Please Solve this C++ Program
Convert a string into binary and count number of 3 consecutive ones present in it and print it .
Note : Don't use temporary integer array variable to store the binary code
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Posted on Jun 10, 2009
Explain how to convert the binary number 01101 into decimal and convert it into decimal.
the binary system are made only for ones and zeros, when you try to "add one digit" in the binary system, you must add an 1 in the right-sided zero of the binary code, that means that when you want to count up in binary, it should be:
00000 = zero
00001 = one
00010 = two
00011 = three
00100 = four
00101 = five
and so on.
to go up to next number you must add a "1" in the place close more to the right, once this digit has reached its two states (binary= first 0 then 1) the same process occurs in the next digit , but it only rise from zero to one once the right one has reached its two binary states.
the binary digit 01101 stand for: 13 (decimal)
Mar 04, 2015 | Office Equipment & Supplies
How to write a program to translate english text to binary string and write a program to do inverse 27 = . , 28 = , 29= ? 30 = . 31=
to convert from text to binary, you would do something along the following lines..
1. have the user enter a string.
2. loop through the string (for each char in stringEntered..)
3. convert the character to binary using the methods provided to you by your language of choice
For the reverse (binary to text):
you must take 8 bits of data (which would be a single character), and convert it to text using the methods provided by your language of choice..
here's some links that might be of interest to you.
Visual FoxPro VFP CTOBIN and BINTOC Functions Equivalent In Net The Most Accurate and Reliable Source Code Converters
Feb 06, 2015 | Microsoft Visual Studio 6 6.0 Professional...
How to convert octal numbers into binary numbers
Each octal digit represents three binary digits. Simply convert each octal digit to three binary digits and string them together.
0o = 000b
1o = 001b
2o = 010b
3o = 011b
4o = 100b
5o = 101b
6o = 110b
7o = 111b
As an example, to convert 351o to binary:
3o is 011b
5o is 101b
1o is 001b
so 351o is 011101001b
Sep 12, 2013 | Audio Players & Recorders
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Suppose 1011 amt convert in words like 'One
Hiii
  1. Start Microsoft Excel.
  2. Press ALT+F11 to start the Visual Basic Editor.
  3. On the Insert menu, click Module.
  4. Type the following code into the module sheet. Option Explicit
    'Main Function
    Function SpellNumber(ByVal MyNumber)
    Dim Dollars, Cents, Temp
    Dim DecimalPlace, Count
    ReDim Place(9) As String
    Place(2) = " Thousand "
    Place(3) = " Million "
    Place(4) = " Billion "
    Place(5) = " Trillion "
    ' String representation of amount.
    MyNumber = Trim(Str(MyNumber))
    ' Position of decimal place 0 if none.
    DecimalPlace = InStr(MyNumber, ".")
    ' Convert cents and set MyNumber to dollar amount.
    If DecimalPlace > 0 Then
    Cents = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & _
    "00", 2))
    MyNumber = Trim(Left(MyNumber, DecimalPlace - 1))
    End If
    Count = 1
    Do While MyNumber <> ""
    Temp = GetHundreds(Right(MyNumber, 3))
    If Temp <> "" Then Dollars = Temp & Place(Count) & Dollars
    If Len(MyNumber) > 3 Then
    MyNumber = Left(MyNumber, Len(MyNumber) - 3)
    Else
    MyNumber = ""
    End If
    Count = Count + 1
    Loop
    Select Case Dollars
    Case ""
    Dollars = "No Dollars"
    Case "One"
    Dollars = "One Dollar"
    Case Else
    Dollars = Dollars & " Dollars"
    End Select
    Select Case Cents
    Case ""
    Cents = " and No Cents"
    Case "One"
    Cents = " and One Cent"
    Case Else
    Cents = " and " & Cents & " Cents"
    End Select
    SpellNumber = Dollars & Cents
    End Function
    ' Converts a number from 100-999 into text
    Function GetHundreds(ByVal MyNumber)
    Dim Result As String
    If Val(MyNumber) = 0 Then Exit Function
    MyNumber = Right("000" & MyNumber, 3)
    ' Convert the hundreds place.
    If Mid(MyNumber, 1, 1) <> "0" Then
    Result = GetDigit(Mid(MyNumber, 1, 1)) & " Hundred "
    End If
    ' Convert the tens and ones place.
    If Mid(MyNumber, 2, 1) <> "0" Then
    Result = Result & GetTens(Mid(MyNumber, 2))
    Else
    Result = Result & GetDigit(Mid(MyNumber, 3))
    End If
    GetHundreds = Result
    End Function
    ' Converts a number from 10 to 99 into text.
    Function GetTens(TensText)
    Result = "" ' Null out the temporary function value.
    If Val(Left(TensText, 1)) = 1 Then ' If value between 10-19...
    Select Case Val(TensText)
    Case 10: Result = "Ten"
    Case 11: Result = "Eleven"
    Case 12: Result = "Twelve"
    Case 13: Result = "Thirteen"
    Case 14: Result = "Fourteen"
    Case 15: Result = "Fifteen"
    Case 16: Result = "Sixteen"
    Case 17: Result = "Seventeen"
    Case 18: Result = "Eighteen"
    Case 19: Result = "Nineteen"
    Case Else
    End Select
    Else ' If value between 20-99...
    Select Case Val(Left(TensText, 1))
    Case 2: Result = "Twenty "
    Case 3: Result = "Thirty "
    Case 4: Result = "Forty "
    Case 5: Result = "Fifty "
    Case 6: Result = "Sixty "
    Case 7: Result = "Seventy "
    Case 8: Result = "Eighty "
    Case 9: Result = "Ninety "
    Case Else
    End Select
    Result = Result & GetDigit _
    (Right(TensText, 1)) ' Retrieve ones place.
    End If
    GetTens = Result
    End Function
    ' Converts a number from 1 to 9 into text.
    Function GetDigit(Digit)
    Select Case Val(Digit)
    Case 1: GetDigit = "One"
    Case 2: GetDigit = "Two"
    Case 3: GetDigit = "Three"
    Case 4: GetDigit = "Four"
    Case 5: GetDigit = "Five"
    Case 6: GetDigit = "Six"
    Case 7: GetDigit = "Seven"
    Case 8: GetDigit = "Eight"
    Case 9: GetDigit = "Nine"
    Case Else: GetDigit = ""
    End Select
    End Function
Hope this will solve ur problem
Regards.
G'Day
Sep 10, 2009 | Microsoft Office Professional 2007 Full...
In MS Excel, convert a Number in Text formate
Dear,
you've use macro to this.
Press Alt+F11
it will open Microsoft Vsual Basic Editor.
Click on Module in Insert Menu and paste the following codings:
Function ConvRs(ByVal MyNumber)
Dim Rupees, Paise, Temp
Place(3) = " Lac "
Place(4) = " Crore "
Place(5) = " Arab " ' String representation of amount
MyNumber = Trim(Str(MyNumber)) ' Position of decimal place 0 if none
' Convert Paise and set MyNumber to Rupee amount
Paise = GetTens(Left(Mid(MyNumber, DecimalPlace + 1) & "00", 2))
End If
Count = 1
If Count = 1 Then Temp = GetHundreds(Right(MyNumber, 3))
If Count > 1 Then Temp = GetHundreds(Right(MyNumber, 2))
If Temp <> "" Then Rupees = Temp & Place(Count) & Rupees
If Count = 1 And Len(MyNumber) > 3 Then
Else
If Count > 1 And Len(MyNumber) > 2 Then
MyNumber = Left(MyNumber, Len(MyNumber) - 2)
Else
MyNumber = ""
End If
End If
Count = Count + 1
Loop
Select Case Rupees
Case ""
Rupees = "No Rupees"
Case "One"
Rupees = "One Rupee"
Case Else
'Rupees = Rupees & " Rupees"
Rupees = "Rupees " & Rupees
End Select
Select Case Paise
Case ""
'Paise = ""
Paise = " Only"
Case "One"
Paise = " and One Paisa"
Case Else
Paise = " and " & Paise & " Paise"
End Select
ConvRs = Rupees & Paise
End Function
' Converts a number from 100-999 into text *
MyNumber = Right("000" & MyNumber, 3) 'Convert the hundreds place
End If
'Convert the tens and ones place
Else
End If
End Function
' Converts a number from 10 to 99 into text. *
Result = "" 'null out the temporary function value
Case Else
End Select
Case Else
End Select
(Right(TensText, 1)) 'Retrieve ones place
End If
GetTens = Result
End Function
' Converts a number from 1 to 9 into text. *
End Select
End Function
save this as as ConvertRs.xla in Microsoft\AddIns folder
now, you'll have to activate this AddIns:
in your Excel Worksheet select:
Tools\Add.Ins...
Check the ConvertRs option
now this will be used as User Defined Function.
you can insert it from the Function Options or just enter the following command in the desired cell where you want the result:
=ConvertRs(Cell Reference)
Cell Reference means where the number is available, you want to convert.
Try this and then tell me the responce.
Bhasker Kumar
Jul 09, 2009 | Microsoft Computers & Internet
Java code for adding octal, hexadecimal subtracting binary,
Hello desireejane,
One method is to do the following
  1. Convert the octal, hexadecimal or binary to decimal.
  2. Add or Subtract the decimal normally
  3. Convert the result back to octal, hexadecimal or binary.
  • Convert the octal to decimal:
public static long octalToDecimal(String octal) throws NumberFormatException {
// Initialize result to 0
long res = 0;
// Do not continue on an empty string
if (octal.isEmpty()) {
throw new NumberFormatException("Empty string is not an octal number");
// Consider each digit in the string
for (int i = 0; i < octal.length(); i++) {
// Get the nth char from the right (first = 0)
char n = octal.charAt(octal.length() - (i+1));
int f = (int) n - 48;
// Check if it's a valid bit
if (f < 0 || f > 7) {
// And if not, die horribly
throw new NumberFormatException("Not an octal number");
} else {
// Only add the value if it's a 1
res
+= f*Math.round(Math.pow(2.0, (3*i)));
return res;
Mar 24, 2009 | Sun Java Programming Language (cdj-275)
Formula for converting currency fig to words
You need to make some changes to the VB script.
here are the steps to guide you
Open Excel - press Alt F11, Click on Insert, Select Module - Copy paste the below mentioned script>>>
Function SpellNumber(ByVal MyNumber, Optional incRupees As Boolean = True)
Dim Crores, Lakhs, Rupees, Paise, Temp
Dim DecimalPlace As Long, Count As Long
Dim myLakhs, myCrores
Place(2) = " Thousand ": Place(3) = " Million "
Place(4) = " Billion ": Place(5) = " Trillion "
' Convert Paise and set MyNumber to Rupees amount.
End If
myCrores = MyNumber \ 10000000
myLakhs = (MyNumber - myCrores * 10000000) \ 100000
MyNumber = MyNumber - myCrores * 10000000 - myLakhs * 100000
Count = 1
Do While myCrores <> ""
Temp = GetHundreds(Right(myCrores, 3))
If Temp <> "" Then Crores = Temp & Place(Count) & Crores
If Len(myCrores) > 3 Then
myCrores = Left(myCrores, Len(myCrores) - 3)
Else
myCrores = ""
End If
Count = Count + 1
Loop
Count = 1
Do While myLakhs <> ""
Temp = GetHundreds(Right(myLakhs, 3))
If Temp <> "" Then Lakhs = Temp & Place(Count) & Lakhs
If Len(myLakhs) > 3 Then
myLakhs = Left(myLakhs, Len(myLakhs) - 3)
Else
myLakhs = ""
End If
Count = Count + 1
Loop
Count = 1
Else
MyNumber = ""
End If
Count = Count + 1
Loop
Select Case Crores
Case "": Crores = ""
Case "One": Crores = " One Crore "
Case Else: Crores = Crores & " Crores "
End Select
Select Case Lakhs
Case "": Lakhs = ""
Case "One": Lakhs = " One Lakh "
Case Else: Lakhs = Lakhs & " Lakhs "
End Select
Select Case Rupees
Case "": Rupees = "Zero "
Case "One": Rupees = "One "
Case Else:
Rupees = Rupees
End Select
Select Case Paise
Case "": Paise = " and Paise Zero Only "
Case "One": Paise = " and Paise One Only "
Case Else: Paise = " and Paise " & Paise & " Only "
End Select
SpellNumber = IIf(incRupees, "Rupees", "") & Crores & Lakhs & Rupees & Paise
End Function
End If
Else
End If
End Function
Case Else
End Select
Case Else
End Select
End If
GetTens = Result
End Function
End Select
End Function
>>>Save it as a file on the computer - Select the cell where you want to insert the function - go to Insert - Function - User Defined - Spellnumber - Select the reference value against my number and type true in incrupees.
It would give the value in Word format.
The limiation is it can be only use in teh same workbook.
Next time when you want to use the formula, either you have to redo the process or use this workbook and copy paste data in another one.
Let me know if you face any difficulty.
Feb 13, 2009 | Microsoft Excel for PC
Convert to Binary in Casio fx-82ES
dear kladofora thire is no 4:BASE-N in the mode please i need help Gist
Nov 25, 2008 | Casio FX-300MS Calculator
Computers & Internet Logo
179 people viewed this question
David Payne
David Payne
