Question about Plumbing
How to replace the spray hose from water ridge Lola pull down kitchen faucet
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: delta kitchen faucet mixed spray...diverter problem???
No a pull out sprayer problem is different.
First try this. Pull out the sprayer and remove from hose by turning nut that connects sprayer to hose. If you can get someone to help you it would be nice since the hose can go down into the faucet and might be trouble to retrieve. Look in the connection on the sprayer where the hose connects and look at the screen. If the screen is plugged or dirty clean and reinsert. If you can't clean it replace it. If this isn't working go to the next suggestion below.
In the spray head of the faucet there is a build up of deposits from use and or water hardness. Here is the link to the Delta site.
Delta Faucets
If you find you faucet model order a new spray head. Once these go bad they usually need replacing.
Hope this helps and please rate this!
Posted on Dec 09, 2008
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
SOURCE: Replacement Price Pfister sprayer/hose
I called Price-Pfister and they sent out the parts free under their warranty, plus a few dollars for postage.
Posted on Apr 26, 2010
SOURCE: Water Ridge Kitchen Facet with attached sprayer w...
You will ned to contact WaterRidge and have them send a Cartridge which you will have to replace. Their products are warrantied for life, so they should send it at no charge. The Customer Sevice # is 1-866-789-2273. You will need the Model # so they can send you the correct cartridge. I am trolling the web for replacement instructions, so I'll let you know if I find some.
Posted on Sep 06, 2010
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
Wateridge Olivia. Where can I get a manual?
Customer Reviews: Water Ridge Pull Out Kitchen Faucet
www.amazon.com/Water-Ridge.../B00O2AGROM
Amazon.com, Inc.The older Water Ridge faucet had a 6 page manual; it seems the company .... me a new Olivia Pullout Kitchen Faucet by WaterRidge' Dual Function Spray Head ...
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed ...
? 3:21
https://www.youtube.com/watch?v=wsreMTL_whc
Apr 19, 2013 - Uploaded by HillBrosReviews
REVIEW: Costco WR Water Ridge Pull Out Faucet Brushed Nickel .... gave me a new Olivia Pullout Kitchen Faucet byWaterRidge' Dual Function Spray ... They sent a hose... with nodirections how to replace the defective one.
Dec 18, 2015 | Plumbing
How remove handle for water ridge farcet nsf 61/9
On a water ridge kitchen faucet, there is a brass fitting that the water supply hose going to the faucet you pull out connects to under the sink, on that fitting youll find a small screw loosen it up, pull the fitting off , also loosen the other screw and disconnect the hose, now look inside the fitting there is some plastic junk ( not sure what its for) get a screw driver and a hammer and bash it out(not to hard) then put it back together. good to go, full pressure!! worked on mine and has for 2yrs.
Oct 20, 2012 | Plumbing
Do I have to remove the entire Delta kitchen faucet in order to replace the pullout faucet hose? If not, can you give me step by step instructions on how to replace it? Thanks.
Should be able to turn water supply off to faucet and trace the line connecting the pull-out faucet. Remove weight in center on hose line this weight helps retract the faucet head in with the line. Remove it and disconnect the line connection and remove the old one.
Feb 14, 2011 | Delta Faucet 470-DST Signature Diamond...
Low water pressure
Remove the spray head and point the hose into the sink drain. Turn the faucet on. If you have good pressure, cal American Standard for a free replacement spray head.
If you still have low water pressure without the spray head, ask them for a new faucet cartridge.
After replacing the faucet cartridge, if you still have low water pressure you will need to ask for a new faucet, possibly free if yours is still under warranty.
Sep 07, 2010 | American Standard Kitchen Faucet 6310 020...
We have a Delta kitchen faucet with a pullout sprayer everything was fine for over a year then it started making a bang bang rattle sound very loud only when the hot water is on it only does it about ever...
Delta comes with a limited lifetime warranty. call them to get free parts. I believe you will need to check several things. Remove the spray head from the sprayer hose, point the hose into the sink drain and turn the faucet on. If it no longer makes the banging noise, replace the spray head. You need to look for a leaking spray hose under the sink also. If the faucet is making noise, replace the ball and cam assembly under the faucet handle. One other thing that I have run into is that the shut-off valves under the sink can also go bad and cause banging and vibration.
Sep 06, 2010 | Delta Model 470: Signature Kitchen...
Need to take the hose assembly out of delta 470 faucet
you need to disconnect from under the faucet and then pull it all the way out just like if you were pulling it out to use the spray. There may be a big weight on the hose to help it back into the spout when placing the head back....you will also have to take that off to pull it through.
Oct 04, 2009 | Delta Faucet 470-DST Signature Diamond...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
Delta kitchen faucet mixed spray...diverter problem???
Delta Faucets
Dec 07, 2008 | Delta 473-WHSD-DST Saxony Diamond Seal...
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
90 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
