I have a Denon PMA 350 amp and I get a crackling in the right speaker when using the CD player(which is new) and the tuner but not my ipod which is plugged in to the auxilary socket. Will it do any harm to try plugging the CD into the tape sockets to try and solve the problem?
  • 1153 Answers
SOURCE: Not outputting to all speakers from CD, but does from DVD
Sounds like a selector setting change. If you are 100% sure that when it was working correctly the setting that was use, you are using it now then I would suggest getting the manual and check all settings. Surround Sound and different kinds of hall, SS, theater, etc can change the sound and what speaker plays when.
Posted on Apr 17, 2008
robotek
  • 1512 Answers
SOURCE: headphone socket
Hi twelvetwelve
Are you able to get access to the rear of the socket and use a small screwdriver to push out the parts of the plug that have come adrift inside the socket? You may have to actually remove the socket from its PCB to get access. If you cannot remove the offending parts, then you may have to replace the socket. There is not alot more that you can do unfortunatly.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
robotek
  • 1512 Answers
SOURCE: i have a phonic powerpod
Hi, a couple of questions for you. What pin connections have you made for the cables in the wall. are you using 2 core plus braid mic cable?
Please let me know and we can go from there.
The loud screeching noise you are experiencing, may be too much gain. Start with everything turned down, and work your way back setting levels to about 5-6 from the master level first. The channel gain at the top of each input strip should be you last adjustment.
regards
robotek
Posted on Jun 09, 2008
micromaster
  • 3614 Answers
SOURCE: CDX-CA600X Audio in sockets
Ok.. i got the post, please wait while i look into the details on the cd player that you have there...
Thanks
I will post in here again
micro
Posted on Jul 16, 2008
dunnbiker
  • 8546 Answers
SOURCE: Yamaha Natural Sound Amp and Tape Player
All of this applies to nearly any analog consumer audio gear...
If you have any Tape Deck and an Equalizer and only the one Tape Monitor loop you should place the EQ into that Tape Monitor loop, then place the Tape Deck onto one of the probable two Tape Monitors on the EQ as it sounds like you had here...
"When I had it set up with the graphic equaliser,pressing tape monitor on the amp and on the equaliser gave me play backfrom the tape player."
That setup will allow you to apply EQ to any analog source and the tape deck in record or playback mode.
However, if you want to remove the EQ and use the Tape Deck directly on the Tape Monitor just attach the deck's Playback cables to Tape Mon In (Play) and the deck's Record cables to the Tape Mon Out (Rec). Flip the Tape Mon control to hear the tape deck or monitor it while recording.
NEVER plug anything but a turntable into the Phono. It has a preamp that expects a ver ysmall signal from the cartridge AND it also has a severe RIAA Equalization curve which would result in grossly exaggerated frequency extremes if you managedto get a non-LP source into it. Likewise, turntables without internal electronics mut always use the Phono section of a receiver, preamp or integrated amp to get the boost and EQ they need.
Posted on Apr 05, 2009
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Why can't I get my turntable to sound right on my
Turn table? You mean like records? lol
The output of record players is different voltage than like cd players, etc...
Does your stereo have input for turntable or are you hooking it up to an extra rca input? I had mine hooked up wrong before and it did same thing.
Dec 11, 2011 | Denon Audio Players & Recorders
Deneon PMA-250 amplifier -Volume knob not working correctly
Well, it seems you have your finger on the source of the problem. If accessible, try some tuner cleaner inside the potentiometer.
Mar 05, 2010 | Audio Players & Recorders
Denon Amp (PMA-700AE) ignores the signal from CD Player DCD-700
If you can follow the circuit from the input of the cd play socket inside the amp itself you might come accross a Memory Retention Capacitor that supplies an IC. If you do. I can't for certain say one will be there, I would replace it, it might be the cause of the lost memory of your device.
If you don't know what a M R C looks like, they are like electrolytic types, but haven the appearance of being squashed. The value will be low only 0.22uf etc and the volts very low say 5.5. The PC board marking will be different to a normal capictor.
Nov 14, 2009 | Audio Players & Recorders
I am trying to connect a Kenwood CD Player to the Denon amp. I am using normal av cable and connecting the output from the CD player to the ''CD'' jack of the Denon amp (no 2). I am not able to get the...
I agree with this answer:try to connect the CD Player output to the working input on the Denon Amp( say tuner remove it temporarily).
try if it works, then you have a good CD player
if not check if there is volume available on CD player , turn it a little bit higher, using remote control
check if the CD is reading the disk
check also the connector you are using
check if there is a known working CD audio inside the player
if still having problems state the model of your CD player
hope this helps, thanks for using Fixya!
Aug 22, 2009 | Kenwood Audio Players & Recorders
Crackling sound from denon avr 2106
I think you may have a blown speaker.
Sha'ul
Jun 25, 2009 | Denon AVR-2106 Receiver
DENON Input selector jumps randomly
I have a PMA-535R. Same problem but slightly different dialknob. I fixed it by spraying a contactspray and WD-40 into the knob itself. This does mean you have to disassemble the front of the amp and take out print of the dialknob. The knob has a plastic dustcovere that you will have to lift. Good luck
Sep 18, 2008 | Audio Players & Recorders
Static from right from speaker
The noise is in the pre-amp stages of the Denon AVR. It might be caused by bad capacitors.
Mar 08, 2017 | Denon AVR-1803 Receiver
 Grubhead
Grubhead
