Question about Sony PlayStation 2 Slimline Console
PS2 will not play any games
I hope you don't mind, but I was wondering if you could shed some light onto why my PS2 suddenly stopped playing games. Games simply do not load, and when I try to access them through the Browser menu, I receive a constant "Reading disc..." message at the bottom of the screen. There is a loud ticking sound coming from the PS2, like the lens is attempting to move but not (??) or something like that.. games appear to be spinning, but not at a fast rate. The Diagnosis feature does not help either. This all happened overnight, which is the strange part. This is an SPCH-70012 model. The Serial Number is FS7423957. The Barcode Number is PK274239571. I'd appreciate any insight you had. Thanks for your time!
  • 11 more comments
  • Poopie Nov 02, 2007
    Won't play DVD's, games, BUT will play cd's. Diagnosis does not work
  • brybry1221 Jan 04, 2008
    i have the same problem
  • madden 2008 Jan 05, 2008
    i have tried cleaning the lens. blowing out the system. cleaning the disk.
  • Anonymous Mar 29, 2008
    this thing sounds like clicking coming from inside the ps2. and says reading disc but me and my friend think it is from droping it earlier.
    1. try to look inside the playstation to see if ining thing fell out
    yes
  • emilydawn24 Apr 25, 2008
    mine does that too.except the reading disc will be there for like 2 seconds and go away and i dont think the cd is moving at all
  • divantae Jun 23, 2008
    loud ticking noise and will not read disc
  • miah-94 Jul 21, 2008
    when i start the game by turning the plug on and there is no disk in it the consoles playes fine but when i put the game in i hear a load tiking coming from the console and the weared thing is that it happened over night so could anybody help me please thanks....
  • insaneClownP Oct 29, 2008
    but i no wat tht ticking sound is it's the lazer peace moveing up and down
    but it woont play movies or ps2 games only some ps1 and audio cd'd
    but wen u try to play a ps2 or movie the cd spins like 90 degres and stops then reapets
    but it might have somting to do with the battery in between the big green thing wen its open
    tht my theory
    its a watch battery i no ther is 1 cuz iv seen it
    so im gunna get a new battery to see if tht was the problum
    and i will tell u guys if thts the prob
  • Anonymous Oct 30, 2008
    ghdgfhd
  • Anonymous Jan 16, 2009
    my play station will turn on power up but the games will not turn i opened the front cover but the game was not turning but mine is the slim model
  • jherendeen_1 Jan 21, 2009
    will play ps1 games but not ps2
  • tanmc82 Jan 27, 2009
    I have the same problem with my slim ps2.3 games will load but I just bought the guitar hero world tour and it will not load the game, it keeps spinning but nothing happens.
    Guru:
  • 134 Answers
The main issue is there is a problem with the laser. You may be able to run Sony PS1 discs or Music CD's but DVD's are normally what quit working first. If you are inclined to open the system and it is out of warrenty you can do so. BE VERY CAREFUL There is a ribon cable that goes to the power button. Also there is most likely a LOT of dust in the system. and clean the lens of the drive. If this does not work, you'll have to replacement with new laser. laser type: khm-430b or pvr-802 of the same type. Hope this helps..
Posted on Nov 02, 2007
    Problem Solver:
  • 4 Answers
Ok so like, everyone above me has said the solution: replace the laser. But here it is, do not, I repeat, DO NOT put scratched discs into the drive. The laser will knock itself out of whack trying to read them, and you'll end up with the same problem. Trust me, I had to replace mine twice...
Posted on Jan 09, 2008
  • 3 Answers
I tried this also. i cleaned the laser relentlessly for hours and it finally started to work. now it only reads cd or ps1 games, but not ps2 games. also i tried standing it up, and it worked after repeated attempts. but it stopped reading dvds agains, so i decided to change the laser eye finally after all that. the magnet is overpowering the motor and it wont spin fast enough to read dvd disc which is formatted different or heavier than a cd rom disc. the power to laser controls the speed to the motor which also controls the power to that little electromagnet built in next to the laser. not a good place to put it!!! just a bad design i think. it works for awhile but eventually the strain burns out or damages the laser eye. remember we are talking about something so sensitive to the slightest volt change in order to operate. and its a moving part too which make it even harder for it.
Posted on Sep 07, 2009
  • 3 Answers
Possible laser failure sony claims only sony can fix them but you may find somebody who does it as a hobby
Posted on Jun 26, 2007
My play station is running but no picture please help.
Posted on Nov 03, 2008
    Guru:
  • 1,463 Answers
As said above the laser may be gone?
but you could contact sony tell them and get it replaced.
only if back as not been opened or tampered with in any way ,
as this will void the replacement .
contact sony .
riz.
My ps2 wont play ps2 games but it will play if i put a music cd
Posted on Jul 13, 2008
I had the same problem with my son's PS2, I first used compressed air to blow out dust with no result. I then cleaned the laser lens with a wetted cotten swab and dried it with the other end. It's been working ever since. Saved me the cost of the much asked for XBOX 360.
Posted on Mar 01, 2008
    New Friend:
BIG HAMMER!!!!!!!!!!!!!
Posted on Apr 01, 2012
SOURCE:
Hey, do you know, in my country Malaysia we got someone that can upgrade PSOne console to be able to play PS2 console game :) but I wonder, how they do that...?? That the problem, and I wish someone who...
The only way someone can get a PS1 to play PS2 games is if they modified a PS2 to look like a PS1. The hardware inside a PS1 is not powerful enough and not complex enough to run PS2 games. They would need to take a PS1, and take the insides out. Then take the insides of a PS2 and modify it so it functionally fit inside a PS1. This seems like cool albeit pointless way to modify your PS1 and PS2. Thanks for the question!
May 30, 2011 | Video Game Consoles & Games
I got a ps2 and it plays some games and it doesnt others...the disks are not scratched or anything it just doesnt play them... like when I put the disk the playstation logo comes up like its about to play...
This happens to me , Some games don't work on Some PS2 consoles for Example my friends Theme park world only works on a Slim PS2 and not a Proper Fat one , Wat type of PS2 do u have? and wat game r u trying to play?
May 21, 2011 | Sony PlayStation 2 (PS2) Console
My ps2 won't play ps2 games. It only plays ps1 games. No dvd's or ps2 discs
I have ps2 too. Your games are not original and you don`t have chip. If it isn`t problem i don`tt know what is.
Feb 22, 2011 | Sony PlayStation 2 Slimline Console
I was just wondering, IF the PS2 can play games that have been edited on a computer/laptop (e.g. 4-disc PS1 game put onto one disc), and not edited as in the actual game disc being edited, but put on a...
Your system needs a mod chip to play games on a disc that was not created by Sony.
Most ps2 games are DVD's only some are cd's.. All of the ps1 games are cd's so if you burnt it onto a dvd its not going to work.
Oct 06, 2010 | Sony PlayStation 2 (PS2) Console
Sony ps2 stopped loading game and only going onto browser screen
want to play all type game cd,dvd etc; on psp2, presently it plays only original sony game cd
Feb 28, 2010 | Sony PlayStation 2 (PS2) Console
My ps2 wont play games
That is a common problem with some ps2s some do it and some don’t just certain ps2 will only play certain games sorry I know this probably doesn’t help just some info
Mar 28, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 games to play on ps3
you can only play ps1 and ps2 games on your ps3 if it has the same game region.hope this info helps your problem
Dec 21, 2008 | Sony Playstation 3 (PS3) Console
PS3 console
I look all over the net but could't find anything, until i found a site that said they could show me how to fix any problem with my ps3. At first i was not so sure about ordering the manual but i did, whats $5 plus i used paypal, but long story short i fix my ps3, i recomend this site www.gameme.20fr.com i hope this help you like it help me. PLAYSTATION FAN FOR LIFE! waiting on PS4
Mar 07, 2008 | Sony Playstation 3 (PS3) Console
Sony PlayStation 2 Slimline Console Logo
7,133 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
