Question about HP EPPSC4380PHOTOTRAYAS PhotoSmart C4380 All-in-One Printer Photo
Continuous paper jam on hp c4380 printer
I have checked the printer thoroughly and can find no paper or paper fragments in the mechanism. Any suggestions
5 Suggested Answers
  • 58 Answers
SOURCE: paper jam - hp c4380
Make sure that there is no paper stuck inside the paper, try cleaning the rollers, if the issue stil persit perform the below steps. Reset the All-in-One to the factory default settings by using these instructions: 1) Press ON and CANCEL buttons simultaneously 2) Display reads ?Enter Special Key Combo? 3) Press BLUE button, Green button and Grey button 4) Press Grey button continuously until "Resets Menu" is displayed. 5) Press Green button. 6) Press Grey button until "Semi full Reset" is displayed. 7) Press Green Button. This should resolve the issue.
Posted on Sep 27, 2009
  • 1218 Answers
SOURCE: HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Posted on Nov 04, 2010
SOURCE: Paper Jam HP OfficeJet 8500
etechrepair.jpg Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
Posted on Jan 19, 2011
khanartist81
  • 80 Answers
SOURCE: paper jam cleared no tears message still appearing
When you turn off the printer unplug it from power and the computer for a few minutes. Plug only the power back in and turn it on. Also consult the manual to find out how to "reset" your printer.
Hope this helps
Posted on Mar 08, 2011
Paper jams frequently
Use a flashlight and check the paper path thoroughly. You may find bits of old paper, dust and debris. Perhaps a thorough blowing out with compressed air will help. Also, the paper feed mechanism may be damaged or worn.
Sep 11, 2012 | Dell MFP 1815dn,Laser fax copier printer
I tried to replace the feeder of cartridge, then i open the mechanism. after complete the work, i saw paper should not properly feed. so how can i solve the problem ?
Make sure that there are not any paper fragments in the machine, this will cause the paper to either jam, or the paper not to feed properly. You should also take the paper that is in the machine out, fan it to separate it, and then put it in the machine. If that is to no avail, then try new paper, following the same instructions as mentioned above. You may also need to adjust the paper sizer mechanism as well.
Mar 07, 2011 | HP PSC 1410v All-in-One Printer
Nov 04, 2010 | HP Officejet 5610 All-In-One InkJet...
HP P2015 Intermittent paper jam lite on solid.
Remove the covers and thoroughly clean the inside of your printer. Vacuum it out and wipe it down. Then examine the sensors and their wiring connectors. Intermittent problems are difficult at best. I suspect a thorough cleaning will eliminate it.
Nov 09, 2009 | HP LaserJet P2015 Printer
I had a paper jam and cleared it. Now the power light and paperfeed light are on and won't go off. I cannot print nor turn off the printer via the buttons. I have reinstalled drivers, opened the back panel...
What precisely IS the error message? In lieu of this information, unplug the printer. Check the paper path thoroughly including between rollers. Any tiny fragment will jam. Use a falshlight and magnifier if you must. Load with normal thickness printer paper. Plug the unit in. Hold the power button down for 10 seconds. Test page should print.
Oct 21, 2009 | HP DeskJet 1220c InkJet Printer
Paper jam - hp c4380
Sep 27, 2009 | HP Office Equipment & Supplies
Paper Jam error with no paper ...
Put your hand in and poke at the front and poke all the levers and move things around a bit it sounds like a stuck switch and poking them normaly frees them up.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Paper Jam, Clear jam
This may be caused by a dirty sensor. Disconnect power supply, open the printer and clean everything. You may use toilet paper. Be careful not to leave fragments of toilet paper inside the printer.
May 06, 2009 | HP 5510 4-in-one Printer
PAPER JAM WITH NO PAPER
May 05, 2009 | HP PhotoSmart C4180 All-in-One Color...
HP EPPSC4380PHOTOTRAYAS PhotoSmart C4380 All-in-One Printer Photo Logo
102 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
