Question about Refrigerators
Crosley upright freezer fan blows - but doesn't get cold anymore
  • Official Brand Answer
  • 4,342 Answers
Hello burnelltolbe - If your refrigerator is not cooling, it could have a floating restriction in the lines or something more complicated like an issue with the sealed system that only a professional can help with. This can include the compressor not working correctly, the evaporator fan not turning, or even coolant in the lines not at the correct levels to properly cool. If the compressor is running, humming, or even a little warm then that is typically normal. However if the compressor is running hot, then it is over working and the issue could be before the compressor in the evaporator fan, coil or coolant lines. I suggest cleaning the unit out including the coils you can reach, and make sure no food items are blocking any vents in the unit. Also try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If any suggestion proves to be ineffective contact a professional to move forward accurately.
Posted on Jan 06, 2013
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
SOURCE: The freezer is not freezing and the fan is blowing
I have a kenmore coldspot side to side refrigerator the fan is blowing but it not freeing or get cold. No ice build up anywhere but the refrigerator is warm and the freezer is warm.
Posted on Apr 07, 2009
  • 33 Answers
SOURCE: freezer circulating fan not working
Buy a pet cow, and all your problems will be solved!! :)
Posted on Jul 11, 2009
woodchuck789
  • 4070 Answers
SOURCE: Whirlpool fridge not blowing cold air but freezer
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Posted on May 28, 2010
  • 4 Answers
SOURCE: refrigerator does seem like its working right
Your refrigerator compressor is either pumping or it is not. Set the refrigerator to low temperature, pull it out and listen for a while to see it the compressor is coming on. If it is coming on then there may be a freon leak or the internal coils may be iced up. If it is not coming on, then either there is no power to the coompressor, or the compressor itself is defective. Use a voltmeter at the compressor to check for voltage. There is also an add on device to start stuck compressors from your local HIVAC jobber store.
Posted on Jun 07, 2010
Why does my new Crosley refrigerator smell like oil in the freezer section?
Get it replaced or paint it lemon yellow. If they argue ask for your money back, if that is a problem contact your BBB and the manufacturer. It comes with an implied warranty to perform.
May 17, 2017 | Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Refrigerator not cooling. doesn't seem like fan is blowing. freezer still working
all that happens is the cold air from the freezer gets blown into the fridge section by the evap fan motor brhind the inside back wall of the freezer so if you open the freezer door and don't hear the fan blowing i would say that yes you do have a bad evap fan motor and that's why the fridge section is warm.next time send the brand name and model number so i can help you better
Sep 17, 2011 | Refrigerators
Hello, My fridge side of my hotpoint model # Hsm25gftc sided by side fridge/freezer isn't getting cold anymore. I purchased it in 2007 I believe. I've tore the ice maker and tray out and pulled...
if the freezer is working fine it sounds like you could have a bad damper control,also there's another thing i want you to check first,hotpoint is a g.e. product,they have sensors in the machines,you said you had the back wall off,take it off again and on top of the evap coil you'll see a sensor,it looks like a white bullet with two whits wires going to it,look at it and if where the wires connect to it it has a black ring around it you have to change it out,also ther's one of these sensors in the fidge section too,it senses how cold the fridge is and tells the damper door to open and close,it sounds like your damper is staying shut,the part number for the temp. sensors are WR55X10025 and it's like 8 dollars,if they have the black ring on them they most likely are your problem,the new sensors are all white,if you have the white sensors then you could have a bad damper.go to this site,it's sears site http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Refrigerator-Parts/Model-HSM25GFTCSA/1811/0165000/H0712760/00006?blt=06&prst=&shdMod= go to the fresh food diagram and look at the damper and the sensor,one of these parts are badmalso g.e. has had alot of problems with the mother boards,the computer board in the back of the fridge,if the condenser fan and evap fans are running fine and the freezer is fine then i would replace the damper and the sensor but change out the sensor first because it's 8 bucks,if that doesn't do it then buy the damper,all it does is the fan blows cold air from the freezer to the fridge section,if the damper isn't opening the air can't enter into the fridge section.hope this helps and points you in the right derection,let me know how you make out,good luck salde
Aug 12, 2011 | Hotpoint HSM25GFRSA
I purchased this Frigidaire freezer three years ago. Around a week ago, I noticed that the items I had stored in the freezer have begun to thaw slowly. Although the freezer is still "working", it...
This is a common defrost problem, The ice
is not being melted by the defrost system. he fan can't blow into ref.
Take out back panel of freezer to check for icw build up. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check evaporator fan in freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If this was helpful please rate me
Thanks for using fixya
Leo Ponder
imufo2
Jul 23, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Freezer not cold enough and fan doesn't blow.
if door was left open for extended period of time it has probably iced up around the evaporator fan, try to defrost around fan area using a hair dryer
Jul 28, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Refrigerators Logo
53 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
