Question about Whirlpool Washing Machines
Drain Water Pump impeller very loose in Whirlpool Duet Sport Model WFW8300SW0-should it be?
Drain Water Pump impeller very loose - is it supposed to be - noticed it when cleaning out filter.
2 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Posted on Jun 27, 2011
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirlpool duet sport with an error code F21. It is not a blocked drian pipe, and is making a noise with the pump.
check drain trap for restriction
If the drain time exceeds 8 minutes, the water valves turn off.
This error code is only shown in Diagnostic test.
Possible Causes/Procedure
- Ask the customer how much detergent they are using and if it is HE
detergent. May have too much suds present causing this condition.
- Turn washer ON to verify pump operates; run the drain cycle.
- Check the drain hose and make sure it is not plugged or kinked.
- Unplug washer or disconnect power
- Make sure that wire harness connections at the Drain Pump, Pressure SW,
& CCU (DP2, PR6 cavities) connectors are not broken or with wires detached,
and that connector internal pins are visible.
- Check continuity from the Drain Pump & CCU (DP2 cavity) connectors.
- Check continuity from the Pressure SW & CCU (PR6 cavity) connectors.
- If the continuity diagnosis failed, Main Harness must be replaced.
- Make continuity test to the Pressure SW. See page 8.
- Check the resistance of the motor pump. See page 8.
- Plug in washer or reconnect power.
- Run the drain cycle.
- If the failure continues, unplug washer or disconnect power.
- Check the drain pump filter for foreign objects.
- Disassemble the drain pump from the washer.
- Check that the impeller is not detached from the motor shaft. If the
impeller is detached from the shaft, is broken or has any scratches,
the drain pump must be replaced.
- Verify the unit operation by performing the Diagnostic Test cycle.
See page 5.
- After the diagnostic test has finished, unplug washer or disconnect
power and wait for 15 seconds.
Feb 15, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Wont drain
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 13, 2009 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Water not draing, F-21 warning flashing. Whirlpool duet
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appar until the pump is replaced.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Impeller - whirlpool duet front load
youll def need to replace the drain pump assy part number 280170
Oct 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washing Machine
Check your drain pump, or drain line for obstructions. The number one cause of insufficient drainage in this model washer is debris building up inside the clean out trap on the drain pump. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
Make sure you check all the drain lines as well. Another common thing that can cause slow drain issues are small articles of clothing getting caught in the drain hose that is attached to the bottom of the wash tub to the inlet side of the pump. It has happened to me on occasion to find socks, underwear and wash cloths lodged in this area. You can usually squeeze the hose to determine if there is anything blocking it. NOTE: In some models, there is a ball valve in the upper most portion of this drain line where it attaches to the wash tub. This is supposed to be there.
If anything has been lodged in the pump impeller for significant periods of time, this can potentially cause damage to the impeller and/or motor. This will affect pump performance. If clearing the pump and verifying that there are no clogs does not fix your problem, more than likely you have a drain pump that is beginning to fail.
If you find that you need to replace the pump, a replacement can be ordered on line at searspartsdirect.com. Just type in your complete model number and look for item number 10 (part #8181684) under the "Pump and Motor Parts" heading. The next link explains how to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
43 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
