Question about HP Deskjet 2460 Printer
Can I install d2460 printer on desktop with win 98 and usb port?
As i remember the win 98 is 16 bit and win 2k and xp are 32bit.Are the driver wil work properly with the win 98? SOMEONE HAVE EXPRIENCE WITH THIS PRINTER AND WIN 98?
I will download the software
Posted on Mar 02, 2009
No compuer connection in win 7 for HP officejet j4680
Please go through  the following steps and I am sure that you wil be able to connect the printer.
1) Check the Printer USB Cable is connected to the PC's USB port.
2) Check that the Printer is in power ON state.
3) Go to this website and download the Printer driver for windows 7
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&dlc=en&product=3692888
Here you will find a Select tab where it will ask for your OS. Select windos 7 32bit or 64 bit whichever is applicable and click Next.
Click on "Driver(2)" and then ┬╗ HP Officejet Basic Print and Scan Driver and Click on the Download tab.
This will download the Printer driver for windows7 and after it gets downloaded install the driver by double clicking on the exe file.
Your printer will get installed.Now you will be able to take print.
If you feel that my answer has helped you in any way then please give a vote.
Thanks.
Apr 05, 2011 | Computers & Internet
I have a lexmark z815 printer connected via usb to my hp omnibook xe3 running win xp. I also have an old desktop running win 98. The 2 pc are connected together via a crossover ethernet cable. The printer...
the easy way out it is to upgrade the desktop to windows xp....I believe that no matter how week is the desktop ..xp it will install on it ...I installed once on a P3 with only 128 M ram and a 1200 CPU...so ..if you have at least 256M ram it will work and there is no need to loose any data either cause you can move them into another partition and format only C ...
Nov 04, 2009 | Lexmark Z815 InkJet Printer
HP 1210 c/ps will not print
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Nov 22, 2008 | Microsoft Windows 98 for PC
I have a 9320 One Touch Scanner and can not find the drivers for Vista. This is creating much frustration as I had purchased the scanner new and can not use it. If possible please point me on where to...
System Requirements PC Microsoft Windows 98 SE, 2000 Professional, ME, XP:
Pentium Equivalent Processor or Higher
64MB of RAM (128 MB Recommended for Windows XP)
200 MB of Available Hard Disk Space
CD-ROM Drive
USB Port
Color Monitor
I do believe the scanner does not support windows vista as of yet.
Printer / Scanner
HP Deskjet 6940 (via Network, auto driver) (32-bit)
HP Laserjet 5L (32bit)
hp color LaserJet 2550L (32-bit)
HP Officejet 4200 (32-bit)
HP PSC 1401 All-In-One Printer (32-bit)
Lexmark 240N (Native Driver x64).
Microtek Scanmaker 3600 (32-bit)
Samsung ML-2010 monochrome laser printer (32-bit)
Epson R220 (32 bit)
Brother HL 1030 works after adding a printer manualy and installing as a brother 1430 (32bit)
Dell Photo AIO Printer 964 (32-bit)
HP Laserjet 4plus (32bit)(64bit) with HP Jet Direct as LPR on Standard TCPIP Port
HP DeskJet 845c (32 bit)
(supported printers/scanners)
Apr 20, 2008 | Office Equipment & Supplies
Can not get my printer to print from the computer
Unfurtunately you didnt tell us what pc system you run: Is it XP, Win2k or Vista?
The latter one wont be able to connect to your pc.
For the mfc 210c are only drivers for xp and win 2k, 98se avaiable.
You need another (newer) mfc (mfc240 or 235) if you run vista.
Anyway, if you run xp, download the aggrssive usb driver remover from the brother homepage and delete the drivers installed.
After a restart of the pc do have the mfc DISconnect from usb port (which must be one of the pc: NO hub!). Insert install disc and wait until pc software demands the connection to mfc. Connect now to pc usb. Let the software finish the installation. This should work for xp and win 2k/98se.
Mar 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Kingston 256 usb pendrive
Dear Ekwal Imam
Install driver for usb drive for win 98. the driver comes with usb. or visit manufacturer site.
Feb 23, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Connect laptop to cpu and use laptop as monitor
go to "tiger direct" and purchase a usb to usb interconnect cord. the software they supply will install an ansi and unicode driver so you can use two machines with win xp, win me or win 98. xp and me use the unicode driver while win 98 uses the ansi driver.
Dec 27, 2007 | Compaq Presario 5000 PC Desktop
Windows xp with not recongise HP Laserjet 6p when plugged into a usb port
To my knowledge, the 6P isn't a USB printer, it's parallel port only. Are you using a USB / parallel port adapter? If so, I believe that's the root of your problems - the adapter.
Try hooking it directly to the parallel port (shut the PC and printer down before doing so).
Upon restart, Windows will detect it, and may or may not "know" the model, so you may have to choose it from the dropdown boxes.
If it works when directly connected, you will need to either locate drivers for the adapter (if any), or manually configure it under the printer port properties.
If you need more help, let me know. These are great little printers - once you get them to work!
Dec 03, 2007 | HP LaserJet 6p Printer
HP Deskjet 2460 Printer Logo
245 people viewed this question
Seeker5211
Seeker5211
