Question about Cisco Aironet 3602i Wireless Access Point AIRCAP3602ICK9
Deployment of Cisco aironet 3602i as standalone AP
How do I deploy my Cisco aironet 3602i AP without using a controller?
  • 5 Answers
SOURCE: configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Posted on Jun 19, 2008
  • 5 Answers
SOURCE: Cisco Aironet 1200
if u have an cisco acs and windows AD, i'd configure the ap to point to acs and configure acs external db to point to AD. let ur windows dhcp server hand out IPs to your mobile devices.
SOURCE: how to reset Cisco Aironet 340 Wireless bridge?
Aironet 340 Series Bridge For Software Version 8.65 or Later If you forget the password that allows you to configure the 340 bridge through the console port, you must completely reset the configuration. Complete these steps in order to delete the current configuration and return all settings to the factory defaults:
  1. Use a straight-through cable with 9-pin male to 9-pin female connectors in order to connect the COM 1 or COM 2 port on your computer to the RS-232 port on the bridge.
    For more information, refer to the Cabling Guide for Console and AUX Ports.
  2. Open a terminal-emulation program on your computer.
    Note: These instructions describe HyperTeminal. Other programs are similar.
  3. Enter a name in the Connection Description window.
  4. Select an icon for the connection.
  5. Click OK.
  6. In the Connect To window, use the Connect using pull-down menu in order to select the port where the cable is connected.
  7. Click OK.
  8. In the Port Settings window, make these selections:
    • Bits per second (baud): 9600
    • Data bits: 8
    • Parity: None
    • Stop bits: 1
    • Flow Control: None
  9. Click OK.
  10. In the Connection Description window, enter a name and select an icon for the connection.
  11. Click OK.
  12. Press Enter.
  13. When the Main Menu screen appears, reboot the bridge.
    Turn the unit off and then back on.
  14. When the bridge reboots and the Main Menu screen reappears, enter 2 in order to choose Reset.
  15. Press Enter.
  16. Enter Yes.
  17. Press Enter in order to confirm the command.
  18. After the bridge reboots and the Express Setup screen appears, reconfigure the bridge with the terminal emulator or an Internet browser.
see this link 340 Wireless Bridge
Posted on Jul 25, 2008
  • 30 Answers
SOURCE: How can I change the default management vlan (vlan
create a new vlan (eg vlan 10)
then ensure that the ethernet port is the same bridge group number as the new vlan (bridge-group 10)
do the same for the wireless port
then shut down vlan 1
Posted on Dec 05, 2009
  • 54 Answers
SOURCE: there is issue of low signal strength showing in
Signal strength can have a lot to do with where the router is compaired to where you sit at your pc/ laptop. If you have a house with thick walls you should go for a N type router rather than the G (standard router type). but a simple way to boost signal is to put a pice of tinfoil behind the anntenae of the router, directing the signal to where your computer is and not letting it just dissipate into the walls of the house in all directions.
hope this helps, but remessage if I have not been clear enough ;)
Posted on Oct 07, 2010
Reset cisco aironet 350 adapter
Try Putty and a 9pin male to RJ45 RS232 serial console cable.
the instructions are in the link provided here:
http://wirelesslanprofessionals.com/wp-content/uploads/2010/01/Password-Recovery-on-Cisco-APs.pdf
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | Computers & Internet
Tip
Cisco Wireless, Access to Information and Resources in Wireless Networks
Cisco wireless solutions ensure that your business is able to react to the constant demands of the fast moving global economy. And the Cisco Unified Wireless Network helps enable the Borderless Mobility Experience with a broad portfolio of products that provide anywhere, anytime access to information with the same quality of experience provided by a wired network.<br /><br />For every Cisco fans, they are familiar with all the <a href="http://www.router-switch.com/Price-cisco-wireless-ap_c5">Cisco wireless products</a>, such as <a href="http://www.router-switch.com/Price-cisco-wireless-ap_c5">Access Point</a>, Client Adapters and Client Software, Antennas, Wireless LAN Controller, Wireless Integrated Switches and Routers, Wireless LAN Management, Outdoor Wireless, Mobile Wireless, Service Control for Mobile Networks, Wireless IP Telephony, etc. <br /><br />Firstly, let's get some questions that were asked by people who used Cisco wireless products<br />"I need drivers, and help on how to set up a Cisco Wireless Adapter? I have a Cisco Aironet 802.11a/b/g Wireless CardBus Adapter that I am unsure on how to set up. I can't find drivers for it on the cisco website, or anywhere on the web. If anyone could link me to the drivers and tell me how to set it up that would be great!"<br /><br />"How do I enable the wireless in a Cisco Aironet access point? This is 1200 series Cisco systems AP which is shipped with the wireless disabled, I have only laptop at my disposal. I have tried to communicate with it using it's supplied ethernet cable but either my laptop does not see it or it does not respond. I have the small hand book that comes with it so I do know all the default settings."<br /><br />"Where can I get coupons for Linksys by Cisco Wireless-N Broadband Router? Where can I find a discount online for Linksys by Cisco Wireless-N Broadband Router?"<br />...<br /><br />No matter what Cisco wireless products you have, many people will be confused with how to use it. So we can learn some basic features of Cisco wireless items to help you know it well.<br /><br />Take Cisco Wireless Access Point as a typical example, Cisco Aironet access points and bridges connect wireless devices to networks, providing ubiquitous network access for indoor and outdoor environments. Cisco's next-generation wireless solutions offer comprehensive wireless coverage with up to nine times the throughput of 802.11a/b/g networks. Cisco enterprise wireless mesh helps enable cost-effective, scalable deployment of highly secure indoor and outdoor wireless LANs.<br /><br />Overview on some popular Cisco wireless Products<br />Cisco Aironet 1250 Series Wireless Access Points built on a robust modular platform designed for easy field upgrades, facilitating support of a variety of wireless capabilities<br />including data rates of 300Mbps per radio while providing reliable and predictable WLAN coverage.<br /> <br /><br />Cisco Aironet 1140 Series Draft N Access Points give six times the performance of 802.11a/g networks for reliable connections to Wi-Fi voice, streaming video, and business applications. Cisco Aironet 1140 Series indoor access points have a sleek design that blends into enterprise environments, and they can be powered with standard 802.3af Power over Ethernet.<br /> <br /><br /><a href="http://www.router-switch.com/Price-cisco-wireless-ap-1250-series-access-point_c55">Cisco Wireless LAN Controllers</a> (Standalone and Modules), simplify the deployment and operation of wireless networks, ensuring smooth performance, enhanced security, and maximum network availability. Cisco wireless LAN controllers communicate with Cisco Aironet access points over any Layer 2 or Layer 3 infrastructure and support 802.11a/b/g and the IEEE 802.11n draft 2.0 standard.<br /> <br /><br />Notes: More info such as price, purchasing info, feature details and specs of Cisco wireless products you can visit routerswitch.com---<span>Cisco Wireless</span>, or go to Cisco's official site see more wireless solutions and services. <br />
on Jul 19, 2011 | Computers & Internet
Aironet 1100 ap amber led light
What controller are you using? You are correct - it is an IOS error. Usually the AP is not compatible with the WLC ios.
Mar 16, 2013 | Aironet 1100 802.11a/b/g AP...
My Cisco aironet 1141N-ke9 showing red blinking continuously and stuck in that .Now only access via console.Can any one solve it
Sounds like the network connection to the AP is shot. Try a different cable, different port on the switch, or repower the device.
Aug 05, 2012 | Aironet Air-ap1141n-a-k9 Cisco 1140 Series...
Can't connect to my Cisco Aironet 350 wireless Access Point
Did you setup and configure your Cisco aironet 350 directly from your laptop? I would verify the IP configuration on your laptop and make sure that your Default Gateway and subnet mask and DNS are set correctly. Give it a static address on the same subnet and see if it can see the router. Hope that helps!
Cheers!
J the Guru
Sep 09, 2017 | Cisco Aironet 350 Series Wireless...
How can I change the default management vlan (vlan 1) to another vlan # in Cisco Aironet 1242G wireless AP
Oct 06, 2009 | Cisco Aironet 1242ag 802.11a/b/g Wireless...
Boot Loop
you may have to reload the OS of the router.
i dont suppose you can kick it into romon mode can you? (usually done by hitting the pause break button on boot.)
if you can you should be able to use Xmodem to reload the OS (as long as you have a copy of it located on your computer)
Mar 11, 2008 | Cisco 1603-R Router
Cisco Aironet 1200
Feb 18, 2008 | Cisco Computers & Internet
Configure cisco aironet wifi
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Cisco Aironet 3602i Wireless Access Point AIRCAP3602ICK9 Logo
1,676 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
