sewing Machine
How do i thread my friends machine. It jams every time she starts sewing. Its a husqvarna 200
I can't find a threading diagram for the 100 but this one is for several other husq models, so could be very close for your friends.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Viking_Sewing_Machine_threading/Viking_150_185_190_Threading_Diagram.htm
Make sure that the bobbin is going into the bobbin case as per the diagram and is into the tension spring. The bobbin needs to turn anticlockwise when you pull on the thread tail when looking at the bobbin inside the case.
There is also a little springlatch on the bobbin case, you need to hold this to release it from the rotary hook to take out. If this isn't working correctly, it will pop out so you'd need to replace the bobbin case.
Now check the top threading too. ALWAYS raise the pressure foot to open up the tensions. And turn flywheel towards you until needle is at highest position. Now follow the threading diagram ensuring the thread does into each eyelet, then down the needle bar and into the needle eye.
Check tension knob number, should be between 4-6, usually 5.
Raise bottom thread manually through the needle plate by holding top thread tail and turning flywheel towards you through one revolution, catching the bottom thread and pulling it up through the hole in the needle plate.
Make sure that you have a new needle in, flat shank to the back, and the right size for fabric you wish to sew, sharp for wovens, ball point for knits.
Now select your stitch, place fabric under foot, lower pressure foot and while holding both threads behind the foot, start stitching. Hopefully, it will now sew for you.
If you can't get the bottom thread to come up at all then its likely that the timing is out and it will need a service.
May 24, 2011 | Husqvarna Sewing Machines
Kenmore 385 model Automatic Button Hole Apparatus Jams Thread?
Practice and practice some more! Use the same fabric and interfacing as your project and a NEW needle (the correct needle) This is for the Sears Kenmore 385 automatic button hole maker. Make sure you pull the bobbin thread through the Guide Block - it is that simple. Make sure you pull your thread to the back of the machine though the presser foot slot - the correct presser foot. Account for both thread tails before starting to sew. Keep thread tails to the back of the machine 4-5", insert fabric under presser foot keeping thread tails clear. Mark button hole and sew.
Mar 30, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Brother LS-1217 Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
