Question about Water Heaters
Control board for whirlpool energy smart hot water heater
  • 21 Answers
SOURCE: Whirlpool energy smart water heater
Two flashes means that the high limit temperature has been reached. Once this happens, the temperature control system will shut off. Make sure that all element access doors are in place. Push the "Push to Reset" button to restart the temperature control system. The water heater will self test for ten minutes before it will start to heat. If you get the 2 flashes again then you may need to replace one or both elements. Each element should measure 5-25 ohms.
The "thermostat" is the knob marked "Temperature Control". Make sure that the operating mode is set to 1,2 or 3.
Posted on Jan 13, 2009
  • 11 Answers
SOURCE: cant reset or get lights on hot water tank or energy smart
I've worked on these before and most of the time it is the computer board which goes bad. I would check to make sure that my connections at the heater are good and that you have power up to that point. If you do then the board is bad and you will have to contact whirlpool.
Posted on May 25, 2009
  • 166 Answers
SOURCE: no hot water, control board light stays green
It may be bad thermostat terminals of the water heater, or, alternatively, the very top heating element is in need of replacement. See this handy diagnostic article for more info:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Heating_Systems_Water_Heaters_Cold_Water_Still_Released_Despite_Water_Heater.htm
Hope this helps.
Brad
Posted on May 27, 2009
gary1121
  • 332 Answers
SOURCE: Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
Posted on May 29, 2009
SOURCE: HOOKED UP WATER HEATER CANNOT GET HOT WATER
recently got a new water heater, we are not getting very much hot water and I think it is hooked up wrong. Cold water coming to the tank is in (H) spot on the heater and?? will this keep us from getting very much water???
Posted on Jan 03, 2010
I have a whirlpool water heater model 333j50rd045v no green light on control box and no hot water do have 220 into the unit the unit is about 12 yrs old
You have energy-smart electric water heater?
Control box might be bad.
Copy following link for troubleshoot manual, and whirlpool phone number for replacement parts etc:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Gene
Aug 22, 2013 | Water Heaters
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
Troubleshooting whirlpool ee2h50rd045v water heater
1) Copy following links for whirlpool energy smart resources:
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
2) Control box is probably bad.
There are 2 types of control boxes for older-style energy smart water heaters.
You will need model number and serial number from label on side of tank to order from Whirlpool.
3) This older-type energy smart water heater is probably discontinued by AO-Smith, American, State, Craftmaster, Reliance water heater group that makes Whirlpool and Kenmore water heaters.
New generation energy smart offers interface with home automation and/or non-existent smart grid.
Older energy smart only offered potential interface with non-existent smart grid.
Dec 23, 2012 | Whirlpool Water Heaters
How do I bypass the control board on a whirlpool energy smart water heater ?
I run out of hot water after one short shower. Lights looks normal. I have adjusted it every way I can, still the 50 gal water heater runs out after one shower. I have check the elements and are fine.
Jul 07, 2012 | Whirlpool Water Heaters
Energy saving devise light blinking and no hot water
Water heater is not identified.
Add a comment with information that appears on label on side of tank for possible help.
You might be talking about Whirlpool energy smart electric.
The error diagnostic lights flash a code: the code decipher is printed on the diagnostic control box on top of heater.
Call Whirlpool: you need model number and serial number from label located on side of tank.
1-877-817-6750
Open following links for energy-smart resources and typical manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Aug 04, 2011 | Whirlpool Water Heaters
Whirlpool 40 gallon energy smart elecrtic water heater. The control board binks once, by the panel means system start up failure,but we still have hot water,but every time we use the hot water it starts...
The evidence points to a control malfunction.
Call Whirlpool for assistance: 1-877-817-6750
You will need your model number and serial number located on label on side of tank.
Serial number is required because models change as the technology evolves.
Open following link to read product details about the Energy Smart, and download typical manual.
Note: Energy Smart water heater requires 10 gauge wire and 30 amp breaker.
Typical energy smart manual shows: 1 flash is start-up error, which indicates 'Power ON with no water in tank.'
This is not possible because at least the upper element would burn out, if not both elements.
If upper element burns out, this water heater will not make any hot water, since it is wired for ordinary non-simultaneous operation.
There cannot be air inside the tank since your hot water faucet is not spewing air.
http://waterheatertimer.org/How-it-works.html
Also be aware that model numbers change.
Read following account of fellow who replaced control board on his 4-year-old energy smart, and how he discovered wires are reversed on newer control boards. Be sure to ask Whirlpool about this possibility, in the event they say control board is faulty and send you new board:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Feb 27, 2011 | Water Heaters
2 green flashes. hot water is blazing hot set at 120 degrees.have the energy smart unit model#ee2h50rd045v . what is wrong?
2 green flashes is 'High Water Temp.'
Typical energy smart manual:
3 flashes is Temperature Sensor failure.
4 flashes is Upper element
5 flashes is Lower element
Troubleshoot section says:
1) Make sure access doors and insulation are installed.
2) Check elements for resistance of 5-25 ohms (if element has a short in center of element, it might not trip breaker)
http://waterheatertimer.org/How-to-test-water-heater-element.html
3) replace element and reset control system.
Buy ordinary 4500 Watt element from hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) I also suspect the self-diagnostic control box.
Manual says: Repair parts may be ordered through your plumber,
local distributor, home improvement center, or by calling
1-877-817-6750.
You need serial number, product number and model number from label on side of tank.
Jan 11, 2011 | Whirlpool Water Heaters
Cant reset or get lights on hot water tank or energy smart
Apr 19, 2009 | Water Heaters
Water Heaters Logo
874 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
