Question about Dell Vostro 410 Desktop Computer
Power supply recently changed now it it reading mos error
Power supply recently changed and replaced with a 585W. Now the keyboard will not work and it keeps giving an MOS error message
  • Dell Master
  • 27,725 Answers
Not sure what a MOS error is or what its related to
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Posted on Jan 03, 2013
Asus Monitor
Here are a few possible problems with your monitor
1, Backlight gone bad
2. Power Supply gone bad
3. Wrong display resolution
Given that your monitor is only 14 months old, I would lean toward
either a bad capacitor in the power supply or the screen resolution
needs to be changed (boot up in safe mode and change the resolution)
The power supply problem would require some dis-assembly and working with high voltage.Not for the faint of heart..
Jan 19, 2012 | ASUS Computers & Internet
Pin layout for orion 585w
There is only one way you can connect your power supply. The connection is pinned to only go in one way. ALSO: The power supply is very inexpensive and can most likely be bought from any of your computer retailers, Amazon - Just make sure to confirm the right model type of power supply. BEST to have it tested before replacing it. To make sure that is the issue..
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Oct 20, 2011 | HP HEC HP585D 585W ORION HP585D ATX 12V...
We have an HP color laserjet CM6040 MFP that is displaying an unknown error message of 58.04 I have checked the service manual and that code doesn't exist. The event log shows the error as a device...
I am having error code of question mark (?) from Hp CM6040 MFP printer.... How can I olve this problem and what is the course?
I need your urgent respond
Thanks
George Sunday
Tel: +234 806 560 7993
Jul 11, 2011 | Office Equipment & Supplies
Same problem as others cited. Fans race and no bootup
Please remove C-mos battery from *********** board & reinsert it,Before it power down the system. After that in c-mos setup selsect Default load & restart the System.
Jun 28, 2009 | E-Machines eMachines Desktop PC
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
Beeps
Standard Original IBM POST Error Codes
Code Description
1 short beep System is OK
2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Display adapter problem (EGA)
3 long beeps 3270 keyboard card
For more info go here: http://pulonangka.web.id/software/beep-codes-error-codes
Aug 16, 2008 | Dell XPS M1530 Notebook
T30 Power up problem
The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
Jul 15, 2008 | IBM ThinkPad T30 2366 Notebook
Proble with HP laserjet 3330
You will have to have the scanner assembly replaced. There were some problems with the earlier versions and they have seen been rectified. I have not had a single one come back in after replacing it.
Jun 01, 2008 | HP LaserJet 3330 All-In-One Printer
Can't find a power adapter.
most speakers use a 5-12 volt DC power supply, you can get an adjustable power supply from radio shack which can be used as a replacement for your power supply. Just look on your spaeker unit for the voltage and current and hand these readings to the sales person and they should be able to show you a power supply that can be used in its place.
Sep 16, 2007 | Harman Kardon SoundSticks II Computer...
Dell Vostro 410 Desktop Computer   Logo
Alun Cox
