Question about IBM ThinkPad R30 2656 Notebook
IBM R30 2656 with 10G hard drive
The hard drive is almost full. I want to replace the drive with a larger one. What is the biggest drive this machine will support. I think the biggest drive they offered the R30 with was 30G. Can I go bigger?
IBM thinkpad R51 won't boot and the blue screen with unmountable-boot-volume comes up and i cannot bypass it.
Sounds like at least a corrupted OS, but most likely a bad hard drive. I'd try reloading Windows (if that's your OS) first, which should take well under an hour; if reloading takes excessively long, then the system is probably having a hard time formatting the hard drive due to physical bad sectors and the easiest thing would be to replace it. The R51 uses good old ATA/IDE 2.5" 9mm height hard drives, which are not available in most stores any longer, but you can probably get the same size or larger ones on eBay for pretty cheap and replace it yourself. Expect to pay about 50 cents to 75 cents per gigabyte - anything more would be considered tourist prices...
Sep 01, 2011 | IBM ThinkPad R51 Notebook
I bought this machine refurbished from and it came with a 40GB hard drive. When i try to put a larger one it and install windows it recognizes the hard drive but after copying files is done, it...
This machine can't use a hard drive larger than what it came with.
This is a very old machine and won't be able to run anything more than Windows 2000.
About the only thing that is current and will run worth a darned is Linux. With Linux you'll be able to use the larger hard drives as well.
Dec 24, 2010 | IBM THINKCENTRE A50 - P4-3.0GHZ/1MB 800MHZ...
I want to upgrade my Fujitsu MHV2040AH 40 GB Hard Drive what is the biggest/fastes one i can replace with? i though i found another one but it doesnt have the right connectors. the fujitsu/toshiba site...
Your Fujitsu MHV2040AH is an IDE 2.5" 5400 rpm 40 GB hard drive.
Most Notebooks nowadays will use 2.5" SATA hard drive which is not compatible with IDE.
New IDE are getting harder to find and are therefore in general more expensive to buy than the equivalent SATA
You should be able to update the drive with most 2.5" HDD with either 5400rpm or 7200rpm (faster) with an IDE interface. Common 2.5 IDE capacity would be 120Gb and 250Gb (320GB and 500GB are also available but could be a bit expensive). The important factors are physical size to fit in your notebook/casing and IDE interface. The BIOS support for larger drive can also be a factor but as a rule, worst case situation, a larger capacity drive can always be used at a lower capacity
Hope it helps.
Dec 15, 2010 | Fujitsu MHV2040AH (HDF40000IAH) 40 GB Hard...
Wat is the maximum hard space that a IBM thinkpad t22 can have
> maximum
The maximum is 500 GB (for the older-generation of IDE-interface disk-drives), since nobody makes IDE drives larger than 500 GB, or 2000 GB for the new generation of SATA disk-drives.
Sep 21, 2010 | IBM ThinkPad T22 2647 Notebook
IBM T42 gives Fan Error message and stops
The fan may be faulty or clogged with dust.
Check the fan to see f it spins freely and remove dust from the heatsink fins and fan assembly.
The specification in the manual for the T40 series shows the largest hard drive is 80 Gb.
It may be possible to install a larger hard drive, but check with Lenevo first.
May 25, 2009 | IBM ThinkPad T42 Notebook
Drive got deleted
hi, you could either replace the hard drive for a larger one or invest in an external hard drive, these are really cheap at the moment and you can purchase a 1TB (1000gb roughly) for less than £80. i recommend ebuyer, fast delivery and value for money. (can i plug ebuyer?)
May 02, 2009 | IBM ThinkPad G40 Notebook
Processor and Disk space
The biggest processor available for the T20 is 1ghz. Be sure when replacing the processor that you get an IBM 133mhz processor. The memory is 1g max, the machine will hold two 512mb chips, and be sure that it's PC133 memory. You can put up to a 120g hard drive in the machine, be sure the hard drive is an IDE 4200rpm drive. These are the specs for the T20, and the maximum size this machine will hold. You can go to this max or anyplace in between.
Aug 27, 2008 | IBM ThinkPad T20 2647 Notebook
Password reset for IBM A21m
This generally indicates a failed hard drive, or on occasion, a failed motherboard component. Try reformatting the hard drive and installing a new operating system. If the drive will not format, using a full NTFS format, not the quick format, then the drive has failed and will need replaced. If the machine won't allow you to get to the boot menu to do the format/install, then the security chip on the motherboard has malfunctioned. Unfortunately, the security chip will be an issue that you will either have to send it to IBM to have fixed, or replace the motherboard.
Aug 09, 2008 | Computers & Internet
Ibm 600x .... cannot detect hard drive larger than 2.1gb .. it can detect 2.1gb below ... i installed winxp on 2.1gb .working fine
ibm is providing their computer with a relevant bios updtes . bios updte will solve most of this type of problems
Dec 02, 2007 | IBM ThinkPad 600X Notebook
IBM ThinkPad R30 2656 Notebook Logo
282 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
