Question about Epson STYLUS OFFICE T1100 COLOUR INKJET PRINTER
Printer epson stylus T1100 selalu paper jam saat print best foto
  • 4 Answers
SOURCE: Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Posted on Aug 12, 2008
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
SOURCE: Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Posted on Jul 29, 2009
pineworks
  • 4041 Answers
SOURCE: Epson Stylus TX110 printer paper jam light flashing but no paper
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 28, 2010
shafaalifa
  • 6 Answers
SOURCE: printer epson stylus T1100 blinking,bagaimana cara
silahkan sedot di http://resetterprogram.blogspot.com itu adjusment pake bahasa rusia conek aja ke komputer terus klik reset
Posted on Aug 27, 2010
Print not clear, double struck, cartridges are new and sometimes paper jams
Paper Does Not Feed Correctly - Epson
https://files.support.epson.com/htmldocs/pho22_/.../trble_4.htm
EpsonPaper does not feed correctly when using the double-sided printing feature. If one of the ... The ink cartridges are not empty. ... If the error does not clear, open the printer cover and remove all of the paper inside, including any torn pieces. Then ... If yourpaper jams frequently, make sure of the following: ... Load a new stack.
Epson Stylus COLOR 600, Top FAQs - Technical Support ...
www.epson.com/cgi-bin/Store/support/supDetail.jsp?...FAQs...
EpsonThis link provides access to Top FAQs for the Epson Stylus COLOR 600. ... I just replaced an ink cartridge and the printer still won't print correctly. ... [ Answer ]; The printer is not producing any black or color ink. ... [ Answer ]; I'm only getting partial printouts or a "paper out" or "printer off line" error appears. ... How do I clear this?
epson printer problems ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/23851
I loaded a new black ink cartridge into my Epson Stylus C86. .... hit this problem when we first bought it, apparently it needs all colours to print ... i am using Epeon L 110 printer The colour print was good before But now the colour print is not clear ... No paper jams (sometimes paper feeds sometimes it doesn't). it appears that ...
Jan 05, 2016 | Epson Stylus NX420 Inkjet Multifunction...
Paper jam
Your having a hardware issue and you need to have it serviced.
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Mar 27, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus Photo 1390 Paper Jam
It PW sensor error. For "Normal Quality" mode, the PW sensor will not work for "reading" paper existence, but for "Fine", photo and best photo it work. PW is paper widht. Small sensor at bottom side of carriage, near the head. Dirty or short circuit may be.... Can you fix it?
Jan 13, 2013 | Epson Stylus 1400 InkJet Photo Printer
General error remove foreign objects inside the printer
Getting General Error Messege delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer
Jun 08, 2011 | Computers & Internet
While printing, the paper got jammed. I removed the paper completely, with out tearing the paper. The printer still states that an error has occured and to turn off the printer, check for jammed paper,...
my epson t13 doesnt feed any paper. when i was printing and run out of paper i put some paper on it but in dismay all of them feed all and it stopped. i tried to pull them out of the printer little by little. when i tried to continue my printing job it never feed any more. any help for this problem pls....
Apr 19, 2011 | Epson Stylus CX8400 Series
Paper jam error
Dear Sir,
I have Epson Stylus-1390 Photo Printer. Problem is when giving photo printing option thru printer driver printer get error is paper jam..
can you give me solution for the same.
thanks
Jan 09, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson cx4800 - will print in text mode but gives me a paper jam message in photo mode pape ris not jammed
It sounds like a driver issue. Have you tried to uninstall and reinstall the software on your computer?
Nov 02, 2008 | Epson Stylus CX4800 All-In-One InkJet...
No printer information
Follow these steps to set up your Epson product and install the built-in Windows Vista drivers:
  1. Set up your computer.
  2. Connect your Epson product to your computer.
  3. Follow the on-screen instructions that Windows Vista displays to guide you through product driver installation.
You need to use a program that can do printing multiple pictures in just one click.
Feb 05, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson STYLUS OFFICE T1100 COLOUR INKJET PRINTER Logo
486 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
