Question about Epson PX730WD Stylus Photo EPSON
Printer PX730WD when I switch on it says printer error. All I can see wrong paper drawer does not close tightly and cover does not close
With 2 drawers, when you close the door tightly, it pushes open the top drawer, so the printer feeds from the incorrect drawer
take both drawers out and find the bit of rubbish blocking it up
a bit of paper or a clip or a staple is stuck in a seem ,,, or runner
Mar 05, 2015 | OKI B4600 Laser Printer
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Will not print. Error message saying Lexmark x2250 printer saying cover not closed when it is
open the cover
there is a switch that the cover has a lever to press its embedded inside the machine with a small opening above it where the cover lever inserts to press it down. chances are its broken. take a stick or piece of tightly folded paper and press it in you will see it says the printer cover is closed. See if you find the broken part and stick it back on the cover, replace the cover or simply wedge the switch in place .. any of those will fix your problem.
Jan 09, 2011 | Office Equipment & Supplies
THE PRINTER IS INDICATING A PAPER JAM, THERE IS NO SIGN OF PAPER, THE DRAWERS ARE ALL CLOSED TIGHT
Paper light flashing could mean a few things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 05, 2010 | Brother HL-2040 Laser Printer
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
Copier doesn't recognize that paper is loaded
Hello sir; Make sure you close drawer tight then pay attention on listening the noise when you close the drawer, if quiet that's mean paper lifting motor defect, otherwise go to paper sensor.
Aug 05, 2009 | HP Office Equipment & Supplies
Alarm on continuously!
please try to reinstall the printer drivers
Feb 13, 2009 | Citizen IDP3541 Matrix Printer
Cannot close middle front drawer
you have to take off the left side cover and you see 2 gears close to the middle of printer, those have to be turned to release the clutch for the drawer. The drawer should now slide in.
Nov 18, 2008 | HP Color LaserJet 4500n Printer
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
Paper Jam Errors
switch off power to printer and switch on again, worked for me
Jan 14, 2008 | Dell 3100cn Laser Printer
Epson PX730WD Stylus Photo EPSON Logo
183 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
