Question about Astoria Argenta AEP-2 Coffee Maker, Espresso Machine
I need a new pressure guage for an Astoria A2 - coffee machine
The pressure gauge no longer works and we need to replace it
The machine is an A2 Astoria with pull levers for the two group heads
We operate in and around the Sheffield area - England
    Novelist:
  • 137 Answers
Here is the site where you can get your presure gauge and other parts for your machine.http://www.espressoparts.com/results.cgis?catalog=&select=NAME&keywords=astoria+pressure+gauge&image.x=15&image.y=14
Posted on Mar 30, 2009
Waterpump makes a lot of noise
It is possible that the water coming into the pump from the mains is obstructed. If you have a water filter, that might need to be replaced. Some of the pumps have a stone filter on them, you will see a huge nut on the inlet side of the pump, that might need to be cleaned. Also check all water lines make sure you have no kinks. Pay attention to the gauge on the machine when the noise is happening if the water dispensing pressure lever should be at about between 3-6 bar when not being used and about 9 when brewing espresso.
Feb 19, 2014 | Faema Smart A2 Automatic Espresso Machine...
Steam wands on espresso machine wont work
There should be a boiler pressure and water pressure guage. If there is no pressure on the boiler guage that could mean a heating element or pressure stat problem.
www.kaldi.com
Jun 12, 2010 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
Maximum water supply pressure
About 3 bars, not more that 5 or you will need to install a pressure regulator on the line.
Apr 10, 2010 | Astoria Argenta SAE-2 Espresso Machine
My 2 group astoria over steams from top of boiler.it warms up then in about half hr steam shoots out at the preasure valve doicky do i need a new one of those thanks greg
The pressure releive valve is pre-factory set to open if the pressure in boiler reach between 1.6 to 1.8 bars.
So either you have the presure switch (presostat) not working normal which supose to switch off the electrical element at 1.2 to 1.3 bars.
So look at the presure gauge at which presure the presure releive valve open and releive the steam out from boiler if it shown more than 1.5 bar the you need to check the presure switch since it does not switch off the heating element.
If the presure releive valve open below 1.5 bar then you need to replace the releive valve.
Good Luck
Mar 23, 2010 | Astoria Argenta SAE-2 Espresso Machine
Boiler has quit working
Check to make sure that there is water in the boiler by either checking the sight glass then rocking the machine to see if the water level bobs up and down, then check the thermal reset switch on the left side of the machine above the element. Make sure there is water in the boiler before pressing reset and turning machine to number 2. After machine heats up make sure pressure does not go past 1.5 bars on the gauge. If it does then the p.stat needs to be replaced.
Nov 01, 2009 | Astoria Argenta SAE-2 Espresso Machine
Just set up a recently purchased used Astoria argenta single and can't get a thick Espresso
Try adjusting the grind on the grinder to a finer setting, and make sure that the machine ins producing about 9 bars of pressure on the water pump(check bottom gauge on manometer).
Feb 19, 2009 | Astoria Argenta AEP-2 Coffee Maker,...
I'm looking for Elektra S1 Owner.s manual
if you have 2 gauges, one shows from 0 up to 3 bar second from 0 up to 16 bar.
  1. the gauge o - 3 shows steam pressure and it should be from 1.1 up to 1.5 bar
  2. if you have second gauge you look it during brewing coffee, it should be from 7 up to 9 bar(it shows the pressure of pump.
anyway becouse it is old machine you should compare the gauge with new one(ehamle for the steam attach to steam pipe one gauge and live valve open) than you will know if it is showing true values.
Nov 23, 2008 | Elektra Microcasa S1 Coffee Maker,...
Hot water no steam low psi
Boiler pressure gauge should be showing in the green zone which should get you 195+ degrees.
Nov 17, 2008 | Astoria Argenta SAE-2 Espresso Machine
Older machine needs repair
When you press the dispense button does the needle on the dispensing pressure gauge move up to the green area? If so, most likely your group head solenoid valve is bad. It's located behind the back splash. It's a small black box connected to a metal tube just behind the group head. They cost around $70.
If the needle doesn't move it could either be your pump or motor. Now you're in the $200 range.
Jul 06, 2008 | Astoria Argenta AEP/JUN Coffee Maker,...
Astoria Argenta AEP-2 Coffee Maker, Espresso Machine Logo
184 people viewed this question
Top Astoria Coffee Makers & Espresso Machines Experts
Charles T Nevin
Charles T Nevin
J.D. Browning
J.D. Browning
NOEL
NOEL
Are you an Astoria Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
