Question about Fisher and Paykel DD605SS Stainless Steel Dishwasher
How much is service and maintenance of Fisher Paykel bottom draw that does not work
  • Fisher and P... Master
  • 3,247 Answers
THere could be lot of reasons for the drawer not to work. Need some description of what is happening before making any suggestions. If there are no lights on the panels then the controller or controller power is faulty. Could cost upto $300 to fix this.
Posted on Jan 12, 2013
  • Nomvula Jan 14, 2013
    When pressing the button for the second drawer the message reads, "error".
  • Sam Jan 21, 2013
    Sorry I have been away on holidays. Just saw your post. i am asssuming you are pressing the Start button on the front panel of the drawer. It is unsual to get the message "error" in this model. Usually the messages are F1, F2, F3 or U1 etc. Are you please able to carefully describe the steps you follow on the drawer after loading the dishes and upto getting the error message.
  • 864 Answers
SOURCE: where can i get a service manual for free fisher Paykel dd/ds602
Look at:
http://fisherpaykel.com/global/customer-care/product-manuals.cfm
I got no results using the model number you provided but you can contact Customer Service from that website.
Posted on Jun 30, 2009
  • 784 Answers
SOURCE: I have a Fisher Paykel dishwasher with water in top drawer
You need a Air gap kit designed by Fisher and Paykel to address this problem. It is pricey but it is worthy. I used this and very happy with it since no back flow problem from one while other running. Here is a link to order it.http://www.fisherpaykelparts.net/product/WT50/WT50-Dual-Air-Gap-Kit/
Posted on Dec 29, 2009
woodchuck789
  • 4070 Answers
SOURCE: haveing a u3 code on my top draw of my fisher
First have the unit turned off. Then open up the drawer that,s giving you trouble.
The badge ought to be lit.
Now simultaneously press the static touch pads on each end of the led status lites (the ones on the drawer top?) (Cycle Select, and Eco-sensor pads)
Hold them for about 5 seconds.Now If you have a metal front machine, the badge display will either show HP or LP. Assuming you have normal water pressure about 50 - 70 psi you want to select the HP setting.
Do that by pressing the start button till you get what you want, then press power off to lock the setting in.
Posted on Mar 06, 2010
Testimonial: "problem solved thank you very much for the info"
SOURCE: FISHER & PAYKEL DD-603
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Posted on Mar 30, 2010
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Remove the bottom drawer on Dd605 fisher paykel dishwasher
its quite simple there are 2 plastic tabs on either side of the draw on the bottom front corner behind the metal panel on the plastic tub part, simply push on the tab and slide the whole rail back (the plastic tab is the end of the rail it sits on) on both side and the draw will lift out (note it doesn't come out very far as the hoses and wiring will still be attached but will still allow you to access everything). message me if you need pics or more help
Oct 05, 2014 | Fisher and Paykel Dishwashers
Cannot turn my fisher and paykel dishwasher off..keeps beeping and motors are running in both draws. I have taken the bottom draw out and it is dry.. I can only turn it off if I turn the house mains off...
I am assuming you infer that the bottom of the dishwasher is dry when you took the bottom drawer out. This means the floodswitch located on the power filter board at the bottom of dishwasher might be faulty. Do you get any Fault code on the display.
Apr 21, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel dd603
Flood switch is at the very bottom underneath the bottom draw in the base floor.Unplug cord.Open bottom draw all the way & squeeze a towel or sponge under the draw & soak up the water..The washer should work now..Why did it flood in first place?
Check that dishes are not stacked higher than top edge of the draw otherwise it can't seal.this can happen when children are asked to stack the dishwasher.Another cause is some models the seal is an inflatable tube that seals the top edge of the draws,it gets cut or sliced buy a plate that was stacked to high when you closed the draw.there should be no clunk of dished hitting when the draw is closed.
May 30, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel control panel to far left side has a film on it that chipped off - showing a shinner stainless steal under it. I guess this is a coating of some sort. Dish draws are 4 1/2 yrs old. Mild det...
You can buys the parts that look chipped/ broken and replace them. Panel parts are very easy to replace.
Check out which parts you need from the parts manual and order from the local fisher and paykel distributor.
http://www.stokes-aus.com.au/StokesAP/Manufacturer_Info/FP/DISHWASHERS/599084%20Dishdrawer-Version%203%20%20eg%20%20DD603%20etc.pdf
The parts that you need are listed from page 6.
Jan 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & paykel double dish drawer top draw just beeps...
The controllers get very brittle & can break away from their housing, the reason it's rapidly beaping is because it thinks the door is open. PLEASE TURN IT OFF FIRST AT THE POWER POINT. Take the front draw panel off by pulling the plugs situated on the front behind the draws, the controller is at the top right hand side if it is loose then thats the problem, double sided tape will work but lots of it or try a wedge type arrangement. I know this is an old post but people refer to these for solutions much later.
Mar 09, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
NO POWER Fisher Paykel DD603 double drawer
Check to see float switch (located on the bottom of cabinet below bottom draw )hasnt moved or dislodged in transit.(Access by way of back panel-easiest) or removing bottom draw.
Sep 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and paykel twin draw
I'm not really sure. With the double drawer configuration, I know the top drawer is larger than the bottom drawer. If I had to take a guess, I would say the single drawer might fit in the top of the double drawer.
Jun 26, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Open Questions:
Why does my Fisher and Paykel DD605SS stalls midway through wash cycle? I'm not sure if the following incidents are related but my Fisher and Paykel DD605ss now stalls part way through the wash cycle. A few nights ago I loaded the dishwasher hit timer and left it to run in the wee small hours. When I got up the next morning the circuit breaker had tripped on the circuit with the dishwasher. Once I reset the circuit breaker I started the dishwasher. I almost always run it on Normal (Eco) 154 minutes. It ran and then started beeping which I presumed was it finished. It continued to beep and was displaying an E4 error. After searching the E4 error I took the most popular solution and unplugged the machine and left it without power for about 10 minutes. After that plugged it back in and hit the start button again. It seemed to run well and when I walked into the kitchen late in the cycle it was displaying 28 minutes to go with a scrubbing brush flashing in the LCD. I left it alone and went about my life and returned to the kitchen about an hour later and it was still on 28 minutes to go. I hit pause and had a look, there was water and foam in the bottom of the draw. I took the wet plates out and hit the rinse option to see if it was a pump problem. The rinse option ran and the draw was almost empty. I then took the rack etc out of the raw and cleaned it all out. There was a little gunk but not much. I put a light load of dishes in the machine and ran it on the Normal wash mode. It started up and made all the right noises so I left it. I came back to the kitchen and it was stuck on 94 minutes with the flashing scrubbing brush. I paused it, took the dishes out and again ran the Rinse option which drained the draw. So my question is are the three events linked? Circuit breaker tripping, E4 error and random stoppages during the wash cycle?
Feb 27, 2017 | Fisher and Paykel DD605SS Stainless Steel...
See all Fisher and Paykel DD605SS Stainless Steel Questions
Fisher and Paykel DD605SS Stainless Steel Dishwasher Logo
57 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
