Question about Vizio VSB210WS Soundbar
Humming noise from my vizio sound bar
Humming noise
2 Suggested Answers
SOURCE: new vizio tv and vizio
get to your menu on the tv and click your audio, go down to speakers and turn it to the off position.
Posted on Dec 04, 2011
Vizio Sound Bar Siren Noise
Audio output section circuit fault. Contact any service technician.
Aug 02, 2015 | Vizio High-Definition Sound Bar VSB200
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
Subwoofer is hummig what is this noise
Hum is a constant low-frequency buzz, usually at about 60 Hz or 120 Hz, which results from voltage differences between true "ground" (what you'd get shoving a copper pipe into the ground) and the electrical "ground" of your receiver's chassis When this voltage differential exists, it's called a "ground loop," and the hum it produces is darned annoying. You'll hear the hum mainly from the subwoofer because it's a low-frequency noise, you will need a ground loop insulator they are about $20 at any electronic store
I have hum bars on my televisions just the vizios i have 3 other televisions and they are perfect
Hum Bars are caused by electrical interference. If you have other equipment hooked to the vizio such as a VCR, try unhooking the VCR and hooking cable directly to the tv bypassing the VCR. If you have a Cable signal amplifier hooked up that also can cause interference if it is going bad. Some tv's can handle the negative interference better than others. You could also try moving another tv into the room where the vizio is and see if that gets hum bars as well. In this situation the process of elimination is the best method. If it goes away using a different tv then it could be the vizio. If a VCR is the problem your best bet it to leave it unhooked. If an amplifier is the issue try it without the amp hooked up. Now with the change over to digital you may not need an amp and can leave it disconnected. If Not you can easily replace the amplifier. If these don't work I would suggest contacting your cable provider so they can properly assess the electrical problem and assist you in fixing the issue before causing and damage to your equipment.
Jul 09, 2010 | Vizio VX20L 20 in. LCD TV
I have a new tv, a Vizio model VL370M and there is a humming noise when I am using standard definition. It is present also when I use a DVD player. It is not the cable box. A Vizio repair man put in two...
If you can handle it then check the 12VDC supply filtration. I mean to say that you have to confirm that the 12VDC is coming with stability and no noise inside it. The filtration work is being performed by the capacitors in the circuitry. Check the capacitor condition in main board please. If it is plague (bad capacitor) then try by replacing it. The sound can be mainly heard through speakers and it most probably caused by sound processing area presents in main board. This kind of thing can be eliminated by changing the main board.
good luck
Feb 02, 2010 | Vizio L37 Television
Humming sound vizio
99 percent of the time the humming can only come from a defective powerboard, before it dies, you should consult your warranty. Otherwise you can order the parts and replace yourself.
Jun 01, 2009 | V, Inc. VIZIO RP56 Rear Projection...
My lcd tv makes a humming noise
My 37 inch vizio did the same thing. go to your menu screen on the tv and go sound. My tv has an option to turn speakers on/off. Once I turned my speakers off and the back on again everything worked great. hope I helped! if I did please let me know! youtube.com/xniax1
Mar 21, 2009 | Vizio VW37L 37 in. LCD HDTV
Vizio 42'' HDTV flatscreen
The TV usually hums when the backlight setting is too low. So turning it up should get rid of the problem. To do this please follow these instructions:
1. Turn the TV on.
2. Press the Menu button on the remote, located right below the channel changing button.
3. Press the down direction button, located at the middle of the remote. Press that button until the backlight is highlighted.
4. Press the right direction button until the backlight is at 100.
5. Press the OK button and then the Exit button until you get back to your picture.
Oct 22, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VSB210WS Soundbar Logo
67 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
