Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Weird warped lines
There is a warped line on the top of the tv picture and a small dicoloration that doubles the picture, but only in that area. Everything else is fine :/
  • Hitachi Master
  • 3,459 Answers
Your TV has a convergence problem. Here are some of the most common symptoms.
  • Screen looks 3D
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 29, 2009
Try the Magic Focus option on the menu.
Posted on Jan 28, 2009
no lamp for this model, it uses three picture tubes but the three D looking picture is a convergence circuit problem and is fixable.
Apr 04, 2012 | Philips 60PP9202 60" Rear Projection...
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
May 23, 2009 | Samsung Televison & Video
52 inch tv has a warped picture with a rainbow type ark at top
This set needs a major repair. there are bad connections on the power board and a fuse is blown. You pretty much need a technician to fix this.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture warped..Can't fix convergence because crosshairs are also warped!!
try these sites:
different tv same problem, same solution
Dec 05, 2007 | Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
If this is a projection tv then replace convergence amps. and resistors in the area also look for open fuses.
Sep 05, 2007 | Philips 55PP9352 55" Projection Television
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
209 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
