Question about Westinghouse LTV-27w6 27 in. LCD HDTV
Dark spots on westinghouse 42 in hdtv led tv - Westinghouse LTV-27w6 27 in. LCD HDTV
4 Suggested Answers
  • 32 Answers
SOURCE: i just purchased a westinghouse lcd led tv. half
This sounds like a series of LED's are not performing properly and may indicate a faulty set. I would recommend returning for a replacement.
Posted on Feb 28, 2011
Testimonial: "simple solution just wanted some reassurance. exactly what i though but good to hear from an expert"
UberTechzor
  • 295 Answers
SOURCE: i just bought an westinghouse
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Posted on Aug 27, 2011
  • 1212 Answers
SOURCE: Westinghouse 42" picture very dark, menu not working
Your set has 2 CCFL tubes, one is potentially failed, which is why it is lit dimly. It is also very possible that the inverter for one section failed as well. A much more likely scenario since electrolytic capacitors are a common point of failure, and most often when they do fail, they will bulge visibly. It is easy to replace them too.
Best approach if you are up to it- take the back of the set (unplugged of course) and see where the power cord comes into set. You may need to remove some metal shields over the supply to see the caps, if any look bulged or appear to have oozed something- they are the first item to address. These use a high ripple current type of capacitor.
Once caps are replaced, power up the set in the manner you are comfortable working with it- back is off, or on, upright fully assembled, or facedown, and see if both CCFL tubes light. if they do- then look at the image quality if the adjustments work again and are legible, youare good to go. if not- then the mainboard may have some issues. It is usually good practice to approach the simple lower cost options when the symptoms suggest it first. Then work up the price chain when a service manual is not available.
Posted on Dec 13, 2011
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
I have a Westinghouse LD-4255VX 42 tv and when I turn it on the screen comes on with the crown symbol and then it cuts off
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Sep 01, 2014 | Westinghouse LD-4255VX 42" Edge-lit LED...
Dark spot on led tv
Possibly faulty LED diode. I recommend taking your TV to your local repair shop. You can try to dissasemble your TV yourself but its safer to hand it to profesional.
Apr 10, 2013 | Westinghouse 46? 1080p Led Tv ld4680 /...
Westinghouse LD-4695 led hdtv bought it less then a month ago and its showing white cloudy spots around edges to pictures of it and they came out blue idk if its because the home theater speakers were all...
Depending on how big your speakers are and how they were to the TV....that might be the reason. Magnets are the worst thing you can have next to electronics. It either that, or you bought a lemon, or you have a kid in the house and they put magnets on the tv for fun.
Dec 15, 2012 | Westinghouse 46" LED TV HDTV 120Hz Full...
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
I purchased 2 32in Westinghouse LCD HDTV and one 42in LED HDTV, BOTH the 32in LCD TV's have a volume that will not stay below max. Sometimes the volume bar will go away I can lower the volume, release the...
there may be some other source of intereference within the area that you have the tv placed try moving it to a different area and see if that works you are dealing with electron magnetic interference and infared waves
Jan 27, 2011 | Westinghouse W4207 42 in. HD-Ready LCD TV
Dark spots on my JVC 61" tv
dark spot could be a faulty led. if you put a program on that is in white screen you should see all the leds light up the screen. dark spot will be were the led is not working. if on white screen and they all lite up but still dark around the area, it could be the lcd screen. and could be dying pixels. and try this video https://youtu.be/wlA2rcrAOCs
Feb 10, 2018 | Toshiba 55H70 55" Rear Projection...
Westinghouse 42 inch lcd flat screen tv
only get sound from my 42 lcd screen fro westinghouse, no display
Jul 15, 2008 | Westinghouse LTV-40w1 HDC 40.02 in. LCD...
Westinghouse LTV-27w6 27 in. LCD HDTV Logo
55 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
