Question about Reliance 6 50 DORT 606 Series 55 Gallon Electric Water Heater
Reliance 606 water heater will not drain
Followed drain procedure but will not drain.
  • 832 Answers
SOURCE: Our 606 reliance electric hot water heater has the
We will just assume that "a" is the lowest temperature
to correspond to 120 degrees, while "c" for 160 degrees.
So try setting it at "a" and feel the hot water that flow.
Or it could be the other way. Just feel the hot water that
flow. It will be done in a few minutes. I hope this will help
you.
Posted on Nov 27, 2009
  • 71 Answers
SOURCE: My Reliance 606 40 gallon water heater only heats
How big is your bathtub? Is your water heater set on the hottest setting? What is the temperature of the hot water at the tap?
Keep in mind that hot water can cause severe burns. Children and those with diminished mental capacity can be seriously harmed by hot water.
The "40 Gallon" rating on the water heater is usually the amount of hot water the unit can produce in one hour. So the tank, and the amount of immediately available hot water, might be smaller than 40 gallons.
My bathtub is 2 feet wide by 1 foot deep and 4 feet long. This is 8 cubic feet or almost 60 gallons. So a 40 gallons of water at 120 degrees, mixed with 20 gallons of cold water (60 degrees), fills the tub with 100 degree water. My January cold water is 42 degrees, so it will take 40 gallons at 129 degrees to fill the tub. If the tub is cold to start it will take even hotter water.
So the water heater might be just fine.
Possible solutions:
1. turn the temperature up on your water heater- or the temperature control could be malfunctioning and not getting the water hot enough.
2. insulate your hot water pipes so that the water loses less heat on the way to the tub.
3. bigger water heater.
4. smaller bathtub, or less full bathtub.
Posted on Jan 04, 2010
  • 82 Answers
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Posted on Jan 31, 2010
SOURCE: Pilot won't stay lit in Reliance 606 gas water heater
The Reliance 606 has an enclosed thermal couple. Before you try taking that assembly apart take a wire brush to the bottom opening directly under the burner. There is a metal filter on the very bottom of the water heater. It could be that the filter has gotten filled with dust or animal hair. It took a serviceman 2 days to figure this out for me. The water heater has to have good airflow through that filter to work well.
Posted on Sep 29, 2010
SOURCE: how to change a thermostat on reliance 606 hot
I wrote a page for changing water heater thermostat.
The photos take you through step-by-step
I recommend replacing both upper and lower thermostats so it eliminates thermostats as possible cause if water heater keeps overheating.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
The Reliance 606 manual shows your water heater uses generic upper and lower thermostats from hardware store.
http://www.reliancewaterheaters.com/lit/om/manuals/185761-000.pdf
Likely the thermostat will solve the problem:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Posted on Nov 10, 2010
Hot water tank wont heat water, how do you relight or resat, its a reliance self cleaning 808
Reliance Water Heater Literature ' Owner's Manuals ...
www.reliancewaterheaters.com/resources/instruction-manuals
Welcome to the Reliance Water Heaters Owner's Manual and Installation ... 9 40 EKRT - 40 Gallon Tall Self-Cleaning Electric Water Heater - 9 Year Warranty . ..... 10 50 DHPST - 50 Gallon Electric Heat Pump Water Heater - 10 Year Warranty .
How to light the pilot on a Reliance 606 water heater ...
? 3:27
https://www.youtube.com/watch?v=VU2PsFVd2ug
Jul 12, 2011 - Uploaded by kilroywashere123
How to light the pilot on a Reliance 606 water heater ... How to fixwater heater, will not stay lit - sealed combustion no hot water - Duration: ...
Reliance Water Heaters - Consumer Affairs
www.consumeraffairs.com > Homeowners > Bath & Plumbing
Rating: 1.6 - ‎84 votes
I purchased a Reliance 606 water heater in 2010. ... That they don't TELL you there's areset button or that I'm having conspiracy thoughts ... After several attempts, I was able to relight it. ... It's heading to the junk pile and I will purchase a new reliable (NotReliance) ... Checked breaker and changed breaker still no hot water!
Dec 28, 2015 | Reliance Water Heaters
HOW TO REMOVE ANODR ROD FRO 606 RELIANCE
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either magnesium or aluminum depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water. To remove you need to turn off the electric, shut the water supply and drain off some of the water so it wont overflow, then it simply unscrews. Use teflon tape or sealer on the thread before installing the new one, then turn everything back on and purge the air from the system by opening a faucet.
Sep 23, 2014 | Reliance 606 Series 40 Gallon Electric...
The reliefe valve opening on my reliance 606 gas water heater is hissing. what could be wrong?
thermostat.Check Settings,and if you turned it up or down while power was still on, thenchange them both. also t+p valve may be weak from temp overshoot.Change it if it continues after replacing thermostats
Aug 21, 2014 | Reliance 606 Series 40 Gallon Natural Gas...
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add comment and say what you tried so far.
Include age of water heater.
Jan 05, 2013 | Reliance & LP Gas Water Heater Control
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
I NEED DIRECTIONS ON HOW TO DRAIN A RELIANCE 606 30 GALLON GAS WATER HEATER
Here is the link for the users manuals for the RELIANCE 606 30 GALLON GAS WATER HEATER, depending on the style you have - tall, short, etc.
http://www.reliancewaterheaters.com/lit/om/g606.html
Oct 02, 2010 | Water Heaters
Feb 13, 2010 | Reliance & 50gal Electric Water Heater
My reliance 606 water heater drain valve is leaking..what size do I need to replace it
You are going to have to drain it anyway. So drain it and take the old one with you to get a new one. In case you don't know turn the breaker off before you drain it. If you don.t you will melt the heating elements. They get too hot out of water.
Jan 06, 2010 | Reliance & Drain Valve for Gas Water...
Reliance 6 50 DORT 606 Series 55 Gallon Electric Water Heater Logo
20 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
