Question about Nintendo Wii Remote Controller
We bought an additional wii remote and have tried to sync it but all we get is all 4 blue lights flashing??? wont work? thanks
    Problem Solver:
  • 6 Answers
Well, I don't have a Wii myself but I did some checking and found this. Hope it helps.
When you first get a second Wii remote, you have to press the red button inside the battery compartment and you press the red button by the Wii's SD Card slot simultaneously. Then you turn on the game and you press the Wii menu button. Go to controller settings and select reconnect remotes (can't remember if that's the exact words, but it's something like that). Next you hold 1 and 2 on the first remote, then hold 1 and 2 on the second remote. And that should do it.
Posted on Jan 19, 2009
On one of the wii controllers all i get is 4 blue lights flashing then nothing
The Wii-mote probably just needs to be synchronized to your Wii. Open the battery compartment on the back of your remote and open the front SD card slot on your Wii. Push the red SYNC button on the Wii and then the little red button on your Wii-moteand it should sync to your console.
Nov 10, 2009 | Nintendo Wii Remote Controller
Tip
2nd wii remote will not connect
Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
http://www.nintendo.com/consumer/systems/wii/en_na/ts/wiiremote.jsp
    Try these steps!
  1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
  2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
  3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
    1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
    2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
    3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console.
    4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
    5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
on Mar 04, 2010 | Microsoft Xbox 360 Console
Tip
try this!
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
      Try these steps!
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC" Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • on Mar 04, 2010 | Video Game Consoles & Games
    My wii remotes wont pick up signal blue lights flash then just go back out again
    Hi, check the batter level and then try re-synching the remote's.
    Here's instructions for both:
    f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
    Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
    There are two ways to check the Wii Remote's battery levels:
    • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
      or
    • Use the HOME Menu to check battery level of each Wii Remote:
      1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
      2. Select the Wii Remote Settings option from the Home Menu.
      3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
    55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
    1. Press the Power button on the Wii console to turn it on.
    2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
    3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
    4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
    This procedure must be followed for each additional Wii Remote added to your system.
    I hope this helps
    Mike
    Jul 30, 2009 | Nintendo Video Game Consoles & Games
    Tip
    Syncing your Wii-mote to your Nintendo Wii
    So you just bought a new Nintendo Wii Remote Controller but when you click the power button the four blue lights at the bottom just blink huh? Well that just means your Remote needs to be synchronized to your Wii.
    Here are simple step by step instructions to do so.
    1) Turn on your Nintendo Wii.
    2) Open the door on the front of your Wii covering the SD card slot and the SYNC button.
    3) Open the battery compartment on the back of your Wii-Remote Controller.
    4) Press the red SYNC button on your Wii.
    5) Press the little red SYNC button on your Wii-Mote.
    6) Wait until a solid blue LED light comes on on one of the four lights at the bottom.
    7) If it doesn't work the first time, try again.
    Your Wii-Mote should now be synchronized.
    on Dec 21, 2009 | Nintendo Wii Remote Controller
    Wii remote wont work after installing wii fit
    From Nintendo:
    2. Turnthe power of the Wii console ON. When you see the Health and Safetyscreen, open the small flap on the front of the Wii console to find ared button labeled "SYNC." Press and hold the SYNC Button down for 15seconds. This will clear all the syncs on the Wii, allowing you to geta clean start to begin the process described below.
      1. Withthe first Wii Remote you wish to sync, remove the battery cover on theback of the Wii Remote to find a small red button just below thebatteries.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
    Jan 02, 2009 | Nintendo Wii Console
    Wii remote keeps beeping and not working
    try this! I found it on Nintendo.com under support:
      Try these steps!
  • Sep 01, 2008 | Nintendo Wii Console
    My wii remote wont work
    Wii Remote Syncing problem is one of the common problem of Nintendo Wii. You may check out the DIY Wii Fix Guide, that explains step by step to fix the problem without any technical knowledge. I hope this guide will solve your problem. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide.
    Jun 21, 2008 | Nintendo Wii Console
    Can't get 2nd remote to work
    We had this same problem so I did a google search for 2nd wii remote not connecting or staying connected and this is what we came up with and did this and it really works! So hopefully this will help all of you to. Good luck! K and M
    This is from www.nintendo.com/wii :
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console.Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture below).
    Jun 19, 2008 | Nintendo Wii Console
    Nintendo Wii Remote Controller Logo
    246 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
